wdt.h
1
6 /* Copyright (c) 2002, 2004 Marek Michalkiewicz
7  Copyright (c) 2005, 2006, 2007 Eric B. Weddington
8  All rights reserved.
9
10  Redistribution and use in source and binary forms, with or without
11  modification, are permitted provided that the following conditions are met:
12
13  * Redistributions of source code must retain the above copyright
14  notice, this list of conditions and the following disclaimer.
15
16  * Redistributions in binary form must reproduce the above copyright
17  notice, this list of conditions and the following disclaimer in
18  the documentation and/or other materials provided with the
19  distribution.
20
21  * Neither the name of the copyright holders nor the names of
22  contributors may be used to endorse or promote products derived
23  from this software without specific prior written permission.
24
25  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26  AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27  IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28  ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29  LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30  CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31  SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32  INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33  CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34  ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35  POSSIBILITY OF SUCH DAMAGE. */
36
37
38 /*
39  avr/wdt.h - macros for AVR watchdog timer
40  */
41
42 #ifndef _AVR_WDT_H_
43 #define _AVR_WDT_H_
44
45 #include <avr/io.h>
46 #include <stdint.h>
47
104 #define wdt_reset() __asm__ __volatile__ ("wdr")
105
106
107 #if defined(WDP3)
108 # define _WD_PS3_MASK _BV(WDP3)
109 #else
110 # define _WD_PS3_MASK 0x00
111 #endif
112
113 #if defined(WDTCSR)
114 # define _WD_CONTROL_REG WDTCSR
115 #else
116 # define _WD_CONTROL_REG WDTCR
117 #endif
118
119 #if defined(WDTOE)
120 #define _WD_CHANGE_BIT WDTOE
121 #else
122 #define _WD_CHANGE_BIT WDCE
123 #endif
124
125
137 #if defined(__AVR_ATxmega16A4__) \
138 || defined(__AVR_ATxmega16D4__) \
139 || defined(__AVR_ATxmega32A4__) \
140 || defined(__AVR_ATxmega32D4__) \
141 || defined(__AVR_ATxmega64A1__) \
142 || defined(__AVR_ATxmega64A3__) \
143 || defined(__AVR_ATxmega64D3__) \
144 || defined(__AVR_ATxmega128A1__) \
145 || defined(__AVR_ATxmega128A3__) \
146 || defined(__AVR_ATxmega128D3__) \
147 || defined(__AVR_ATxmega192A3__) \
148 || defined(__AVR_ATxmega192D3__) \
149 || defined(__AVR_ATxmega256A3__) \
150 || defined(__AVR_ATxmega256D3__) \
151 || defined(__AVR_ATxmega256A3B__)
152
153 /*
154  wdt_enable(WDT_PER_8KCLK_gc);
155 */
156 #define wdt_enable(value) \
157 __asm__ __volatile__ ( \
158  "in __tmp_reg__, %0" "\n\t" \
159  "out %1, %3" "\n\t" \
160  "sts %2, %4" "\n\t" \
161  "wdr" "\n\t" \
162  "out %0, __tmp_reg__" "\n\t" \
163  : \
164  : "M" (_SFR_MEM_ADDR(RAMPD)), \
165  "M" (_SFR_MEM_ADDR(CCP)), \
166  "M" (_SFR_MEM_ADDR(WDT_CTRL)), \
167  "r" ((uint8_t)0xD8), \
168  "r" ((uint8_t)(WDT_CEN_bm | WDT_ENABLE_bm | value)) \
169  : "r0" \
170 )
171
172
173 #elif defined(__AVR_AT90CAN32__) \
174 || defined(__AVR_AT90CAN64__) \
175 || defined(__AVR_AT90CAN128__) \
176 || defined(__AVR_AT90PWM1__) \
177 || defined(__AVR_AT90PWM2__) \
178 || defined(__AVR_AT90PWM216__) \
179 || defined(__AVR_AT90PWM2B__) \
180 || defined(__AVR_AT90PWM3__) \
181 || defined(__AVR_AT90PWM316__) \
182 || defined(__AVR_AT90PWM3B__) \
183 || defined(__AVR_AT90PWM81__) \
184 || defined(__AVR_AT90USB1286__) \
185 || defined(__AVR_AT90USB1287__) \
186 || defined(__AVR_AT90USB162__) \
187 || defined(__AVR_AT90USB646__) \
188 || defined(__AVR_AT90USB647__) \
189 || defined(__AVR_AT90USB82__) \
190 || defined(__AVR_ATmega1280__) \
191 || defined(__AVR_ATmega1281__) \
192 || defined(__AVR_ATmega1284P__) \
193 || defined(__AVR_ATmega128RFA1__) \
194 || defined(__AVR_ATmega164__) \
195 || defined(__AVR_ATmega164A__) \
196 || defined(__AVR_ATmega164P__) \
197 || defined(__AVR_ATmega165__) \
198 || defined(__AVR_ATmega165A__) \
199 || defined(__AVR_ATmega165P__) \
200 || defined(__AVR_ATmega168__) \
201 || defined(__AVR_ATmega168A__) \
202 || defined(__AVR_ATmega168P__) \
203 || defined(__AVR_ATmega169__) \
204 || defined(__AVR_ATmega169A__) \
205 || defined(__AVR_ATmega169P__) \
206 || defined(__AVR_ATmega169PA__) \
207 || defined(__AVR_ATmega16HVA__) \
208 || defined(__AVR_ATmega16HVA2__) \
209 || defined(__AVR_ATmega16HVB__) \
210 || defined(__AVR_ATmega16M1__) \
211 || defined(__AVR_ATmega16U2__) \
212 || defined(__AVR_ATmega16U4__) \
213 || defined(__AVR_ATmega2560__) \
214 || defined(__AVR_ATmega2561__) \
215 || defined(__AVR_ATmega324__) \
216 || defined(__AVR_ATmega324A__) \
217 || defined(__AVR_ATmega324P__) \
218 || defined(__AVR_ATmega324PA__) \
219 || defined(__AVR_ATmega325__) \
220 || defined(__AVR_ATmega3250__) \
221 || defined(__AVR_ATmega328__) \
222 || defined(__AVR_ATmega328P__) \
223 || defined(__AVR_ATmega329__) \
224 || defined(__AVR_ATmega329P__) \
225 || defined(__AVR_ATmega329PA__) \
226 || defined(__AVR_ATmega3290__) \
227 || defined(__AVR_ATmega3290P__) \
228 || defined(__AVR_ATmega32C1__) \
229 || defined(__AVR_ATmega32HVB__) \
230 || defined(__AVR_ATmega32M1__) \
231 || defined(__AVR_ATmega32U2__) \
232 || defined(__AVR_ATmega32U4__) \
233 || defined(__AVR_ATmega32U6__) \
234 || defined(__AVR_ATmega406__) \
235 || defined(__AVR_ATmega48__) \
236 || defined(__AVR_ATmega48A__) \
237 || defined(__AVR_ATmega48P__) \
238 || defined(__AVR_ATmega640__) \
239 || defined(__AVR_ATmega644__) \
240 || defined(__AVR_ATmega644A__) \
241 || defined(__AVR_ATmega644P__) \
242 || defined(__AVR_ATmega644PA__) \
243 || defined(__AVR_ATmega645__) \
244 || defined(__AVR_ATmega645A__) \
245 || defined(__AVR_ATmega645P__) \
246 || defined(__AVR_ATmega6450__) \
247 || defined(__AVR_ATmega6450A__) \
248 || defined(__AVR_ATmega6450P__) \
249 || defined(__AVR_ATmega649__) \
250 || defined(__AVR_ATmega649A__) \
251 || defined(__AVR_ATmega6490__) \
252 || defined(__AVR_ATmega6490A__) \
253 || defined(__AVR_ATmega6490P__) \
254 || defined(__AVR_ATmega649P__) \
255 || defined(__AVR_ATmega64C1__) \
256 || defined(__AVR_ATmega64HVE__) \
257 || defined(__AVR_ATmega64M1__) \
258 || defined(__AVR_ATmega88__) \
259 || defined(__AVR_ATmega88A__) \
260 || defined(__AVR_ATmega88P__) \
261 || defined(__AVR_ATmega88PA__) \
262 || defined(__AVR_ATmega8HVA__) \
263 || defined(__AVR_ATmega8U2__) \
264 || defined(__AVR_ATtiny48__) \
265 || defined(__AVR_ATtiny88__) \
266 || defined(__AVR_ATtiny87__) \
267 || defined(__AVR_ATtiny167__) \
268 || defined(__AVR_AT90SCR100__) \
269 || defined(__AVR_ATA6289__)
270
271 /* Use STS instruction. */
272
273 #define wdt_enable(value) \
274 __asm__ __volatile__ ( \
275  "in __tmp_reg__,__SREG__" "\n\t" \
276  "cli" "\n\t" \
277  "wdr" "\n\t" \
278  "sts %0,%1" "\n\t" \
279  "out __SREG__,__tmp_reg__" "\n\t" \
280  "sts %0,%2" "\n\t" \
281  : /* no outputs */ \
282  : "M" (_SFR_MEM_ADDR(_WD_CONTROL_REG)), \
283  "r" (_BV(_WD_CHANGE_BIT) | _BV(WDE)), \
284  "r" ((uint8_t) ((value & 0x08 ? _WD_PS3_MASK : 0x00) | \
285  _BV(WDE) | (value & 0x07)) ) \
286  : "r0" \
287 )
288
289 #define wdt_disable() \
290 __asm__ __volatile__ ( \
291  "in __tmp_reg__, __SREG__" "\n\t" \
292  "cli" "\n\t" \
293  "sts %0, %1" "\n\t" \
294  "sts %0, __zero_reg__" "\n\t" \
295  "out __SREG__,__tmp_reg__" "\n\t" \
296  : /* no outputs */ \
297  : "M" (_SFR_MEM_ADDR(_WD_CONTROL_REG)), \
298  "r" ((uint8_t)(_BV(_WD_CHANGE_BIT) | _BV(WDE))) \
299  : "r0" \
300 )
301
302
303
304 #else
305
306 /* Use OUT instruction. */
307
308 #define wdt_enable(value) \
309  __asm__ __volatile__ ( \
310  "in __tmp_reg__,__SREG__" "\n\t" \
311  "cli" "\n\t" \
312  "wdr" "\n\t" \
313  "out %0,%1" "\n\t" \
314  "out __SREG__,__tmp_reg__" "\n\t" \
315  "out %0,%2" \
316  : /* no outputs */ \
317  : "I" (_SFR_IO_ADDR(_WD_CONTROL_REG)), \
318  "r" (_BV(_WD_CHANGE_BIT) | _BV(WDE)), \
319  "r" ((uint8_t) ((value & 0x08 ? _WD_PS3_MASK : 0x00) | \
320  _BV(WDE) | (value & 0x07)) ) \
321  : "r0" \
322  )
323
329 #define wdt_disable() \
330 __asm__ __volatile__ ( \
331  "in __tmp_reg__, __SREG__" "\n\t" \
332  "cli" "\n\t" \
333  "out %0, %1" "\n\t" \
334  "out %0, __zero_reg__" "\n\t" \
335  "out __SREG__,__tmp_reg__" "\n\t" \
336  : /* no outputs */ \
337  : "I" (_SFR_IO_ADDR(_WD_CONTROL_REG)), \
338  "r" ((uint8_t)(_BV(_WD_CHANGE_BIT) | _BV(WDE))) \
339  : "r0" \
340 )
341
342 #endif
343
344
345
367 #define WDTO_15MS 0
368
370 #define WDTO_30MS 1
371
373 #define WDTO_60MS 2
374
376 #define WDTO_120MS 3
377
379 #define WDTO_250MS 4
380
382 #define WDTO_500MS 5
383
385 #define WDTO_1S 6
386
388 #define WDTO_2S 7
389
390 #if defined(__DOXYGEN__) || defined(WDP3)
391
412 #define WDTO_4S 8
413
415 #define WDTO_8S 9
416
417 #endif /* defined(__DOXYGEN__) || defined(WDP3) */
418
420 #endif /* _AVR_WDT_H_ */
AVR device-specific IO Definitions.
