_rtems_rfs_file_shared Struct Reference
File data that is shared by various file handles accessing the same file. More...
#include <rtems-rfs-file.h>
Collaboration diagram for _rtems_rfs_file_shared:
Collaboration graph
[legend]
rtems_chain_node link
 The shared parts are maintained as a list.
int references
 Reference count the users of this data.
rtems_rfs_inode_handle inode
 The inode for the file.
rtems_rfs_block_map map
 The block map for the file. More...
rtems_rfs_block_size size
 The size of the file as taken from the inode. More...
rtems_rfs_time atime
 The access time. More...
rtems_rfs_time mtime
 The modified time. More...
rtems_rfs_time ctime
 The change time. More...
rtems_rfs_file_systemfs
 Hold a pointer to the file system data so users can take the handle and use it without the needing to hold the file system data pointer.
We hold various inode values common to the file that can change frequently so the inode is not thrashed yet we meet the requirements of the POSIX standard. The stat call needs to check the shared file data.
Field Documentation
◆ atime
rtems_rfs_time _rtems_rfs_file_shared::atime
The access time.
The last time the file was read.
◆ ctime
rtems_rfs_time _rtems_rfs_file_shared::ctime
The change time.
The last time the inode was written too.
◆ map
rtems_rfs_block_map _rtems_rfs_file_shared::map
The handle holds the file's position not the map.
◆ mtime
rtems_rfs_time _rtems_rfs_file_shared::mtime
The modified time.
The last time the file was written too.
◆ size
rtems_rfs_block_size _rtems_rfs_file_shared::size
The map's size and this size should be the same.
