mpci.h
1
9 /*
10  * COPYRIGHT (c) 1989-2009.
11  * On-Line Applications Research Corporation (OAR).
12  *
13  * The license and distribution terms for this file may be
14  * found in the file LICENSE in this distribution or at
15  * http://www.rtems.org/license/LICENSE.
16  */
17
18 #ifndef _RTEMS_SCORE_MPCI_H
19 #define _RTEMS_SCORE_MPCI_H
20
21 #include <rtems/score/mppkt.h>
22 #include <rtems/score/thread.h>
23 #include <rtems/score/threadq.h>
24 #include <rtems/score/watchdog.h>
25
26 #ifdef __cplusplus
27 extern "C" {
28 #endif
29
46 #define MPCI_ALL_NODES 0
47
51 typedef void MPCI_Entry;
52
58
66  );
67
76  );
77
85  uint32_t,
87  );
88
98  );
99
108 typedef struct {
110  uint32_t default_timeout;
126 } MPCI_Control;
127
130 #ifdef __cplusplus
131 }
132 #endif
133
134 #endif
135 /* end of include file */
MPCI_receive_entry receive_packet
This field points to the MPCI receive packet entry point.
Definition: mpci.h:125
The following record contains the prefix for every packet passed between nodes in an MP system...
Definition: mppkt.h:80
MPCI_Entry(* MPCI_get_packet_entry)(MP_packet_Prefix **)
This type defines the prototype for the get packet entry point in an Multiprocessor Communications In...
Definition: mpci.h:64
Constants and Structures Associated with Watchdog Timers.
size_t maximum_packet_size
This field contains the maximum size of a packet supported by this MPCI layer.
Definition: mpci.h:115
Constants and Structures Needed to Declare a Thread Queue.
This fields contains the timeout for MPCI operations in ticks.
Definition: mpci.h:110
Constants and Structures Related with the Thread Control Block.
void MPCI_Entry
This type is returned by all user provided MPCI routines.
Definition: mpci.h:51
MPCI_send_entry send_packet
This field points to the MPCI send packet entry point.
Definition: mpci.h:123
This type defines the Multiprocessor Communications Interface (MPCI) Table.
Definition: mpci.h:108
MPCI_Entry(* MPCI_receive_entry)(MP_packet_Prefix **)
This type defines the prototype for the receive packet entry point in an Multiprocessor Communication...
Definition: mpci.h:96
Specification for the Packet Handler.
MPCI_Entry(* MPCI_return_packet_entry)(MP_packet_Prefix *)
This type defines the prototype for the return packet entry point in an Multiprocessor Communications...
Definition: mpci.h:74
MPCI_initialization_entry initialization
This field points to the MPCI initialization entry point.
Definition: mpci.h:117
MPCI_Entry(* MPCI_initialization_entry)(void)
This type defines the prototype for the initization entry point in an Multiprocessor Communications I...
Definition: mpci.h:57
MPCI_return_packet_entry return_packet
This field points to the MPCI return packet entry point.
Definition: mpci.h:121
MPCI_get_packet_entry get_packet
This field points to the MPCI get packet entry point.
Definition: mpci.h:119
MPCI_Entry(* MPCI_send_entry)(uint32_t, MP_packet_Prefix *)
This type defines the prototype for send get packet entry point in an Multiprocessor Communications I...
Definition: mpci.h:84
