MP_packet_Prefix Struct Reference
The following record contains the prefix for every packet passed between nodes in an MP system. More...
#include <mppkt.h>
MP_packet_Classes the_class
 This field indicates the API class of the operation being performed. More...
Objects_Id id
 This field is the id of the object to be acted upon. More...
Objects_Id source_tid
 This field is the ID of the originating thread. More...
Priority_Control source_priority
 This field is the priority of the originating thread. More...
uint32_t return_code
 This field is where the status of the operation will be returned. More...
uint32_t length
 This field is the length of the data following the prefix. More...
uint32_t to_convert
 This field is the length of the data which required network conversion. More...
Watchdog_Interval timeout
 This field is the requested timeout for this operation. More...
Note
This structure is padded to ensure that anything following it is on a 16 byte boundary. This is the most stringent structure alignment rule encountered yet.
Field Documentation
◆ id
Objects_Id MP_packet_Prefix::id
Referenced by _MPCI_Process_response().
◆ length
uint32_t MP_packet_Prefix::length
◆ return_code
uint32_t MP_packet_Prefix::return_code
◆ source_priority
Priority_Control MP_packet_Prefix::source_priority
◆ source_tid
Objects_Id MP_packet_Prefix::source_tid
Referenced by _MPCI_Send_process_packet(), and _MPCI_Send_response_packet().
◆ the_class
MP_packet_Classes MP_packet_Prefix::the_class
Referenced by _MPCI_Receive_server().
◆ timeout
Watchdog_Interval MP_packet_Prefix::timeout
◆ to_convert
uint32_t MP_packet_Prefix::to_convert
