Data Structures | Macros | Enumerations
MP Packet Handler
This handler encapsulates the primary definition of MPCI packets. More...
Collaboration diagram for MP Packet Handler:
struct  MP_packet_Prefix
 The following record contains the prefix for every packet passed between nodes in an MP system. More...
#define MP_PACKET_CLASSES_FIRST   MP_PACKET_MPCI_INTERNAL
 This constant defines the first entry in the MP_packet_Classes enumeration.
#define MP_PACKET_CLASSES_LAST   MP_PACKET_SIGNAL
 This constant defines the last entry in the MP_packet_Classes enumeration.
#define MP_PACKET_MINIMUM_PACKET_SIZE   64
 An MPCI must support packets of at least this size.
#define MP_PACKET_MINIMUN_HETERO_CONVERSION   ( sizeof( MP_packet_Prefix ) / sizeof( uint32_t ) )
 The following constant defines the number of uint32_t's in a packet which must be converted to native format in a heterogeneous system. More...
enum  MP_packet_Classes {
  MP_PACKET_MPCI_INTERNAL = 0, MP_PACKET_TASKS = 1, MP_PACKET_MESSAGE_QUEUE = 2, MP_PACKET_SEMAPHORE = 3,
  MP_PACKET_PARTITION = 4, MP_PACKET_REGION = 5, MP_PACKET_EVENT = 6, MP_PACKET_SIGNAL = 7
 The following enumerated type defines the packet classes. More...
This handler defines the part of the packet that is common to all remote operations.
◆ MP_PACKET_MINIMUN_HETERO_CONVERSION
In packets longer than MP_PACKET_MINIMUN_HETERO_CONVERSION uint32_t's, some of the "extra" data may a user message buffer which is not automatically endian swapped.
◆ MP_packet_Classes
Note
In general, each class corresponds to a manager which supports global operations. Each manager defines the set of supported operations.
