This handler encapsulates functionality which provides the foundation Spinlock services used in all of the APIs supported by RTEMS. More...
Files | |
| file | corespinlock.c |
| Initialize a Spinlock. | |
| file | corespinlockrelease.c |
| Release a Spinlock. | |
| struct | CORE_spinlock_Attributes |
| The following defines the control block used to manage the attributes of each spinlock. More... | |
| struct | CORE_spinlock_Control |
| The following defines the control block used to manage each spinlock. More... | |
| #define | CORE_SPINLOCK_STATUS_LAST CORE_SPINLOCK_UNAVAILABLE |
| This is a shorthand for the last status code. More... | |
| #define | CORE_SPINLOCK_UNLOCKED 0 |
| This indicates the lock is available. More... | |
| #define | CORE_SPINLOCK_LOCKED 1 |
| This indicates the lock is unavailable. More... | |
Enumerations | |
| enum | CORE_spinlock_Status { CORE_SPINLOCK_SUCCESSFUL, CORE_SPINLOCK_HOLDER_RELOCKING, CORE_SPINLOCK_NOT_HOLDER, CORE_SPINLOCK_TIMEOUT, CORE_SPINLOCK_IS_BUSY, CORE_SPINLOCK_UNAVAILABLE } |
| Core Spinlock handler return statuses. More... | |
| void | _CORE_spinlock_Initialize (CORE_spinlock_Control *the_spinlock, CORE_spinlock_Attributes *the_spinlock_attributes) |
| Initialize the spinlock. More... | |
| CORE_spinlock_Status | _CORE_spinlock_Wait (CORE_spinlock_Control *the_spinlock, bool wait, Watchdog_Interval timeout) |
| Wait for spinlock. More... | |
| CORE_spinlock_Status | _CORE_spinlock_Release (CORE_spinlock_Control *the_spinlock) |
| Manually release the spinlock. More... | |
| RTEMS_INLINE_ROUTINE void | _CORE_spinlock_Initialize_attributes (CORE_spinlock_Attributes *the_attributes) |
| This method is used to initialize core spinlock attributes. More... | |
| RTEMS_INLINE_ROUTINE bool | _CORE_spinlock_Is_busy (CORE_spinlock_Control *the_spinlock) |
| This method is used to determine if the spinlock is available or not. More... | |
| #define CORE_SPINLOCK_LOCKED 1 |
Referenced by _CORE_spinlock_Release().
| #define CORE_SPINLOCK_STATUS_LAST CORE_SPINLOCK_UNAVAILABLE |
Referenced by _POSIX_Spinlock_Translate_core_spinlock_return_code().
| #define CORE_SPINLOCK_UNLOCKED 0 |
| enum CORE_spinlock_Status |
| void _CORE_spinlock_Initialize | ( | CORE_spinlock_Control * | the_spinlock, |
| CORE_spinlock_Attributes * | the_spinlock_attributes | ||
This routine initializes the spinlock based on the parameters passed.
| [in] | the_spinlock | is the spinlock control block to initialize |
| [in] | the_spinlock_attributes | define the behavior of this instance |
References CORE_spinlock_Control::Attributes, CORE_spinlock_Control::holder, CORE_spinlock_Control::lock, and CORE_spinlock_Control::users.
| RTEMS_INLINE_ROUTINE void _CORE_spinlock_Initialize_attributes | ( | CORE_spinlock_Attributes * | the_attributes | ) |
| [in] | the_attributes | pointer to the attributes to initialize. |
References CORE_spinlock_Attributes::XXX.
| RTEMS_INLINE_ROUTINE bool _CORE_spinlock_Is_busy | ( | CORE_spinlock_Control * | the_spinlock | ) |
| [in] | the_spinlock | will be checked |
References CORE_spinlock_Control::users.
| CORE_spinlock_Status _CORE_spinlock_Release | ( | CORE_spinlock_Control * | the_spinlock | ) |
This routine manually releases the spinlock. All of the threads waiting for the spinlock will be readied.
| [in] | the_spinlock | is the spinlock to surrender |
References _ISR_Disable, CORE_SPINLOCK_LOCKED, CORE_spinlock_Control::holder, and CORE_spinlock_Control::lock.
| CORE_spinlock_Status _CORE_spinlock_Wait | ( | CORE_spinlock_Control * | the_spinlock, |
| bool | wait, | ||
| Watchdog_Interval | timeout | ||
Wait for spinlock.
This routine wait for the spinlock to be released. If the spinlock is set to automatic and this is the appropriate thread, then it returns immediately. Otherwise, the calling thread is blocked until the spinlock is released.
| [in] | the_spinlock | is the spinlock to wait for |
| [in] | wait | is true if willing to wait |
| [in] | timeout | is the maximum number of ticks to spin (0 is forever) |
| A | status is returned which indicates the success or failure of this operation. |
