Defines to control the file system: More...
| #define | CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK IMFS_MEMFILE_DEFAULT_BYTES_PER_BLOCK |
| IMFS. More... | |
| #define | CONFIGURE_SEMAPHORES_FOR_NFS 0 |
| This defines the IMFS file system table entry. More... | |
| #define | CONFIGURE_SEMAPHORES_FOR_DOSFS 0 |
| DOSFS. | |
| #define | CONFIGURE_SEMAPHORES_FOR_RFS 0 |
| RFS. | |
| #define | CONFIGURE_SEMAPHORES_FOR_JFFS2 0 |
| JFFS2. | |
| #define | CONFIGURE_SEMAPHORES_FOR_FILE_SYSTEMS |
| This computes the number of semaphores required for the various file systems including the FIFO plugin to the IMFS. More... | |
List of available file systems. You can define as many as you like:
Combinations:
| #define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK IMFS_MEMFILE_DEFAULT_BYTES_PER_BLOCK |
IMFS.
This specifies the number of bytes per block for files within the IMFS. There are a maximum number of blocks per file so this dictates the maximum size of a file. This has to be balanced with the unused portion of each block that might be wasted.
| #define CONFIGURE_SEMAPHORES_FOR_FILE_SYSTEMS |
This is an internal parameter.
| #define CONFIGURE_SEMAPHORES_FOR_NFS 0 |
DEVFS
