Files | Macros | Functions
Classic Event Implementation
Collaboration diagram for Classic Event Implementation:
file  eventimpl.h
 Classic Event Implementation.
#define EVENT_CURRENT   0
 This constant is passed as the event_in to the rtems_event_receive directive to determine which events are pending.
#define EVENT_SETS_NONE_PENDING   0
 The following constant is the value of an event set which has no events pending.
void _Event_Manager_initialization (void)
 Event Manager Initialization. More...
void _Event_Seize (rtems_event_set event_in, rtems_option option_set, rtems_interval ticks, rtems_event_set *event_out, Thread_Control *executing, Event_Control *event, Thread_Wait_flags wait_class, States_Control block_state, ISR_lock_Context *lock_context)
void _Event_Surrender (Thread_Control *the_thread, rtems_event_set event_in, Event_Control *event, Thread_Wait_flags wait_class, ISR_lock_Context *lock_context)
void _Event_Timeout (Objects_Id id, void *arg)
 Timeout Event.
RTEMS_INLINE_ROUTINE void _Event_Initialize (Event_Control *event)
RTEMS_INLINE_ROUTINE bool _Event_sets_Is_empty (rtems_event_set the_event_set)
 Checks if on events are posted in the event_set. More...
RTEMS_INLINE_ROUTINE void _Event_sets_Post (rtems_event_set the_new_events, rtems_event_set *the_event_set)
 Posts the given new_events into the event_set passed in. More...
RTEMS_INLINE_ROUTINE rtems_event_set _Event_sets_Get (rtems_event_set the_event_set, rtems_event_set the_event_condition)
 Returns the events in event_condition that are set in event_set. More...
RTEMS_INLINE_ROUTINE rtems_event_set _Event_sets_Clear (rtems_event_set the_event_set, rtems_event_set the_mask)
 Removes the events in mask from the event_set passed in. More...
◆ _Event_Manager_initialization()
void _Event_Manager_initialization ( void  )
Event Manager
This routine performs the initialization necessary for this manager.
  • INTERRUPT LATENCY:
    • single case
References _MPCI_Register_packet_processor().
◆ _Event_sets_Clear()
RTEMS_INLINE_ROUTINE rtems_event_set _Event_sets_Clear ( rtems_event_set  the_event_set,
This function removes the events in mask from the event_set passed in. The result is returned to the user in event_set.
◆ _Event_sets_Get()
RTEMS_INLINE_ROUTINE rtems_event_set _Event_sets_Get ( rtems_event_set  the_event_set,
This function returns the events in event_condition which are set in event_set.
◆ _Event_sets_Is_empty()
RTEMS_INLINE_ROUTINE bool _Event_sets_Is_empty ( rtems_event_set  the_event_set)
This function returns TRUE if on events are posted in the event_set, and FALSE otherwise.
Referenced by rtems_event_receive(), and rtems_event_system_receive().
◆ _Event_sets_Post()
RTEMS_INLINE_ROUTINE void _Event_sets_Post ( rtems_event_set  the_new_events,
This routine posts the given new_events into the event_set passed in. The result is returned to the user in event_set.
