File Transfer Protocol file system (FTP client). More...
#include <ctype.h>#include <errno.h>#include <fcntl.h>#include <malloc.h>#include <netdb.h>#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <unistd.h>#include <arpa/inet.h>#include <netinet/in.h>#include <sys/select.h>#include <sys/socket.h>#include <sys/types.h>#include <rtems.h>#include <rtems/ftpfs.h>#include <rtems/libio_.h>#include <rtems/rtems_bsdnet.h>#include <rtems/seterr.h>
| struct | rtems_ftpfs_entry |
| Connection entry for each open file stream. More... | |
| struct | rtems_ftpfs_mount_entry |
| Mount entry for each file system instance. More... | |
| struct | rtems_ftpfs_pasv_entry |
| struct | rtems_ftpfs_size_entry |
| #define | DEBUG_PRINTF(...) |
| #define | RTEMS_FTPFS_REPLY_SIZE 3 |
Typedefs | |
| typedef void(* | rtems_ftpfs_reply_parser) (const char *, size_t, void *) |
| rtems_status_code | rtems_ftpfs_get_verbose (const char *mount_point, bool *verbose) |
| Returns in verbose if the verbose mode is enabled or disabled for the file system at mount_point. More... | |
| rtems_status_code | rtems_ftpfs_set_verbose (const char *mount_point, bool verbose) |
Enables or disables the verbose mode if verbose is true or false respectively for the file system at mount_point. More... | |
| rtems_status_code | rtems_ftpfs_get_timeout (const char *mount_point, struct timeval *timeout) |
| Returns the current timeout value in timeout for the file system at mount_point. More... | |
| rtems_status_code | rtems_ftpfs_set_timeout (const char *mount_point, const struct timeval *timeout) |
| Sets the timeout value to timeout for the file system at mount_point. More... | |
| int | rtems_ftpfs_initialize (rtems_filesystem_mount_table_entry_t *e, const void *d) |
| Do not call directly, use mount(). | |
