POSIX Thread Cancelation Support. More...
#include <rtems/posix/threadsup.h>
struct | POSIX_Cancel_Handler_control |
This structure is used to manage the cancelation handlers. More... | |
void | _POSIX_Threads_cancel_run (Thread_Control *the_thread) |
POSIX run thread cancelation. More... | |
void | _POSIX_Thread_Evaluate_cancellation_and_enable_dispatch (Thread_Control *the_thread) |
POSIX evaluate thread cancelation and enable dispatch. More... | |
This file contains the prototypes and data types used to implement POSIX thread cancelation.
void _POSIX_Thread_Evaluate_cancellation_and_enable_dispatch | ( | Thread_Control * | the_thread | ) |
This routine separates a piece of code that existed as part of another routine, but had to be separated to improve coverage.
[in] | the_thread | is a pointer to the thread to evaluate canceling |
References _Objects_Put(), _POSIX_Thread_Exit(), _Thread_Unnest_dispatch(), Thread_Control::API_Extensions, POSIX_API_Control::cancelability_state, POSIX_API_Control::cancelability_type, POSIX_API_Control::cancelation_requested, Thread_Control::Object, and THREAD_API_POSIX.
void _POSIX_Threads_cancel_run | ( | Thread_Control * | the_thread | ) |
This support routine runs through the chain of cancel handlers that have been registered and executes them.
[in] | the_thread | is a pointer to the thread whose cancelation handlers should be run |
References _Chain_Extract_unprotected(), _Chain_Is_empty(), _Chain_Tail(), _ISR_Disable, _ISR_Enable, _Thread_Disable_dispatch(), _Thread_Enable_dispatch(), _Workspace_Free(), Thread_Control::API_Extensions, POSIX_Cancel_Handler_control::arg, POSIX_API_Control::cancelability_state, POSIX_API_Control::Cancellation_Handlers, POSIX_Cancel_Handler_control::Node, Chain_Node_struct::previous, POSIX_Cancel_Handler_control::routine, and THREAD_API_POSIX.
