RTEMS 4.10.0 On-Line Library
Object Services Directives
RTEMS C User's Guide
27.4: Directives
Object Services BUILD_NAME - Build object name from characters
Object Services OBJECT_GET_CLASSIC_NAME - Lookup name from id
Object Services OBJECT_GET_NAME - Obtain object name as string
Object Services OBJECT_SET_NAME - Set object name
Object Services OBJECT_ID_GET_API - Obtain API from Id
Object Services OBJECT_ID_GET_CLASS - Obtain Class from Id
Object Services OBJECT_ID_GET_NODE - Obtain Node from Id
Object Services OBJECT_ID_GET_INDEX - Obtain Index from Id
Object Services BUILD_ID - Build Object Id From Components
Object Services OBJECT_ID_API_MINIMUM - Obtain Minimum API Value
Object Services OBJECT_ID_API_MAXIMUM - Obtain Maximum API Value
Object Services OBJECT_API_MINIMUM_CLASS - Obtain Minimum Class Value
Object Services OBJECT_API_MAXIMUM_CLASS - Obtain Maximum Class Value
Object Services OBJECT_GET_API_NAME - Obtain API Name
Object Services OBJECT_GET_API_CLASS_NAME - Obtain Class Name
Object Services OBJECT_GET_CLASS_INFORMATION - Obtain Class Information
Copyright © 1988-2008
OAR Corporation
