RTEMS Logo
RTEMS 4.10.0 On-Line Library
Object Services OBJECT_GET_NAME - Obtain object name as string
PREV UP NEXT Bookshelf RTEMS C User's Guide
27.4.3: OBJECT_GET_NAME - Obtain object name as string
CALLING SEQUENCE:
char *rtems_object_get_name(
  rtems_id       id,
  size_t         length,
  char          *name
DIRECTIVE STATUS CODES
Returns a pointer to the name if successful or NULL otherwise.
DESCRIPTION:
This service looks up the name of the object specified by id and places it in the memory pointed to by name. Every attempt is made to return name as a printable string even if the object has the Classic API thirty-two bit style name.
NOTES:
This directive is strictly local and does not impact task scheduling.
