RTEMS Logo
RTEMS 4.10.0 On-Line Library
Object Services OBJECT_SET_NAME - Set object name
PREV UP NEXT Bookshelf RTEMS C User's Guide
27.4.4: OBJECT_SET_NAME - Set object name
CALLING SEQUENCE:
rtems_status_code rtems_object_set_name(
  rtems_id       id,
  const char    *name
DIRECTIVE STATUS CODES
RTEMS_SUCCESSFUL - name looked up successfully
RTEMS_INVALID_ADDRESS - invalid name pointer
RTEMS_INVALID_ID - invalid object id
DESCRIPTION:
This service sets the name of id to that specified by the string located at name.
NOTES:
This directive is strictly local and does not impact task scheduling.
If the object specified by id is of a class that has a string name, this method will free the existing name to the RTEMS Workspace and allocate enough memory from the RTEMS Workspace to make a copy of the string located at name.
If the object specified by id is of a class that has a thirty-two bit integer style name, then the first four characters in *name will be used to construct the name. name to the RTEMS Workspace and allocate enough memory from the RTEMS Workspace to make a copy of the string
