int rtems_object_api_minimum_class( int api );
If api is not valid, -1 is returned.
If successful, this service returns the minimum valid for the class
portion of an object Id for the specified api.
This service returns the minimum valid for the class portion of
This directive is strictly local and does not impact task scheduling.
