RTEMS Logo
RTEMS 4.10.0 On-Line Library
Object Services BUILD_NAME - Build object name from characters
PREV UP NEXT Bookshelf RTEMS C User's Guide
27.4.1: BUILD_NAME - Build object name from characters
CALLING SEQUENCE:
rtems_name rtems_build_name(
  uint8_t c1,
  uint8_t c2,
  uint8_t c3,
  uint8_t c4
DIRECTIVE STATUS CODES
Returns a name constructed from the four characters.
DESCRIPTION:
This service takes the four characters provided as arguments and constructs a thirty-two bit object name with c1 in the most significant byte and c4 in the least significant byte.
NOTES:
This directive is strictly local and does not impact task scheduling.
