rtl-rap.h File Reference
RTEMS Run-Time Linker ELF Headers. More...
#include "rtl-fwd.h"
#include "rtl-obj-fwd.h"
#include "rtl-sym.h"
Include dependency graph for rtl-rap.h:
bool rtems_rtl_rap_file_check (rtems_rtl_obj_t *obj, int fd)
 The RAP format check handler. More...
bool rtems_rtl_rap_file_load (rtems_rtl_obj_t *obj, int fd)
 The RAP format load handler. More...
bool rtems_rtl_rap_file_unload (rtems_rtl_obj_t *obj)
 The RAP format unload handler. More...
rtems_rtl_loader_format_t * rtems_rtl_rap_file_sig (void)
 The RAP format signature handler. More...
◆ rtems_rtl_rap_file_check()
bool rtems_rtl_rap_file_check ( rtems_rtl_obj_t *  obj,
int  fd
Parameters
objThe object being checked.
fdThe file descriptor.
◆ rtems_rtl_rap_file_load()
bool rtems_rtl_rap_file_load ( rtems_rtl_obj_t *  obj,
int  fd
Parameters
objThe object to load.
obj->entry = (void*)(uintptr_t) ehdr.e_entry;
References rtems_rtl_rap_s::file, rtems_rtl_obj_s::ooffset, rtems_rtl_obj_cache_read(), and rtems_rtl_obj_caches().
◆ rtems_rtl_rap_file_sig()
rtems_rtl_loader_format_t* rtems_rtl_rap_file_sig ( void  )
Returns
rtems_rtl_loader_format_t* The format's signature.
◆ rtems_rtl_rap_file_unload()
bool rtems_rtl_rap_file_unload ( rtems_rtl_obj_t *  obj)
Parameters
objThe object to unload.
