rtems_rtl_rap_s Struct Reference
The RAP loader. More...
Collaboration diagram for rtems_rtl_rap_s:
Collaboration graph
[legend]
rtems_rtl_obj_cache_t * file
 The file cache for the RAP file. More...
rtems_rtl_obj_comp_t * decomp
 The decompression streamer. More...
uint32_t length
 The file length. More...
uint32_t version
 The RAP file version. More...
uint32_t compression
 The type of compression. More...
uint32_t checksum
 The checksum. More...
uint32_t machinetype
 The ELF machine type. More...
uint32_t datatype
 The ELF data type. More...
uint32_t class
 The ELF class. More...
uint32_t init
 The initialisation strtab offset. More...
uint32_t fini
 The finish strtab offset. More...
rtems_rtl_rap_section_t secs [RTEMS_RTL_RAP_SECS]
 The sections. More...
uint32_t symtab_size
 The symbol table size. More...
char * strtab
 The string table. More...
uint32_t strtab_size
 The string table size. More...
uint32_t relocs_size
 The relocation table size. More...
uint32_t symbols
 The number of symbols. More...
uint32_t strtable_size
 The size of section names and obj names. More...
uint32_t rpathlen
 The length of rpath. More...
char * strtable
 The detail string which resides in obj detail. More...
The RAP loader.
Field Documentation
◆ checksum
uint32_t rtems_rtl_rap_s::checksum
The checksum.
◆ class
uint32_t rtems_rtl_rap_s::class
The ELF class.
◆ compression
uint32_t rtems_rtl_rap_s::compression
◆ datatype
uint32_t rtems_rtl_rap_s::datatype
The ELF data type.
◆ decomp
rtems_rtl_obj_comp_t* rtems_rtl_rap_s::decomp
◆ file
rtems_rtl_obj_cache_t* rtems_rtl_rap_s::file
Referenced by rtems_rtl_rap_file_load().
◆ fini
uint32_t rtems_rtl_rap_s::fini
◆ init
uint32_t rtems_rtl_rap_s::init
◆ length
uint32_t rtems_rtl_rap_s::length
The file length.
◆ machinetype
uint32_t rtems_rtl_rap_s::machinetype
◆ relocs_size
uint32_t rtems_rtl_rap_s::relocs_size
◆ rpathlen
uint32_t rtems_rtl_rap_s::rpathlen
◆ secs
rtems_rtl_rap_section_t rtems_rtl_rap_s::secs[RTEMS_RTL_RAP_SECS]
The sections.
◆ strtab
char* rtems_rtl_rap_s::strtab
The string table.
◆ strtab_size
uint32_t rtems_rtl_rap_s::strtab_size
◆ strtable
char* rtems_rtl_rap_s::strtable
◆ strtable_size
uint32_t rtems_rtl_rap_s::strtable_size
◆ symbols
uint32_t rtems_rtl_rap_s::symbols
◆ symtab_size
uint32_t rtems_rtl_rap_s::symtab_size
◆ version
uint32_t rtems_rtl_rap_s::version
