rtems_glue.c File Reference
#include <stdarg.h>
#include <rtems/libio.h>
#include <rtems/error.h>
#include <sys/types.h>
#include <sys/param.h>
#include <sys/domain.h>
#include <sys/mbuf.h>
#include <sys/socketvar.h>
#include <sys/socket.h>
#include <sys/sockio.h>
#include <sys/callout.h>
#include <sys/proc.h>
#include <sys/ioctl.h>
#include <net/if.h>
#include <net/route.h>
#include <netinet/in.h>
#include <vm/vm.h>
#include <arpa/inet.h>
#include <net/netisr.h>
#include "loop.h"
Include dependency graph for rtems_glue.c:
struct  newtask
void sysctl_register_all (void *arg)
uint32_t rtems_bsdnet_semaphore_release_recursive (void)
void rtems_bsdnet_semaphore_obtain_recursive (uint32_t nest_count)
void * malloc (size_t)
void free (void *)
void * rtems_bsdnet_malloc (size_t size, int type, int flags)
void rtems_bsdnet_free (void *addr, int type)
void rtems_set_udp_buffer_sizes (u_long, u_long)
void rtems_set_tcp_buffer_sizes (u_long, u_long)
void rtems_set_sb_efficiency (u_long)
void rtems_bsdnet_semaphore_obtain (void)
void rtems_bsdnet_semaphore_release (void)
int sbwait (struct sockbuf *sb)
void sowakeup (struct socket *so, struct sockbuf *sb)
int sb_lock (struct sockbuf *sb)
void wakeup (void *p)
int soconnsleep (struct socket *so)
void soconnwakeup (struct socket *so)
void rtems_bsdnet_schednetisr (int n)
rtems_id rtems_bsdnet_newproc (char *name, int stacksize, void(*entry)(void *), void *arg)
rtems_status_code rtems_bsdnet_event_receive (rtems_event_set event_in, rtems_option option_set, rtems_interval ticks, rtems_event_set *event_out)
unsigned long rtems_bsdnet_random (void)
void rtems_bsdnet_timeout (void(*ftn)(void *), void *arg, int ticks)
int hzto (struct timeval *tv)
void rtems_bsdnet_log (int priority, const char *fmt,...)
u_int in_cksum_hdr (const void *ip)
int rtems_bsdnet_rtrequest (int req, struct sockaddr *dst, struct sockaddr *gateway, struct sockaddr *netmask, int flags, struct rtentry **net_nrt)
int rtems_bsdnet_initialize_network (void)
void rtems_bsdnet_attach (struct rtems_bsdnet_ifconfig *ifp)
void rtems_bsdnet_detach (struct rtems_bsdnet_ifconfig *ifp)
int rtems_bsdnet_ifconfig (const char *ifname, uint32_t cmd, void *param)
int rtems_bsdnet_parse_driver_name (const struct rtems_bsdnet_ifconfig *config, char **namep)
 Splits a network interface name with interface configuration config into the unit name and number parts. More...
int m_mballoc (int nmb, int nowait)
int m_clalloc (int ncl, int nowait)
uint32_t nmbclusters = (128L * 1024L) / MCLBYTES
Semaphore_Control * the_networkSemaphore
int rtems_bsdnet_ticks_per_second
int rtems_bsdnet_microseconds_per_tick
struct callout * callfree = NULL
struct callout calltodo
int nfs_diskless_valid
struct in_addr rtems_bsdnet_log_host_address = {0}
struct in_addr rtems_bsdnet_bootp_server_address = {0}
char * rtems_bsdnet_bootp_boot_file_name = 0
char * rtems_bsdnet_bootp_server_name = 0
char * rtems_bsdnet_domain_name = 0
char * rtems_bsdnet_bootp_cmdline = 0
struct in_addr * rtems_bsdnet_nameserver = _rtems_bsdnet_nameserver
int rtems_bsdnet_nameserver_count = 0
struct in_addr * rtems_bsdnet_ntpserver = _rtems_bsdnet_ntpserver
int rtems_bsdnet_ntpserver_count = 0
int32_t rtems_bsdnet_timeoffset = 0
struct domain routedomain
struct domain inetdomain
int rtems_bsdnet_log_priority
◆ rtems_bsdnet_parse_driver_name()
int rtems_bsdnet_parse_driver_name ( const struct rtems_bsdnet_ifconfig *  config,
char **  namep
Memory for the unit name will be allocated from the heap and copied to namep. If namep is NULL nothing will be allocated and copied.
Returns the unit number or -1 on error.
