admin
rtems-admin.git
doxygen
builder
latest
rtems.git
libnetworking
sys
mbuf.h
1
2
* Copyright (c) 1982, 1986, 1988, 1993
3
* The Regents of the University of California. All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 3. Neither the name of the University nor the names of its contributors
14
* may be used to endorse or promote products derived from this software
15
* without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27
* SUCH DAMAGE.
28
29
* @(#)mbuf.h 8.5 (Berkeley) 2/19/95
30
* $FreeBSD: src/sys/sys/mbuf.h,v 1.169 2005/03/17 19:34:57 jmg Exp $
31
32
33
34
#ifndef _SYS_MBUF_H_
35
#define _SYS_MBUF_H_
36
37
#ifndef M_WAITOK
38
sys/malloc.h
39
#endif
40
41
42
* Mbufs are of a single size, MSIZE (machine/machparam.h), which
43
* includes overhead. An mbuf may add a single "mbuf cluster" of size
44
* MCLBYTES (also in machine/machparam.h), which has no additional overhead
45
* and is used instead of the internal data area; this is done when
46
* at least MINCLSIZE of data must be stored.
47
48
49
#define MLEN (MSIZE - sizeof(struct m_hdr))
/* normal data len */
50
#define MHLEN (MLEN - sizeof(struct pkthdr))
/* data len w/pkthdr */
51
#define MINCLSIZE (MHLEN + MLEN)
/* smallest amount to put in cluster */
52
#define M_MAXCOMPRESS (MHLEN / 2)
/* max amount to copy for compression */
53
54
55
* Macros for type conversion:
56
* mtod(m, t) -- Convert mbuf pointer to data pointer of correct type.
57
* dtom(x) -- Convert data pointer within mbuf to mbuf pointer (XXX).
58
* mtocl(x) -- Convert pointer within cluster to cluster index #
59
* cltom(x) -- Convert cluster # to ptr to beginning of cluster
60
61
#define mtod(m, t) ((t)((m)->m_data))
62
#define dtom(x) ((struct mbuf *)((intptr_t)(x) & ~(MSIZE-1)))
63
#define mtocl(x) (((uintptr_t)(x) - (uintptr_t)mbutl) >> MCLSHIFT)
64
#define cltom(x) ((caddr_t)((u_long)mbutl + ((u_long)(x) << MCLSHIFT)))
65
66
67
* Header present at the beginning of every mbuf.
68
69
struct
m_hdr
70
struct
mbuf
*mh_next;
/* next buffer in chain */
71
struct
mbuf
*mh_nextpkt;
/* next chain in queue/record */
72
caddr_t mh_data;
/* location of data */
73
int
mh_len;
/* amount of data in this mbuf */
74
int
mh_flags;
/* flags; see below */
75
short
mh_type;
/* type of data in this mbuf */
76
77
78
79
* Record/packet header in first mbuf of chain; valid only if M_PKTHDR is set.
80
81
struct
pkthdr
82
struct
ifnet
*rcvif;
/* rcv interface */
83
int32_t len;
/* total packet length */
84
85
86
87
* Description of external storage mapped into mbuf; valid only if M_EXT is set.
88
89
struct
m_ext
90
caddr_t ext_buf;
/* start of buffer */
91
void (*ext_free)
/* free routine if not the usual */
92
(caddr_t, u_int);
93
u_int ext_size;
/* size of buffer, for ext_free */
94
void (*ext_ref)
/* add a reference to the ext object */
95
(caddr_t, u_int);
96
97
98
99
* The core of the mbuf object along with some shortcut defines for
100
* practical purposes.
101
102
struct
mbuf
103
struct
m_hdr
m_hdr
104
union
105
struct
106
struct
pkthdr
MH_pkthdr;
/* M_PKTHDR set */
107
union
108
struct
m_ext
MH_ext;
/* M_EXT set */
109
char
MH_databuf[MHLEN];
110
} MH_dat;
111
} MH;
112
char
M_databuf[MLEN];
/* !M_PKTHDR, !M_EXT */
113
} M_dat;
114
115
#define m_next m_hdr.mh_next
116
#define m_len m_hdr.mh_len
117
#define m_data m_hdr.mh_data
118
#define m_type m_hdr.mh_type
119
#define m_flags m_hdr.mh_flags
120
#define m_nextpkt m_hdr.mh_nextpkt
121
#define m_act m_nextpkt
122
#define m_pkthdr M_dat.MH.MH_pkthdr
123
#define m_ext M_dat.MH.MH_dat.MH_ext
124
#define m_pktdat M_dat.MH.MH_dat.MH_databuf
125
#define m_dat M_dat.M_databuf
126
127
128
* mbuf flags.
129
130
#define M_EXT 0x0001
/* has associated external storage */
131
#define M_PKTHDR 0x0002
/* start of record */
132
#define M_EOR 0x0004
/* end of record */
133
#define M_PROTO1 0x0008
/* protocol-specific */
134
135
136
* mbuf pkthdr flags (also stored in m_flags).
137
138
#define M_BCAST 0x0100
/* send/received as link-level broadcast */
139
#define M_MCAST 0x0200
/* send/received as link-level multicast */
140
141
142
* Flags copied when copying m_pkthdr.
143
144
#define M_COPYFLAGS (M_PKTHDR|M_EOR|M_PROTO1|M_BCAST|M_MCAST)
145
146
147
* mbuf types.
148
149
#define MT_FREE 0
/* should be on free list */
150
#define MT_DATA 1
/* dynamic (data) allocation */
151
#define MT_HEADER 2
/* packet header */
152
#define MT_SOCKET 3
/* socket structure */
153
#define MT_PCB 4
/* protocol control block */
154
#define MT_RTABLE 5
/* routing tables */
155
#define MT_HTABLE 6
/* IMP host tables */
156
#define MT_ATABLE 7
/* address resolution tables */
157
#define MT_SONAME 8
/* socket name */
158
#define MT_SOOPTS 10
/* socket options */
159
#define MT_FTABLE 11
/* fragment reassembly header */
160
#define MT_RIGHTS 12
/* access rights */
161
#define MT_IFADDR 13
/* interface address */
162
#define MT_CONTROL 14
/* extra-data protocol message */
163
#define MT_OOBDATA 15
/* expedited data */
164
165
166
* General mbuf allocator statistics structure.
167
168
struct
mbstat {
169
u_long m_mbufs;
/* mbufs obtained from page pool */
170
u_long m_clusters;
/* clusters obtained from page pool */
171
u_long m_spare;
/* spare field */
172
u_long m_clfree;
/* free clusters */
173
u_long m_drops;
/* times failed to find space */
174
u_long m_wait;
/* times waited for space */
175
u_long m_drain;
/* times drained protocols for space */
176
u_short m_mtypes[256];
/* type specific mbuf allocations */
177
178
179
180
/* flags to m_get/MGET */
181
#define M_DONTWAIT M_NOWAIT
182
#define M_WAIT M_WAITOK
183
184
/* Freelists:
185
186
* Normal mbuf clusters are normally treated as character arrays
187
* after allocation, but use the first word of the buffer as a free list
188
* pointer while on the free list.
189
190
union
mcluster
191
union
mcluster
*mcl_next;
192
char
mcl_buf[MCLBYTES];
193
194
195
196
* mbuf utility macros:
197
198
* MBUFLOCK(code)
199
* prevents a section of code from from being interrupted by network
200
* drivers.
201
202
#define MBUFLOCK(code) \
203
{ int ms = splimp(); \
204
{ code } \
205
splx(ms); \
206
207
208
209
* mbuf allocation/deallocation macros:
210
211
* MGET(struct mbuf *m, int how, int type)
212
* allocates an mbuf and initializes it to contain internal data.
213
214
* MGETHDR(struct mbuf *m, int how, int type)
215
* allocates an mbuf and initializes it to contain a packet header
216
* and internal data.
217
218
#define MGET(m, how, type) { \
219
int _ms = splimp(); \
220
if (mmbfree == 0) \
221
(void)m_mballoc(1, (how)); \
222
if (((m) = mmbfree) != 0) { \
223
mmbfree = (m)->m_next; \
224
mbstat.m_mtypes[MT_FREE]--; \
225
(m)->m_type = (type); \
226
mbstat.m_mtypes[type]++; \
227
(m)->m_next = (struct mbuf *)NULL; \
228
(m)->m_nextpkt = (struct mbuf *)NULL; \
229
(m)->m_data = (m)->m_dat; \
230
(m)->m_flags = 0; \
231
splx(_ms); \
232
} else { \
233
splx(_ms); \
234
(m) = m_retry((how), (type)); \
235
236
237
238
#define MGETHDR(m, how, type) { \
239
240
if (mmbfree == 0) \
241
242
243
244
245
246
247
248
249
(m)->m_data = (m)->m_pktdat; \
250
(m)->m_flags = M_PKTHDR; \
251
splx(_ms); \
252
} else { \
253
splx(_ms); \
254
(m) = m_retryhdr((how), (type)); \
255
256
257
258
259
* Mbuf cluster macros.
260
* MCLALLOC(caddr_t p, int how) allocates an mbuf cluster.
261
* MCLGET adds such clusters to a normal mbuf;
262
* the flag M_EXT is set upon success.
263
* MCLFREE releases a reference to a cluster allocated by MCLALLOC,
264
* freeing the cluster if the reference count has reached 0.
265
266
#define MCLALLOC(p, how) \
267
MBUFLOCK( \
268
if (mclfree == 0) \
269
(void)m_clalloc(1, (how)); \
270
if (((p) = (caddr_t)mclfree) != 0) { \
271
++mclrefcnt[mtocl(p)]; \
272
mbstat.m_clfree--; \
273
mclfree = ((union mcluster *)(p))->mcl_next; \
274
275
276
277
#define MCLGET(m, how) \
278
{ MCLALLOC((m)->m_ext.ext_buf, (how)); \
279
if ((m)->m_ext.ext_buf != NULL) { \
280
(m)->m_data = (m)->m_ext.ext_buf; \
281
(m)->m_flags |= M_EXT; \
282
(m)->m_ext.ext_free = NULL; \
283
(m)->m_ext.ext_ref = NULL; \
284
(m)->m_ext.ext_size = MCLBYTES; \
285
286
287
288
#define MCLFREE(p) \
289
MBUFLOCK ( \
290
if (--mclrefcnt[mtocl(p)] == 0) { \
291
((union mcluster *)(p))->mcl_next = mclfree; \
292
mclfree = (union mcluster *)(p); \
293
mbstat.m_clfree++; \
294
295
296
297
298
* MFREE(struct mbuf *m, struct mbuf *n)
299
* Free a single mbuf and associated external storage.
300
* Place the successor, if any, in n.
301
302
#define MFREE(m, n) \
303
MBUFLOCK( \
304
mbstat.m_mtypes[(m)->m_type]--; \
305
if ((m)->m_flags & M_EXT) { \
306
if ((m)->m_ext.ext_free) \
307
(*((m)->m_ext.ext_free))((m)->m_ext.ext_buf, \
308
(m)->m_ext.ext_size); \
309
else { \
310
char *p = (m)->m_ext.ext_buf; \
311
312
313
314
315
316
317
318
(n) = (m)->m_next; \
319
(m)->m_type = MT_FREE; \
320
mbstat.m_mtypes[MT_FREE]++; \
321
(m)->m_next = mmbfree; \
322
mmbfree = (m); \
323
324
325
326
* Copy mbuf pkthdr from from to to.
327
* from must have M_PKTHDR set, and to must be empty.
328
329
#define M_COPY_PKTHDR(to, from) { \
330
(to)->m_pkthdr = (from)->m_pkthdr; \
331
(to)->m_flags = (from)->m_flags & M_COPYFLAGS; \
332
(to)->m_data = (to)->m_pktdat; \
333
334
335
336
* Set the m_data pointer of a newly-allocated mbuf (m_get/MGET) to place
337
* an object of the specified size at the end of the mbuf, longword aligned.
338
339
#define M_ALIGN(m, len) do { \
340
(m)->m_data += (MLEN - (len)) & ~(sizeof(long) - 1); \
341
} while (0)
342
343
344
* As above, for mbufs allocated with m_gethdr/MGETHDR
345
* or initialized by M_COPY_PKTHDR.
346
347
#define MH_ALIGN(m, len) do { \
348
(m)->m_data += (MHLEN - (len)) & ~(sizeof(long) - 1); \
349
} while (0)
350
351
352
* Compute the amount of space available
353
* before the current start of data in an mbuf.
354
355
#define M_LEADINGSPACE(m) \
356
((m)->m_flags & M_EXT ?
/* (m)->m_data - (m)->m_ext.ext_buf */
0 : \
357
(m)->m_flags & M_PKTHDR ? (m)->m_data - (m)->m_pktdat : \
358
(m)->m_data - (m)->m_dat)
359
360
361
362
* after the end of data in an mbuf.
363
364
#define M_TRAILINGSPACE(m) \
365
((m)->m_flags & M_EXT ? (m)->m_ext.ext_buf + (m)->m_ext.ext_size - \
366
((m)->m_data + (m)->m_len) : \
367
&(m)->m_dat[MLEN] - ((m)->m_data + (m)->m_len))
368
369
370
* Arrange to prepend space of size plen to mbuf m.
371
* If a new mbuf must be allocated, how specifies whether to wait.
372
* If how is M_DONTWAIT and allocation fails, the original mbuf chain
373
* is freed and m is set to NULL.
374
375
#define M_PREPEND(m, plen, how) { \
376
if (M_LEADINGSPACE(m) >= (plen)) { \
377
(m)->m_data -= (plen); \
378
(m)->m_len += (plen); \
379
} else \
380
(m) = m_prepend((m), (plen), (how)); \
381
if ((m) && (m)->m_flags & M_PKTHDR) \
382
(m)->m_pkthdr.len += (plen); \
383
384
385
386
* Change mbuf to new type.
387
* This is a relatively expensive operation and should be avoided.
388
389
#define MCHTYPE(m, t) { \
390
MBUFLOCK(mbstat.m_mtypes[(m)->m_type]--; mbstat.m_mtypes[t]++;) \
391
(m)->m_type = t;\
392
393
394
/* Length to m_copy to copy all. */
395
#define M_COPYALL (uint32_t)1000000000L
396
397
/* Compatibility with 4.3. */
398
#define m_copy(m, o, l) m_copym((m), (o), (l), M_DONTWAIT)
399
400
#ifdef _KERNEL
401
extern
struct
mbuf
*mbutl;
/* virtual address of mclusters */
402
extern
char
*mclrefcnt;
/* cluster reference counts */
403
extern
struct
mbstat mbstat;
404
extern
uint32_t nmbclusters;
405
extern
uint32_t nmbufs;
406
extern
struct
mbuf
*mmbfree;
407
extern
union
mcluster
*mclfree;
408
extern
int
max_linkhdr;
/* largest link-level header */
409
extern
int
max_protohdr;
/* largest protocol header */
410
extern
int
max_hdr;
/* largest link+protocol header */
411
extern
int
max_datalen;
/* MHLEN - max_hdr */
412
413
struct
mbuf
*m_copym(
struct
mbuf
int
, uint32_t,
int
414
struct
mbuf
*m_copypacket(
struct
mbuf
int
415
struct
mbuf
*m_devget(
char
int
int
struct
ifnet
416
void
(*copy)(
char
*, caddr_t, u_int));
417
struct
mbuf
*m_free(
struct
mbuf
418
struct
mbuf
*m_get(
int
int
419
struct
mbuf
*m_getclr(
int
int
420
struct
mbuf
*m_gethdr(
int
int
421
struct
mbuf
*m_prepend(
struct
mbuf
int
int
422
struct
mbuf
*m_pullup(
struct
mbuf
int
423
struct
mbuf
*m_retry(
int
int
424
struct
mbuf
*m_retryhdr(
int
int
425
struct
mbuf
*m_split(
struct
mbuf
int
int
426
void
m_adj(
struct
mbuf
int
427
void
m_cat(
struct
mbuf
struct
mbuf
428
int
m_mballoc(
int
int
429
int
m_clalloc(
int
int
430
int
m_copyback(
struct
mbuf
int
int
, caddr_t);
431
int
m_copydata(
const
struct
mbuf
int
int
, caddr_t);
432
void
m_freem(
struct
mbuf
433
void
m_reclaim(
void
434
435
#endif
/* _KERNEL */
436
437
#endif
/* !_SYS_MBUF_H_ */
mcluster
Definition:
mbuf.h:191
pkthdr
Definition:
mbuf.h:82
malloc.h
ifnet
Definition:
if_var.h:99
m_ext
Definition:
mbuf.h:90
mbuf
Definition:
mbuf.h:103
m_hdr
Definition:
mbuf.h:70
