RTEMS File Systems Inode RoutinesThese functions manage inodes in the RFS file system. More...
#include <inttypes.h>
#include <rtems/rfs/rtems-rfs-block.h>
#include <rtems/rfs/rtems-rfs-inode.h>
#include <rtems/rfs/rtems-rfs-dir.h>
Include dependency graph for rtems-rfs-inode.c:
int rtems_rfs_inode_alloc (rtems_rfs_file_system *fs, rtems_rfs_bitmap_bit goal, rtems_rfs_ino *ino)
 Allocate an inode number and return it. More...
int rtems_rfs_inode_free (rtems_rfs_file_system *fs, rtems_rfs_ino ino)
 Free an inode. More...
int rtems_rfs_inode_open (rtems_rfs_file_system *fs, rtems_rfs_ino ino, rtems_rfs_inode_handle *handle, bool load)
 Open the inode handle. More...
int rtems_rfs_inode_close (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle)
 The close inode handle. More...
int rtems_rfs_inode_load (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle)
 Load the inode into memory. More...
int rtems_rfs_inode_unload (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle, bool update_ctime)
 Unload the inode from memory. More...
int rtems_rfs_inode_create (rtems_rfs_file_system *fs, rtems_rfs_ino parent, const char *name, size_t length, uint16_t mode, uint16_t links, uid_t uid, gid_t gid, rtems_rfs_ino *ino)
 Create an inode allocating, initialising and adding an entry to the parent directory. More...
int rtems_rfs_inode_delete (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle)
 Delete the inode eraseing it and release the buffer to commit the write. More...
int rtems_rfs_inode_initialise (rtems_rfs_inode_handle *handle, uint16_t links, uint16_t mode, uid_t uid, gid_t gid)
 Initialise a new inode. More...
int rtems_rfs_inode_time_stamp_now (rtems_rfs_inode_handle *handle, bool atime, bool mtime)
 Time stamp the inode with the current time. More...
rtems_rfs_pos rtems_rfs_inode_get_size (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle)
 Calculate the size of data attached to the inode. More...
An inode is part of a block that reside after the bitmaps in the group.
◆ rtems_rfs_inode_alloc()
int rtems_rfs_inode_alloc ( rtems_rfs_file_system *  fs,
rtems_rfs_ino *  ino
Parameters
[in]fsis the file system data.
[out]inowill contain the ino.
Return values
0Successful operation.
error_codeAn error occurred.
◆ rtems_rfs_inode_close()
int rtems_rfs_inode_close ( rtems_rfs_file_system *  fs,
rtems_rfs_inode_handle *  handle
All opened inodes need to be closed.
Parameters
[in]fsis the file system.
[in]handleis the handle to close.
Return values
◆ rtems_rfs_inode_create()
int rtems_rfs_inode_create ( rtems_rfs_file_system *  fs,
const char *  name,
size_t  length,
uint16_t  mode,
uint16_t  links,
uid_t  uid,
gid_t  gid,
rtems_rfs_ino *  ino
Parameters
[in]parentis the parent inode number to add the directory entry to.
[in]nameis a pointer to the name of the directory entryinode to create.
◆ rtems_rfs_inode_delete()
int rtems_rfs_inode_delete ( rtems_rfs_file_system *  fs,
You need to load the inode again if you wish to use it again.
Parameters
[in]handleis the inode handle to erase.
Return values
◆ rtems_rfs_inode_free()
int rtems_rfs_inode_free ( rtems_rfs_file_system *  fs,
rtems_rfs_ino  ino
Free an inode.
Parameters
[in]inois the ino too free.
Return values
◆ rtems_rfs_inode_get_size()
rtems_rfs_pos rtems_rfs_inode_get_size ( rtems_rfs_file_system *  fs,
Parameters
[in]handleis the inode handle.
Return values
sizeThe data size in bytes in the block map attched to the inode.
◆ rtems_rfs_inode_initialise()
int rtems_rfs_inode_initialise ( rtems_rfs_inode_handle *  handle,
uint16_t  links,
uint16_t  mode,
uid_t  uid,
gid_t  gid
Parameters
[in]handleis the inode handle to initialise.
[in]linksare the number of links to the inode.
[in]modeis the inode mode.
[in]uidis the user id.
[in]gidis the group id.
Return values
◆ rtems_rfs_inode_load()
int rtems_rfs_inode_load ( rtems_rfs_file_system *  fs,
Parameters
[in]handleis the inode handle to load.
Return values
◆ rtems_rfs_inode_open()
int rtems_rfs_inode_open ( rtems_rfs_file_system *  fs,
rtems_rfs_ino  ino,
bool  load
This reads the inode into the buffer and sets the data pointer. All data is in media byte order and needs to be accessed via the supporting calls.
Parameters
[in]inois the inode number.
[in]handleis the handle to the inode we are opening.
[in]loadIf true load the inode into memory from the media.
Return values
◆ rtems_rfs_inode_time_stamp_now()
int rtems_rfs_inode_time_stamp_now ( rtems_rfs_inode_handle *  handle,
bool  atime,
bool  mtime
The ctime field is hanlded automatically.
Parameters
[in]atimeUpdate the atime field.
[in]mtimeUPdate the mtime field.
Return values
ENXIONo inode is loaded.
◆ rtems_rfs_inode_unload()
int rtems_rfs_inode_unload ( rtems_rfs_file_system *  fs,
bool  update_ctime
Parameters
[in]handleis the inode handle to unload.
[in]update_ctimeUpdate the ctime field of the inode.
Return values
