RTEMS File System Data. More...
#include <rtems/rfs/rtems-rfs-group.h>
Include dependency graph for rtems-rfs-file-system.h:
struct  _rtems_rfs_file_system
 RFS File System data. More...
#define RTEMS_RFS_SB_OFFSET_MAGIC   (0)
 Superblock offsets and values.
#define RTEMS_RFS_SB_MAGIC   (0x28092001)
#define RTEMS_RFS_SB_OFFSET_VERSION   (RTEMS_RFS_SB_OFFSET_MAGIC + 4)
#define RTEMS_RFS_SB_OFFSET_BLOCK_SIZE   (RTEMS_RFS_SB_OFFSET_VERSION + 4)
#define RTEMS_RFS_SB_OFFSET_BLOCKS   (RTEMS_RFS_SB_OFFSET_BLOCK_SIZE + 4)
#define RTEMS_RFS_SB_OFFSET_BAD_BLOCKS   (RTEMS_RFS_SB_OFFSET_BLOCKS + 4)
#define RTEMS_RFS_SB_OFFSET_MAX_NAME_LENGTH   (RTEMS_RFS_SB_OFFSET_BAD_BLOCKS + 4)
#define RTEMS_RFS_SB_OFFSET_GROUPS   (RTEMS_RFS_SB_OFFSET_MAX_NAME_LENGTH + 4)
#define RTEMS_RFS_SB_OFFSET_GROUP_BLOCKS   (RTEMS_RFS_SB_OFFSET_GROUPS + 4)
#define RTEMS_RFS_SB_OFFSET_GROUP_INODES   (RTEMS_RFS_SB_OFFSET_GROUP_BLOCKS + 4)
#define RTEMS_RFS_SB_OFFSET_INODE_SIZE   (RTEMS_RFS_SB_OFFSET_GROUP_INODES + 4)
#define RTEMS_RFS_VERSION   (0x00000000)
 RFS Version Number.
#define RTEMS_RFS_VERSION_MASK   INT32_C(0x00000000)
 RFS Version Number Mask. More...
#define RTEMS_RFS_ROOT_INO   (1)
 The root inode number. More...
#define RTEMS_RFS_EMPTY_INO   (0)
 Empty inode number.
#define RTEMS_RFS_INODE_BLOCKS   (5)
 The number of blocks in the inode. More...
#define RTEMS_RFS_INODE_OVERHEAD_PERCENTAGE   (1)
 The inode overhead is the percentage of space reserved for inodes. More...
#define RTEMS_RFS_SUPERBLOCK_SIZE   (1)
 Number of blocks in the superblock. More...
#define RTEMS_RFS_FS_MAX_HELD_BUFFERS   (5)
 The maximum number of buffers held by the file system at any one time.
#define RTEMS_RFS_FS_BITMAPS_HOLD   (1 << 0)
 Flags to control the file system. More...
#define RTEMS_RFS_FS_NO_LOCAL_CACHE   (1 << 1)
 Do not cache the buffers and release directly to the buffer support layer. More...
#define RTEMS_RFS_FS_FORCE_OPEN   (1 << 2)
 Force open and ignore any errors. More...
#define RTEMS_RFS_FS_READ_ONLY   (1 << 3)
 Make the mount read-only. More...
#define rtems_rfs_fs_flags(_f)   ((_f)->flags)
 Return the flags. More...
#define rtems_rfs_fs_release_bitmaps(_f)   (!((_f)->flags & RTEMS_RFS_FS_BITMAPS_HOLD))
 Should bitmap buffers be released when finished ? More...
#define rtems_rfs_fs_no_local_cache(_f)   ((_f)->flags & RTEMS_RFS_FS_NO_LOCAL_CACHE)
 Are the buffers locally cache or released back to the buffering layer ? More...
#define rtems_rfs_fs_device(_fs)   ((_fs)->device)
 The disk device number. More...
#define rtems_rfs_fs_blocks(_fs)   ((_fs)->blocks)
 The size of the disk in blocks. More...
#define rtems_rfs_fs_block_size(_fs)   ((_fs)->block_size)
 The block size. More...
#define rtems_rfs_fs_inodes(_fs)   ((_fs)->inodes)
 The number of inodes. More...
#define rtems_rfs_fs_block(_fs, _grp, _blk)   ((((_fs)->group_blocks) * (_grp)) + (_blk) + 1)
 Calculate a block in the file system given the group and the block within the group. More...
#define rtems_rfs_fs_media_blocks(_fs)   ((_fs)->media_size)
 The media size of the disk in media size blocks. More...
#define rtems_rfs_fs_media_block_size(_fs)   (1)
 The media block size. More...
#define rtems_rfs_fs_max_name(_fs)   ((_fs)->max_name_length)
 The maximum length of a name supported by the file system.
#define rtems_rfs_fs_max_block_map_blocks(_fs)   ((_fs)->block_map_doubly_blocks)
 Return the maximum number of blocks in a block map. More...
#define rtems_rfs_fs_user(_fs)   ((_fs)->user)
 Return the user pointer.
typedef uint64_t rtems_rfs_pos
 Absolute position. More...
typedef int64_t rtems_rfs_pos_rel
 Relative position. More...
uint64_t rtems_rfs_fs_size (rtems_rfs_file_system *fs)
 Return the size of the disk in bytes. More...
uint64_t rtems_rfs_fs_media_size (rtems_rfs_file_system *fs)
 The size of the disk in bytes calculated from the media parameters. More...
int rtems_rfs_fs_open (const char *name, void *user, uint32_t flags, uint32_t max_held_buffers, rtems_rfs_file_system **fs)
 Open the file system given a file path. More...
int rtems_rfs_fs_close (rtems_rfs_file_system *fs)
 Close the file system. More...
This file defines the file system data.
◆ RTEMS_RFS_FS_BITMAPS_HOLD
Do not release bitmaps when finished. Default is off so they are released.
◆ rtems_rfs_fs_block
#define rtems_rfs_fs_block (   _fs,
  _grp,
  _blk
Parameters
[in]_fsis a pointer to the file system.
[in]_grpis the group.
[in]_blkis the block within the group.
Returns
The absolute block number.
◆ rtems_rfs_fs_block_size
#define rtems_rfs_fs_block_size (   _fs)    ((_fs)->block_size)
The block size.
Parameters
◆ rtems_rfs_fs_blocks
#define rtems_rfs_fs_blocks (   _fs)    ((_fs)->blocks)
Parameters
◆ rtems_rfs_fs_device
#define rtems_rfs_fs_device (   _fs)    ((_fs)->device)
Parameters
◆ rtems_rfs_fs_flags
#define rtems_rfs_fs_flags (   _f)    ((_f)->flags)
Return the flags.
Parameters
◆ RTEMS_RFS_FS_FORCE_OPEN
◆ rtems_rfs_fs_inodes
#define rtems_rfs_fs_inodes (   _fs)    ((_fs)->inodes)
Parameters
◆ rtems_rfs_fs_max_block_map_blocks
#define rtems_rfs_fs_max_block_map_blocks (   _fs)    ((_fs)->block_map_doubly_blocks)
Returns
uint32_t The maximum number of blocks possible.
◆ rtems_rfs_fs_media_block_size
#define rtems_rfs_fs_media_block_size (   _fs)    (1)
This is the size of a block on disk. For a device I/O this value is 1.
Parameters
◆ rtems_rfs_fs_media_blocks
#define rtems_rfs_fs_media_blocks (   _fs)    ((_fs)->media_size)
Parameters
◆ RTEMS_RFS_FS_NO_LOCAL_CACHE
The default is to hold buffers.
◆ rtems_rfs_fs_no_local_cache
#define rtems_rfs_fs_no_local_cache (   _f)    ((_f)->flags & RTEMS_RFS_FS_NO_LOCAL_CACHE)
Parameters
◆ RTEMS_RFS_FS_READ_ONLY
Currently not supported.
◆ rtems_rfs_fs_release_bitmaps
#define rtems_rfs_fs_release_bitmaps (   _f)    (!((_f)->flags & RTEMS_RFS_FS_BITMAPS_HOLD))
Parameters
◆ RTEMS_RFS_INODE_BLOCKS
This number effects the size of the inode and that effects the overhead of the inode tables in a group.
◆ RTEMS_RFS_INODE_OVERHEAD_PERCENTAGE
It is calculated as the percentage number of blocks in a group. The number of blocks in a group is the number of bits a block can hold.
◆ RTEMS_RFS_ROOT_INO
Do not use 0 as this has special meaning in some Unix operating systems.
◆ RTEMS_RFS_SUPERBLOCK_SIZE
Yes I know it is a superblock and not superblocks but if for any reason this needs to change it is handled.
◆ RTEMS_RFS_VERSION_MASK
The mask determines which bits of the version number indicate compatility issues.
Typedef Documentation
◆ rtems_rfs_pos
Absolute position.
Make a 64bit value.
◆ rtems_rfs_pos_rel
Relative position.
Make a 64bit value.
◆ rtems_rfs_fs_close()
int rtems_rfs_fs_close ( rtems_rfs_file_system *  fs)
Parameters
[in]fsis the file system data.
Return values
0Successful operation.
-1Error. See errno
References rtems_rfs_trace().
Referenced by rtems_rfs_rtems_shutdown().
◆ rtems_rfs_fs_media_size()
uint64_t rtems_rfs_fs_media_size ( rtems_rfs_file_system *  fs)
Parameters
[in]fsis a pointer to the file system.
Returns
uint64_t The size of the disk in bytes.
◆ rtems_rfs_fs_open()
int rtems_rfs_fs_open ( const char *  name,
void *  user,
uint32_t  flags,
rtems_rfs_file_system **  fs
Parameters
[in]nameis a pointer to the device to open.
[in]fsis the file system data filled in by this call.
[in]useris a pointer to the user data.
[in]flagsis a initial set of user flags for the file system.
[in]max_held_buffersis the maximum number of buffers the RFS holds.
Return values
-1Error. See errno
◆ rtems_rfs_fs_size()
uint64_t rtems_rfs_fs_size ( rtems_rfs_file_system *  fs)
Parameters
Returns
