Macros | Functions
RTEMS File System Directory Support. More...
#include <dirent.h>
#include <rtems/libio_.h>
#include <rtems/rfs/rtems-rfs-data.h>
#include <rtems/rfs/rtems-rfs-inode.h>
Include dependency graph for rtems-rfs-dir.h:
#define RTEMS_RFS_DIR_ENTRY_INO   (0)
 Define the offsets of the fields of a directory entry. More...
#define RTEMS_RFS_DIR_ENTRY_HASH   (4)
 The hash offset in a directory entry. More...
#define RTEMS_RFS_DIR_ENTRY_LEN   (8)
 The length offset in a directory entry. More...
#define RTEMS_RFS_DIR_ENTRY_SIZE   (4 + 4 + 2)
 The length of the directory entry header.
#define RTEMS_RFS_DIR_ENTRY_EMPTY   (0xffff)
 The length when the remainder of the directory block is empty.
#define rtems_rfs_dir_entry_hash(_e)   rtems_rfs_read_u32 (_e + RTEMS_RFS_DIR_ENTRY_HASH)
 Return the hash of the entry. More...
#define rtems_rfs_dir_set_entry_hash(_e, _h)   rtems_rfs_write_u32 (_e + RTEMS_RFS_DIR_ENTRY_HASH, _h)
 Set the hash of the entry. More...
#define rtems_rfs_dir_entry_ino(_e)   rtems_rfs_read_u32 (_e + RTEMS_RFS_DIR_ENTRY_INO)
 Return the ino of the entry. More...
#define rtems_rfs_dir_set_entry_ino(_e, _i)   rtems_rfs_write_u32 (_e + RTEMS_RFS_DIR_ENTRY_INO, _i)
 Set the ino of the entry. More...
#define rtems_rfs_dir_entry_length(_e)   rtems_rfs_read_u16 (_e + RTEMS_RFS_DIR_ENTRY_LEN)
 Return the length of the entry. More...
#define rtems_rfs_dir_set_entry_length(_e, _l)   rtems_rfs_write_u16 (_e + RTEMS_RFS_DIR_ENTRY_LEN, _l)
 Set the length of the entry. More...
int rtems_rfs_dir_lookup_ino (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *inode, const char *name, int length, rtems_rfs_ino *ino, uint32_t *offset)
 Look up a directory entry in the directory pointed to by the inode. More...
int rtems_rfs_dir_add_entry (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *dir, const char *name, size_t length, rtems_rfs_ino ino)
 Add an entry to the directory returing the inode number allocated to the entry. More...
int rtems_rfs_dir_del_entry (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *dir, rtems_rfs_ino ino, uint32_t offset)
 Del an entry from the directory using an inode number as a key. More...
int rtems_rfs_dir_read (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *dir, rtems_rfs_pos_rel offset, struct dirent *dirent, size_t *length)
 Read the directory entry from offset into the directory entry buffer and return the length of space this entry uses in the directory table. More...
int rtems_rfs_dir_empty (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *dir)
 Check if the directory is empty. More...
This file provides the directory support functions.
◆ RTEMS_RFS_DIR_ENTRY_HASH
The hash is 32bits. We need at least 16bits and given the length and ino field are 4 the extra 2 bytes is not a big overhead.
◆ rtems_rfs_dir_entry_hash
#define rtems_rfs_dir_entry_hash (   _e)    rtems_rfs_read_u32 (_e + RTEMS_RFS_DIR_ENTRY_HASH)
Parameters
[in]_eis a pointer to the directory entry.
Return values
hashThe uint32_t hash of the entry.
◆ RTEMS_RFS_DIR_ENTRY_INO
The ino offset in a directory entry.
◆ rtems_rfs_dir_entry_ino
#define rtems_rfs_dir_entry_ino (   _e)    rtems_rfs_read_u32 (_e + RTEMS_RFS_DIR_ENTRY_INO)
Parameters
Return values
inoThe ino of the entry.
◆ RTEMS_RFS_DIR_ENTRY_LEN
◆ rtems_rfs_dir_entry_length
#define rtems_rfs_dir_entry_length (   _e)    rtems_rfs_read_u16 (_e + RTEMS_RFS_DIR_ENTRY_LEN)
Parameters
[in]_ePointer to the directory entry.
Return values
lengthThe length of the entry.
◆ rtems_rfs_dir_set_entry_hash
#define rtems_rfs_dir_set_entry_hash (   _e,
  _h
Parameters
[in]_his the hash of the entry.
◆ rtems_rfs_dir_set_entry_ino
#define rtems_rfs_dir_set_entry_ino (   _e,
  _i
Parameters
[in]_iis the ino of the entry.
◆ rtems_rfs_dir_set_entry_length
#define rtems_rfs_dir_set_entry_length (   _e,
  _l
Parameters
[in]_lis the length.
◆ rtems_rfs_dir_add_entry()
int rtems_rfs_dir_add_entry ( rtems_rfs_file_system *  fs,
rtems_rfs_inode_handle *  dir,
const char *  name,
size_t  length,
rtems_rfs_ino  ino
Parameters
[in]fsis the file system data.
[in]diris a pointer to the directory inode the entry is to be added too.
[in]nameis a pointer to the name of the entry to be added.
[in]lengthis the length of the name excluding a terminating 0.
[in]inois the ino of the entry.
Return values
0Successful operation.
error_codeAn error occurred.
◆ rtems_rfs_dir_del_entry()
int rtems_rfs_dir_del_entry ( rtems_rfs_file_system *  fs,
rtems_rfs_ino  ino,
uint32_t  offset
Parameters
[in]diris a pointer to the directory inode the entry is to be deleted from.
[in]offsetis the offset in the directory of the entry to delete. If 0 search from the start for the ino.
Return values
◆ rtems_rfs_dir_empty()
int rtems_rfs_dir_empty ( rtems_rfs_file_system *  fs,
The current and parent directory entries are ignored.
Parameters
[in]diris a pointer to the directory inode to check.
Return values
◆ rtems_rfs_dir_lookup_ino()
int rtems_rfs_dir_lookup_ino ( rtems_rfs_file_system *  fs,
rtems_rfs_inode_handle *  inode,
const char *  name,
int  length,
rtems_rfs_ino *  ino,
uint32_t *  offset
The look up is local to this directory. No need to decend.
Parameters
[in]fsis the file system.
[in]inodeis a pointer to the inode of the directory to search.
[in]nameis a pointer to the name to look up. The name may not be nul terminated.
[in]lengthis the length of the name.
[out]inowill be filled in with the inode number if there is no error.
[in]offsetis the offset in the directory for the entry.
Return values
◆ rtems_rfs_dir_read()
int rtems_rfs_dir_read ( rtems_rfs_file_system *  fs,
struct dirent *  dirent,
size_t *  length
Parameters
[in]diris a pointer to the direct inode handler.
[in]offsetis the offset in the directory to read from.
[in]direntis a ointer to the dirent structure the entry is written into.
[out]lengthwill contain the length this entry takes in the directory.
Return values
