| file | __assert.c |
| | Evaluate Assertion.
| file | __getpid.c |
| | Get Process Id.
| file | __gettod.c |
| | Get the Date and Time.
| file | __times.c |
| | Get Process Times.
| file | __usrenv.c |
| | RTEMS File System Location Support.
| file | _calloc_r.c |
| | Allocate Space for Array in Memory.
| file | _free_r.c |
| | Allocate and Free Dynamic Memory.
| file | _malloc_r.c |
| file | _realloc_r.c |
| | _realloc_r Implementation
| file | _rename_r.c |
| | Rename a File.
| file | access.c |
| | access() - POSIX 1003.1b 5.6.3 - File Accessibility
| file | assoclocalbyname.c |
| | RTEMS Associate Local by Name.
| file | assoclocalbyremote.c |
| | RTEMS Associate Local by Remote.
| file | assoclocalbyremotebitfield.c |
| file | assocnamebad.c |
| | RTEMS Associate Bad Name.
| file | assocnamebylocal.c |
| | RTEMS Associate Name by Local.
| file | assocnamebylocalbitfield.c |
| | RTEMS Associate Name by Local Bitfield.
| file | assocnamebyremote.c |
| | RTEMS Associate Name by Remote.
| file | assocnamebyremotebitfield.c |
| | RTEMS Associate Name by Remote Bitfield.
| file | assocptrbylocal.c |
| | RTEMS Associate Pointer by Local.
| file | assocptrbyname.c |
| | RTEMS Associate Pointer by Name.
| file | assocptrbyremote.c |
| | RTEMS Associate Pointer by Remote.
| file | assocremotebylocal.c |
| file | assocremotebylocalbitfield.c |
| | RTEMS Assoc Routines.
| file | assocremotebyname.c |
| | RTEMS Associate Remote by Name.
| file | base_fs.c |
| | Base File System Initialization.
| file | cachealignedalloc.c |
| file | cachecoherentalloc.c |
| file | calloc.c |
| file | cfgetispeed.c |
| | Baud Rate Functions.
| file | cfgetospeed.c |
| file | cfsetispeed.c |
| file | cfsetospeed.c |
| file | chdir.c |
| | POSIX 1003.1b - 5.2.1 - Change Current Working Directory.
| file | chmod.c |
| | Change File Modes.
| file | chown.c |
| | Change Owner and Group of a File.
| file | chroot.c |
| | Change Root Directory.
| file | clonenode.c |
| | Clones a Node.
| file | close.c |
| | POSIX 1003.1b 6.3.1 - Close a File.
| file | ctermid.c |
| | Generate Terminal Pathname.
| file | dup.c |
| | POSIX 1003.1b 6.2.1 Duplicate an Open File Descriptor.
| file | dup2.c |
| file | envlock.c |
| | Global Environment Lock Support.
| file | error.c |
| | Error and Panic Report Support.
| file | fchdir.c |
| | Change Directory.
| file | fchmod.c |
| | Change File Modes.
| file | fchown.c |
| file | fcntl.c |
| | POSIX 1003.1b 6.5.2 - File Control.
| file | fdatasync.c |
| | POSIX 1003.1b 6.6.2 - Synchronize the Data of a File.
| file | flockfile.c |
| | Lock File for Stdio.
| file | fpathconf.c |
| | Configurable Pathname Varables.
| file | free.c |
| | calloc()
| file | freenode.c |
| | Releases all Resources of a Location.
| file | fstat.c |
| file | fsync.c |
| | Synchronize the State of a File.
| file | ftruncate.c |
| | Truncate a File to the Specified Length.
| file | ftrylockfile.c |
| file | funlockfile.c |
| | Unlock File for Stdio.
| file | getchark.c |
| | Get Character from Stdin.
| file | getcwd.c |
| | Get Current Working Directory.
| file | getdents.c |
| | Get Directory Entries.
| file | getegid.c |
| | Get Real User, Effective User, Ral Group, and Effective Group IDs.
| file | geteuid.c |
| file | getgid.c |
| file | getgrent.c |
| | User Database Access Routines.
| file | getgrnam.c |
| file | getgroups.c |
| | Get Supplementary IDs.
| file | getlogin.c |
| | Get User Name.
| file | getpagesize.c |
| | Get System Page Size.
| file | getpgrp.c |
| file | getpid.c |
| | Process and Parent Process IDs.
| file | getppid.c |
| | Get Process and Parent Process IDs.
| file | getpwent.c |
| file | getrusage.c |
| file | getuid.c |
| file | gxx_wrappers.c |
| | RTEMS Threads Compatibility Routines for Libgcc2.
| file | ioctl.c |
| | ioctl() system call
| file | isatty.c |
| | Test whether a File Descriptor Refers to a Terminal.
| file | isatty_r.c |
| | Test for a Terminal Device.
| file | issetugid.c |
| | Dummy Version of BSD Routine.
| file | kill_noposix.c |
| | Kill No POSIXMarginal implementations of some POSIX API routines to be used when POSIX is disabled.
| file | lchown.c |
| file | libio.c |
| | File Descriptor Routines.
| file | libio_exit.c |
| file | libio_helper_null.c |
| file | libio_init.c |
| | RTEMS LibIO Initialization.
| file | link.c |
| | Create a new link.
| file | lseek.c |
| file | lstat.c |
| | Get File Status.
| file | malloc.c |
| | RTEMS Malloc Family Implementation.
| file | malloc_deferred.c |
| | Malloc Deferred Support.
| file | malloc_dirtier.c |
| | Dirty Memory Function.
| file | malloc_initialize.c |
| | RTEMS_Malloc_Initialize() implementation.
| file | malloc_p.h [code] |
| file | malloc_walk.c |
| | Malloc Walk.
| file | mallocfreespace.c |
| | RTEMS Malloc Get Free Information.
| file | mallocgetheapptr.c |
| | RTEMS Malloc Get Heap Pointer.
| file | mallocinfo.c |
| | RTEMS Malloc Get Status Information.
| file | mallocsetheapptr.c |
| | RTEMS Malloc Set Heap Pointer.
| file | mkdir.c |
| | Make a Directory.
| file | mkfifo.c |
| | Make a FIFO Special File.
| file | mknod.c |
| | Create a Special or Ordinary File.
| file | mount-mgr.c |
| file | mount-mktgt.c |
| | mount_and_make_target_path() implementation.
| file | mount.c |
| | Mounts a File System.
| file | newlibc_exit.c |
| file | newlibc_init.c |
| | Newlib Initialization.
| file | newlibc_reent.c |
| | Newlib Support.
| file | open.c |
| | Open a File.
| file | open_dev_console.c |
| file | pathconf.c |
| file | libcsupport/src/pipe.c |
| | Create an Inter-Process Channel.
| file | posix_memalign.c |
| file | printf_plugin.c |
| | RTEMS Plugin Printf.
| file | printk.c |
| | Kernel Printf Function.
| file | printk_plugin.c |
| | Plugin Printk.
| file | privateenv.c |
| | Instantiate a Private User Environment.
| file | putk.c |
| | Write Character to Stream.
| file | pwdgrp.c |
| file | pwdgrp.h [code] |
| file | libcsupport/src/read.c |
| | Read From a File.
| file | readdir_r.c |
| | Read a Directory.
| file | readlink.c |
| | Read Value of a Symbolic Link.
| file | readv.c |
| | Read a Vector.
| file | realloc.c |
| | Reallocate Memory Block.
| file | realpath.c |
| file | resource_snapshot.c |
| file | rmdir.c |
| | Remove a Directory.
| file | rtems_heap_extend.c |
| | rtems_heap_extend() implementation.
| file | rtems_heap_extend_via_sbrk.c |
| | RTEMS Extend Heap via Sbrk.
| file | rtems_heap_greedy.c |
| | Greedy Allocate that Empties the Heap.
| file | rtems_heap_null_extend.c |
| file | rtems_malloc.c |
| | rtems_malloc() implementation.
| file | rtems_memalign.c |
| | RTEMS Variation on Aligned Memory Allocation.
| file | rtems_mkdir.c |
| | rtems_mkdir() implementation.
| file | rtems_putc.c |
| | RTEMS Output a Character.
| file | setegid.c |
| file | seteuid.c |
| | Set Effective User Id.
| file | setgid.c |
| file | setpgid.c |
| | Set Process Group ID for Job Control.
| file | setsid.c |
| | Create Session and Set Process Group ID.
| file | setuid.c |
| file | stat.c |
| | Get File Status.
| file | statvfs.c |
| file | strlcat.c |
| | Concatenate a Strings.
| file | strlcpy.c |
| file | sup_fs_check_permissions.c |
| | RTEMS File System Permissions Check Support.
| file | sup_fs_deviceio.c |
| | RTEMS DeviceIO Support.
| file | sup_fs_eval_path.c |
| | RTEMS File Sysyem Path Eval Support.
| file | sup_fs_eval_path_generic.c |
| | RTEMS File System Eval Generic Path.
| file | sup_fs_exist_in_same_instance.c |
| | Checks that the Locations Exist in the Same File System Instance.
| file | sup_fs_location.c |
| file | sup_fs_mount_iterate.c |
| | Mount table entry visitor.
| file | sup_fs_next_token.c |
| | RTEMS File System Eval Eat Delimiter Path.
| file | symlink.c |
| | Make a Symbolic Link to a File.
| file | sync.c |
| | Synchronize Data on Disk with Memory.
| file | tcdrain.c |
| | Line Control Functions.
| file | tcflow.c |
| file | tcflush.c |
| file | tcgetattr.c |
| | Get State.
| file | tcgetpgrp.c |
| | Get Foreground Process Group ID.
| file | tcsendbreak.c |
| file | tcsetattr.c |
| | Get and Set State.
| file | tcsetpgrp.c |
| | Set Foreground Process Group ID.
| file | termios.c |
| | TERMIOS serial line support.
| file | termios_baud2index.c |
| | Convert Bxxx Constant to Index.
| file | termios_baud2num.c |
| | Convert Baud Part of Termios control flags to an integral Baud Value.
| file | termios_baudtable.c |
| | RTEMS Termios Baud Table.
| file | termios_num2baud.c |
| | Converts the Integral Baud to Termios Control Flag Representation.
| file | termios_setbestbaud.c |
| file | termios_setinitialbaud.c |
| | Sets the Initial Baud in the Termios Context.
| file | termiosinitialize.c |
| | Termios Initialization.
| file | truncate.c |
| file | ttyname.c |
| | Demetermine Terminal Device Name.
| file | uenvgetgroups.c |
| file | umask.c |
| | Set File Creation Mask.
| file | unlink.c |
| | Remove an Existing Link.
| file | unmount.c |
| | Unmount a File System.
| file | utime.c |
| | Set File Access and Modification Times.
| file | utimes.c |
| | Change File Last Access and Modification Times.
| file | utsname.c |
| | Get System Name.
| file | vprintk.c |
| | Print Formatted Output.
| file | libcsupport/src/write.c |
| | Write to a File.
| file | write_r.c |
| | POSIX 1003.1b 6.4.2 - Write to a File.
| file | writev.c |
