sup_fs_eval_path.c File Reference
RTEMS File Sysyem Path Eval Support. More...
#include <rtems/libio_.h>
Include dependency graph for sup_fs_eval_path.c:
void rtems_filesystem_eval_path_continue (rtems_filesystem_eval_path_context_t *ctx)
rtems_filesystem_location_info_t * rtems_filesystem_eval_path_start_with_root_and_current (rtems_filesystem_eval_path_context_t *ctx, const char *path, size_t pathlen, int eval_flags, rtems_filesystem_global_location_t *const *global_root_ptr, rtems_filesystem_global_location_t *const *global_current_ptr)
rtems_filesystem_location_info_t * rtems_filesystem_eval_path_start (rtems_filesystem_eval_path_context_t *ctx, const char *path, int eval_flags)
rtems_filesystem_location_info_t * rtems_filesystem_eval_path_start_with_parent (rtems_filesystem_eval_path_context_t *ctx, const char *path, int eval_flags, rtems_filesystem_location_info_t *parentloc, int parent_eval_flags)
void rtems_filesystem_eval_path_recursive (rtems_filesystem_eval_path_context_t *ctx, const char *path, size_t pathlen)
void rtems_filesystem_eval_path_error (rtems_filesystem_eval_path_context_t *ctx, int eno)
void rtems_filesystem_eval_path_cleanup (rtems_filesystem_eval_path_context_t *ctx)
void rtems_filesystem_eval_path_cleanup_with_parent (rtems_filesystem_eval_path_context_t *ctx, rtems_filesystem_location_info_t *parentloc)
void rtems_filesystem_eval_path_restart (rtems_filesystem_eval_path_context_t *ctx, rtems_filesystem_global_location_t **newstartloc_ptr)
 Requests a path evaluation restart. More...
