Files | |
| file | barrier.c |
| RTEMS Barrier Manager Initialization. | |
| file | barriercreate.c |
| RTEMS Create Barrier. | |
| file | barrierdata.c |
| Instantiate Barrier Data. | |
| file | barrierdelete.c |
| RTEMS Delete Barrier. | |
| file | barrierident.c |
| RTEMS Barrier name to Id. | |
| file | barrierrelease.c |
| RTEMS Barrier Release. | |
| file | barriertranslatereturncode.c |
| Translate SuperCore Barrier Status Code to RTEMS Status Code. | |
| file | barrierwait.c |
| RTEMS Barrier Wait. | |
| file | clockget.c |
| Obtain Current Time of Day. | |
| file | clockgetsecondssinceepoch.c |
| Obtain Seconds Since Epoch. | |
| file | clockgettickspersecond.c |
| Obtain Ticks Per Seconds. | |
| file | clockgettod.c |
| Obtain Current Time of Day (Classic TOD) | |
| file | clockgettodtimeval.c |
| Obtain TOD in struct timeval Format. | |
| file | clockgetuptime.c |
| Obtain the System Uptime. | |
| file | clockgetuptimenanoseconds.c |
| Returns the system uptime in seconds. | |
| file | clockgetuptimetimeval.c |
| Gets the System Uptime in the Struct Timeval Format. | |
| file | clockset.c |
| Set the Current TOD. | |
| file | clocktick.c |
| Announce a Clock Tick. | |
| file | clocktodtoseconds.c |
| TOD to Seconds. | |
| file | clocktodvalidate.c |
| TOD Validate. | |
| file | dpmem.c |
| Dual Ported Memory Manager Initialization. | |
| file | dpmemcreate.c |
| RTEMS Create Port. | |
| file | dpmemdata.c |
| Define the internal Dual Ported Memory information. | |
| file | dpmemdelete.c |
| RTEMS Delete Port. | |
| file | dpmemexternal2internal.c |
| RTEMS Port External to Internal. | |
| file | dpmemident.c |
| RTEMS Port Name to Id. | |
| file | dpmeminternal2external.c |
| RTEMS Port Internal to External. | |
| file | event.c |
| Event Manager Initialization. | |
| file | eventmp.c |
| Event MP Support. | |
| file | eventreceive.c |
| Constant used to receive the set of currently pending events in. | |
| file | eventseize.c |
| file | eventsend.c |
| Sends an Event Set to the Target Task. | |
| file | eventsurrender.c |
| Surrender Event. | |
| file | getcurrentprocessor.c |
| file | getprocessorcount.c |
| file | intrbody.c |
| RTEMS Interrupt Support. | |
| file | intrcatch.c |
| RTEMS Interrupt Catch. | |
| file | modes.c |
| Body for RTEMS_INTERRUPT_LEVEL Macro. | |
| file | mp.c |
| MP Support. | |
| file | msg.c |
| Message Queue Manager Initialization. | |
| file | msgdata.c |
| Instantiate the Message Queue Data. | |
| file | msgmp.c |
| Multiprocessing Support for the Message Queue Manager. | |
| file | msgqbroadcast.c |
| RTEMS Broadcast Message Queue. | |
| file | msgqcreate.c |
| RTEMS Create Message Queue. | |
| file | msgqdelete.c |
| RTEMS Delete Message Queue. | |
| file | msgqflush.c |
| rtems_message_queue_flush | |
| file | msgqgetnumberpending.c |
| RTEMS Message Queue Get Number Pending. | |
| file | msgqident.c |
| RTEMS Message Queue Name to Id. | |
| file | msgqreceive.c |
| RTEMS Message Queue Receive. | |
| file | msgqsend.c |
| rtems_message_queue_send | |
| file | msgqtranslatereturncode.c |
| Message queue Translate Core Message Queue Return Code. | |
| file | msgqurgent.c |
| RTEMS Urgent Message Queue. | |
| file | part.c |
| Partition Manager Initialization. | |
| file | partcreate.c |
| RTEMS Partition Create. | |
| file | partdata.c |
| Instantiate RTEMS Partition Data. | |
| file | partdelete.c |
| RTEMS Delete Partition. | |
| file | partgetbuffer.c |
| RTEMS Get Partition Buffer. | |
| file | partident.c |
| RTEMS Partition Name to Id. | |
| file | partmp.c |
| Partition_MP_Send_process_packet. | |
| file | partreturnbuffer.c |
| file | ratemon.c |
| Rate Monotonic Manager Initialization. | |
| file | ratemoncancel.c |
| RTEMS Rate Monotonic Cancel. | |
| file | ratemoncreate.c |
| Create a Period. | |
| file | ratemondata.c |
| Instantiate RTEMS Period Data. | |
| file | ratemondelete.c |
| RTEMS Delete Rate Monotonic. | |
| file | ratemongetstatistics.c |
| RTEMS Rate Monotonic Get Statistics. | |
| file | ratemongetstatus.c |
| RTEMS Rate Monotonic Get Status. | |
| file | ratemonident.c |
| RTEMS Rate Monotonic Name to Id. | |
| file | ratemonperiod.c |
| Rate Monotonic Support. | |
| file | ratemonreportstatistics.c |
| RTEMS Report Rate Monotonic Statistics. | |
| file | ratemonresetall.c |
| rtems_rate_monotonic_reset_all_statistics | |
| file | ratemonresetstatistics.c |
| RTEMS Rate Monotonic Reset Statistics. | |
| file | ratemontimeout.c |
| Rate Monotonic Timeout. | |
| file | region.c |
| _Region_Manager_initialization | |
| file | regioncreate.c |
| rtems_region_create | |
| file | regiondata.c |
| Instantiate RTEMS Region Data. | |
| file | regiondelete.c |
| RTEMS Delete Region. | |
| file | regionextend.c |
| RTEMS Extend Region. | |
| file | regiongetfreeinfo.c |
| RTEMS Get Region Free Information. | |
| file | regiongetinfo.c |
| RTEMS Get Region Information. | |
| file | regiongetsegment.c |
| RTEMS Get Region Segment. | |
| file | regiongetsegmentsize.c |
| RTEMS Get Region Segment Size. | |
| file | regionident.c |
| RTEMS Region Name to Id. | |
| file | regionmp.c |
| Region MP Support. | |
| file | regionprocessqueue.c |
| Process Region Queue. | |
| file | regionresizesegment.c |
| Resize RTEMS Region Segment. | |
| file | regionreturnsegment.c |
| RTEMS Return Region Segment. | |
| file | rtclock.c |
| No Initialization Routine. | |
| file | rtemsbuildid.c |
| Build Object Id. | |
| file | rtemsbuildname.c |
| Build Thirty-Two Bit Object Name. | |
| file | rtemsobjectapimaximumclass.c |
| Get Highest Valid Class Value. | |
| file | rtemsobjectapiminimumclass.c |
| Get Lowest Valid Class Value. | |
| file | rtemsobjectgetapiclassname.c |
| Get Class Name. | |
| file | rtemsobjectgetapiname.c |
| Get API Name. | |
| file | rtemsobjectgetclassicname.c |
| Obtain Name of Object. | |
| file | rtemsobjectgetclassinfo.c |
| Get Class Information. | |
| file | rtemsobjectgetname.c |
| Obtain Object Name as String. | |
| file | rtemsobjectidapimaximum.c |
| Get Highest Valid API Index. | |
| file | rtemsobjectidapiminimum.c |
| Get Lowest Valid API Index. | |
| file | rtemsobjectidgetapi.c |
| Get API Portion of Object Id. | |
| file | rtemsobjectidgetclass.c |
| Get Class Portion of Object Id. | |
| file | rtemsobjectidgetindex.c |
| Get Index Portion of Object Id. | |
| file | rtemsobjectidgetnode.c |
| Get Node Portion of Object Id. | |
| file | rtemsobjectsetname.c |
| Set Name of Object. | |
| file | rtemstimer.c |
| Timer Manager Initialization. | |
| file | rtemstimerdata.c |
| Instantiate RTEMS Timer Data. | |
| file | schedulergetprocessorset.c |
| file | schedulerident.c |
| file | sem.c |
| Semaphore Manager Initialization. | |
| file | semcreate.c |
| rtems_semaphore_create | |
| file | semdata.c |
| Instantiate Semaphore Data. | |
| file | semdelete.c |
| RTEMS Delete Semaphore. | |
| file | semflush.c |
| RTEMS Semaphore Flush. | |
| file | semident.c |
| RTEMS Semaphore Name to Id. | |
| file | semmp.c |
| Semaphore MP Support. | |
| file | semobtain.c |
| RTEMS Obtain Semaphore. | |
| file | semrelease.c |
| RTEMS Semaphore ReleaseThis file contains the implementation of the Classic API directive rtems_semaphore_release(). | |
| file | semsetpriority.c |
| file | semtranslatereturncode.c |
| Semaphore Translate Core Mutex and Semaphore Return Code. | |
| file | signal.c |
| Signal Manager Initialization. | |
| file | signalcatch.c |
| RTEMS Catch Signal. | |
| file | signalmp.c |
| Signal MP Support. | |
| file | signalsend.c |
| RTEMS Send Signal. | |
| file | status.c |
| Status Mapping Arrays. | |
| file | statustext.c |
| file | systemeventreceive.c |
| rtems_event_system_receive() implementation. | |
| file | systemeventsend.c |
| rtems_event_system_send() implementation. | |
| file | taskcreate.c |
| RTEMS Task Create. | |
| file | taskdata.c |
| Instantiate RTEMS Classic API Tasks Data. | |
| file | taskdelete.c |
| RTEMS Delete Task. | |
| file | taskgetaffinity.c |
| RTEMS Task Get Affinity. | |
| file | taskgetnote.c |
| RTEMS Get Task Node. | |
| file | taskgetscheduler.c |
| file | taskident.c |
| RTEMS Task Name to Id. | |
| file | taskinitusers.c |
| _RTEMS_tasks_Initialize_user_tasks_body | |
| file | taskissuspended.c |
| rtems_task_is_suspended | |
| file | taskmode.c |
| RTEMS Task Mode. | |
| file | taskmp.c |
| RTEMS Tasks MP Send Process Packet. | |
| file | taskrestart.c |
| RTEMS Task Restart. | |
| file | taskresume.c |
| RTEMS Resume Task. | |
| file | tasks.c |
| RTEMS Task API Extensions. | |
| file | taskself.c |
| RTEMS Get Self Task Id. | |
| file | tasksetaffinity.c |
| RTEMS Task Set Affinity. | |
| file | tasksetnote.c |
| RTEMS Set Task Note. | |
| file | tasksetpriority.c |
| RTEMS Set Task Priority. | |
| file | tasksetscheduler.c |
| file | taskstart.c |
| RTEMS Start Task. | |
| file | tasksuspend.c |
| RTEMS Suspend Task. | |
| file | taskvariable_invoke_dtor.c |
| RTEMS Tasks Invoke Task Variable Destructor. | |
| file | taskvariableadd.c |
| RTEMS Add Task Variable. | |
| file | taskvariabledelete.c |
| RTEMS Delete Task Variable. | |
| file | taskvariableget.c |
| Get a per-task variable. | |
| file | taskwakeafter.c |
| RTEMS Task Wake After. | |
| file | taskwakewhen.c |
| RTEMS Task Wake When. | |
| file | timercancel.c |
| file | rtems/src/timercreate.c |
| RTEMS Create Timer. | |
| file | rtems/src/timerdelete.c |
| RTEMS Delete Timer. | |
| file | timerfireafter.c |
| RTEMS Timer Fire After. | |
| file | timerfirewhen.c |
| RTEMS Timer Fire When. | |
| file | timergetinfo.c |
| RTEMS Get Timer Information. | |
| file | timerident.c |
| RTEMS Timer Name to Id. | |
| file | timerreset.c |
| RTEMS Timer Reset. | |
| file | timerserver.c |
| Timer Manager - rtems_timer_initiate_server directive along with the Timer Server Body and support routines. | |
| file | timerserverfireafter.c |
| RTEMS Timer Server Fire After. | |
| file | timerserverfirewhen.c |
| RTEMS Timer Server Fire When Directive. | |
| file | workspace.c |
| RTEMS Workspace Support. | |
| file | workspacegreedy.c |
| Greedy Allocate that Empties the Workspace and Free. | |
