Partition_MP_Send_process_packet. More...
#include <rtems/rtems/partimpl.h>
Include dependency graph for partmp.c:
 RTEMS_STATIC_ASSERT (sizeof(Partition_MP_Packet)<=MP_PACKET_MINIMUM_PACKET_SIZE, Partition_MP_Packet)
void _Partition_MP_Send_process_packet (Partition_MP_Remote_operations operation, Objects_Id partition_id, rtems_name name, Objects_Id proxy_id)
rtems_status_code _Partition_MP_Send_request_packet (Partition_MP_Remote_operations operation, Objects_Id partition_id, void *buffer)
 Partition_MP_Send_request_packet. More...
void _Partition_MP_Send_response_packet (Partition_MP_Remote_operations operation, Objects_Id partition_id, Thread_Control *the_thread)
 Partition_MP_Send_response_packet. More...
void _Partition_MP_Process_packet (rtems_packet_prefix *the_packet_prefix)
 Partition_MP_Process_packet. More...
void _Partition_MP_Send_extract_proxy (void *argument)
 Partition_MP_Send_extract_proxy. More...
Partition_MP_Packet * _Partition_MP_Get_packet (void)
 Partition_MP_Get_packet. More...
◆ _Partition_MP_Get_packet()
Partition_MP_Packet* _Partition_MP_Get_packet ( void  )
This function is used to obtain a partition mp packet.
References _MPCI_Get_packet().
◆ _Partition_MP_Process_packet()
void _Partition_MP_Process_packet ( rtems_packet_prefix *  the_packet_prefix)
This routine performs the actions specific to this package for the request from another node.
◆ _Partition_MP_Send_extract_proxy()
void _Partition_MP_Send_extract_proxy ( void *  argument)
This routine is invoked when a task is deleted and it has a proxy which must be removed from a thread queue and the remote node must be informed of this.
References _Partition_MP_Send_process_packet().
◆ _Partition_MP_Send_process_packet()
void _Partition_MP_Send_process_packet ( Partition_MP_Remote_operations  operation,
rtems_name  name,
Objects_Id  proxy_id
Multiprocessing Support for the Partition Manager
This routine performs a remote procedure call so that a process operation can be performed on another node.
Referenced by _Partition_MP_Send_extract_proxy().
◆ _Partition_MP_Send_request_packet()
rtems_status_code _Partition_MP_Send_request_packet ( Partition_MP_Remote_operations  operation,
void *  buffer
This routine performs a remote procedure call so that a directive operation can be initiated on another node.
◆ _Partition_MP_Send_response_packet()
void _Partition_MP_Send_response_packet ( Partition_MP_Remote_operations  operation,
Thread_Control *  the_thread
This routine performs a remote procedure call so that a directive can be performed on another node.
