Multiprocessing Support for the Message Queue Manager. More...
#include <rtems/rtems/messageimpl.h>
#include <rtems/rtems/optionsimpl.h>
Include dependency graph for msgmp.c:
 RTEMS_STATIC_ASSERT (MESSAGE_QUEUE_MP_PACKET_SIZE<=MP_PACKET_MINIMUM_PACKET_SIZE, Message_queue_MP_Packet)
void _Message_queue_MP_Send_process_packet (Message_queue_MP_Remote_operations operation, Objects_Id message_queue_id, rtems_name name, Objects_Id proxy_id)
 _Message_queue_MP_Send_process_packet More...
rtems_status_code _Message_queue_MP_Send_request_packet (Message_queue_MP_Remote_operations operation, Objects_Id message_queue_id, const void *buffer, size_t *size_p, rtems_option option_set, rtems_interval timeout)
 _Message_queue_MP_Send_request_packet More...
void _Message_queue_MP_Send_response_packet (Message_queue_MP_Remote_operations operation, Objects_Id message_queue_id, Thread_Control *the_thread)
 _Message_queue_MP_Send_response_packet More...
void _Message_queue_MP_Process_packet (rtems_packet_prefix *the_packet_prefix)
 _Message_queue_MP_Process_packet More...
void _Message_queue_MP_Send_object_was_deleted (Thread_Control *the_proxy)
 _Message_queue_MP_Send_object_was_deleted More...
void _Message_queue_MP_Send_extract_proxy (void *argument)
 _Message_queue_MP_Send_extract_proxy More...
Message_queue_MP_Packet * _Message_queue_MP_Get_packet (void)
 _Message_queue_MP_Get_packet More...
void _Message_queue_Core_message_queue_mp_support (Thread_Control *the_thread, Objects_Id id)
 Message_queue_Core_message_queue_mp_support. More...
◆ _Message_queue_Core_message_queue_mp_support()
void _Message_queue_Core_message_queue_mp_support ( Thread_Control *  the_thread,
rtems_id  id
Input parameters: the_thread - the remote thread the message was submitted to id - id of the message queue
Output parameters: NONE
References _Message_queue_MP_Send_response_packet(), and RTEMS_SUCCESSFUL.
◆ _Message_queue_MP_Get_packet()
Message_queue_MP_Packet* _Message_queue_MP_Get_packet ( void  )
This function is used to obtain a message queue mp packet.
References _MPCI_Get_packet().
◆ _Message_queue_MP_Process_packet()
void _Message_queue_MP_Process_packet ( rtems_packet_prefix *  the_packet_prefix)
This routine performs the actions specific to this package for the request from another node.
◆ _Message_queue_MP_Send_extract_proxy()
void _Message_queue_MP_Send_extract_proxy ( void *  argument)
This routine is invoked when a task is deleted and it has a proxy which must be removed from a thread queue and the remote node must be informed of this.
References _Message_queue_MP_Send_process_packet().
◆ _Message_queue_MP_Send_object_was_deleted()
void _Message_queue_MP_Send_object_was_deleted ( Thread_Control *  the_proxy)
This routine is invoked indirectly by the thread queue when a proxy has been removed from the thread queue and the remote node must be informed of this.
References _Message_queue_MP_Send_response_packet(), and RTEMS_OBJECT_WAS_DELETED.
◆ _Message_queue_MP_Send_process_packet()
void _Message_queue_MP_Send_process_packet ( Message_queue_MP_Remote_operations  operation,
rtems_name  name,
Objects_Id  proxy_id
This routine performs a remote procedure call so that a process operation can be performed on another node.
Referenced by _Message_queue_MP_Send_extract_proxy().
◆ _Message_queue_MP_Send_request_packet()
rtems_status_code _Message_queue_MP_Send_request_packet ( Message_queue_MP_Remote_operations  operation,
const void *  buffer,
size_t *  size_p,
This routine performs a remote procedure call so that a directive operation can be initiated on another node.
◆ _Message_queue_MP_Send_response_packet()
void _Message_queue_MP_Send_response_packet ( Message_queue_MP_Remote_operations  operation,
This routine performs a remote procedure call so that a directive can be performed on another node.
Referenced by _Message_queue_Core_message_queue_mp_support(), and _Message_queue_MP_Send_object_was_deleted().
