Files | |
| file | boot.h [code] |
| Bootloader Support Utilities. | |
| file | common.h [code] |
| Common Symbols and Define Undefined Registers. | |
| file | crc16.h [code] |
| Moved to <util/crc16.h> | |
| file | delay.h [code] |
| Moved to <util/delay.h> | |
| file | score/cpu/avr/avr/eeprom.h [code] |
| Data EEPROM Contained in the AVR Microcontrollers. | |
| file | fuse.h [code] |
| file | interrupt.h [code] |
| file | score/cpu/avr/avr/io.h [code] |
| AVR device-specific IO Definitions. | |
| file | io1200.h [code] |
| Definitions for AT90S1200. | |
| file | io2313.h [code] |
| file | io2323.h [code] |
| file | io2333.h [code] |
| file | io2343.h [code] |
| Definitions for AT90S2343. | |
| file | io43u32x.h [code] |
| Definitions for AT43USB32x. | |
| file | io43u35x.h [code] |
| file | io4414.h [code] |
| Definitions for AT90S4414. | |
| file | io4433.h [code] |
| Definitions for AT90S4433. | |
| file | io4434.h [code] |
| Definitions for AT90S4434. | |
| file | io76c711.h [code] |
| Definitions for AT76C711. | |
| file | io8515.h [code] |
| file | io8534.h [code] |
| Definitions for AT90C8534. | |
| file | io8535.h [code] |
| Definitions for AT90S8535. | |
| file | io86r401.h [code] |
| Definitions for AT86RF401. | |
| file | io90pwm1.h [code] |
| Definitions for AT90PWM1. | |
| file | io90pwm216.h [code] |
| Definitions for AT90PWM216. | |
| file | io90pwm2b.h [code] |
| Definitions for AT90PWM2B. | |
| file | io90pwm316.h [code] |
| file | io90pwm3b.h [code] |
| Definitions for AT90PWM3B. | |
| file | io90pwm81.h [code] |
| Definitions for AT90PWM81. | |
| file | io90pwmx.h [code] |
| Definitions for AT90PWM2(B) and AT90PWM3(B) | |
| file | io90scr100.h [code] |
| Definitions for AT90SCR100. | |
| file | ioa6289.h [code] |
| Definitions for ATA6289. | |
| file | ioat94k.h [code] |
| Definitions for AT94K Series FPSLIC(tm) | |
| file | iocan128.h [code] |
| file | iocan32.h [code] |
| Definitions for CAN32. | |
| file | iocan64.h [code] |
| file | iocanxx.h [code] |
| Definitions for AT90CAN32, AT90CAN64 and AT90CAN128. | |
| file | iom103.h [code] |
| Definitions for ATmega103. | |
| file | iom128.h [code] |
| Definitions for ATmega128. | |
| file | iom1280.h [code] |
| Definitions for ATmega1280. | |
| file | iom1281.h [code] |
| Definitions for ATmega1281. | |
| file | iom1284p.h [code] |
| Definitions for ATmega1284P. | |
| file | iom128rfa1.h [code] |
| file | iom16.h [code] |
| Definitions for ATmega16. | |
| file | iom161.h [code] |
| Definitions for ATmega161. | |
| file | iom162.h [code] |
| Definitions for ATmega162. | |
| file | iom163.h [code] |
| Definitions for ATmega163. | |
| file | iom164.h [code] |
| Definitions for ATmega164. | |
| file | iom165.h [code] |
| Definitions for ATmega165. | |
| file | iom165p.h [code] |
| file | iom168.h [code] |
| Definitions for iom168. | |
| file | iom168p.h [code] |
| Definitions for ATmega168P. | |
| file | iom169.h [code] |
| Definitions for ATmega169. | |
| file | iom169p.h [code] |
| Definitions for ATmega169P. | |
| file | iom169pa.h [code] |
| Definitions for ATmega169PA. | |
| file | iom16a.h [code] |
| file | iom16hva.h [code] |
| Definitions for ATmega16HVA. | |
| file | iom16hva2.h [code] |
| Definitions for ATmega16HVA2. | |
| file | iom16hvb.h [code] |
| Definitions for ATmega16HVB. | |
| file | iom16m1.h [code] |
| Definitions for ATmega16M1. | |
| file | iom16u2.h [code] |
| Definitions for ATmega16U2. | |
| file | iom16u4.h [code] |
| Definitions for ATmega16U4. | |
| file | iom2560.h [code] |
| file | iom2561.h [code] |
| file | iom32.h [code] |
| Definitions for ATmega32. | |
| file | iom323.h [code] |
| Definitions for ATmega323. | |
| file | iom324.h [code] |
| Definitions for ATmega324. | |
| file | iom324pa.h [code] |
| file | iom325.h [code] |
| Definitions for ATmega325 and ATmega325P. | |
| file | iom3250.h [code] |
| file | iom328p.h [code] |
| Definitions for ATmega328P. | |
| file | iom329.h [code] |
| file | iom3290.h [code] |
| Definitions for ATmega3290 and ATmega3290P. | |
| file | iom32c1.h [code] |
| Definitions for ATmega32C1. | |
| file | iom32hvb.h [code] |
| file | iom32m1.h [code] |
| Definitions for ATmega32M1. | |
| file | iom32u2.h [code] |
| file | iom32u4.h [code] |
| Definitions for ATmega32U4. | |
| file | iom32u6.h [code] |
| Definitions for ATmega32U6. | |
| file | iom406.h [code] |
| Definitions for ATmega406. | |
| file | iom48.h [code] |
| Definitions for iom48. | |
| file | iom48p.h [code] |
| Definitions for ATmega48P. | |
| file | iom64.h [code] |
| file | iom640.h [code] |
| Definitions for ATmega640. | |
| file | iom644.h [code] |
| Definitions for ATmega644. | |
| file | iom644p.h [code] |
| file | iom644pa.h [code] |
| Definitions for ATmega644PA. | |
| file | iom645.h [code] |
| Definitions for ATmega645. | |
| file | iom6450.h [code] |
| Definitions for ATmega6450. | |
| file | iom649.h [code] |
| Definitions for ATmega649. | |
| file | iom6490.h [code] |
| Definitions for ATmega6490. | |
| file | iom649p.h [code] |
| file | iom64c1.h [code] |
| Definitions for ATmega64C1. | |
| file | iom64hve.h [code] |
| Definitions for ATmega64HVE. | |
| file | iom64m1.h [code] |
| file | iom8.h [code] |
| Definitions for ATmega8. | |
| file | iom8515.h [code] |
| Definitions for ATmega8515. | |
| file | iom8535.h [code] |
| file | iom88.h [code] |
| Definitions for ATmega88. | |
| file | iom88p.h [code] |
| Definitions for ATmega88P. | |
| file | iom88pa.h [code] |
| file | iom8hva.h [code] |
| Definitions for ATmega8HVA. | |
| file | iom8u2.h [code] |
| Definitions for ATmega8U2. | |
| file | iomx8.h [code] |
| file | iomxx0_1.h [code] |
| Definitions for ATmega640/1280/1281/2560/2561. | |
| file | iomxx4.h [code] |
| Definitions for ATmega164P/324P/644P and ATmega644. | |
| file | iomxxhva.h [code] |
| Definitions for ATmega8HVA and ATmega16HVA. | |
| file | iotn11.h [code] |
| Definitions for ATtiny10/11. | |
| file | iotn12.h [code] |
| Definitions for ATtiny12. | |
| file | iotn13.h [code] |
| Definitions for ATtiny13. | |
| file | iotn13a.h [code] |
| file | iotn15.h [code] |
| Definitions for ATtiny15. | |
| file | iotn167.h [code] |
| Definitions for ATtiny167. | |
| file | iotn22.h [code] |
| file | iotn2313.h [code] |
| Definitions for ATtiny2313. | |
| file | iotn2313a.h [code] |
| Definitions for ATtiny2313A. | |
| file | iotn24.h [code] |
| Definitions for ATtiny24. | |
| file | iotn24a.h [code] |
| Definitions for ATtiny24A. | |
| file | iotn25.h [code] |
| file | iotn26.h [code] |
| Definitions for ATtiny26. | |
| file | iotn261.h [code] |
| Definitions for ATtiny261. | |
| file | iotn261a.h [code] |
| Definitions for ATtiny261A. | |
| file | iotn28.h [code] |
| Definitions for ATtiny28. | |
| file | iotn4313.h [code] |
| Definitions for ATtiny4313. | |
| file | iotn43u.h [code] |
| Definitions for ATtiny43U. | |
| file | iotn44.h [code] |
| Definitions for ATtiny44. | |
| file | iotn44a.h [code] |
| file | iotn45.h [code] |
| Definitions for ATtiny45. | |
| file | iotn461.h [code] |
| Definitions for ATtiny461. | |
| file | iotn461a.h [code] |
| Definitions for ATtiny461A. | |
| file | iotn48.h [code] |
| Definitions for ATtiny48. | |
| file | iotn84.h [code] |
| file | iotn85.h [code] |
| Definitions for ATtiny85. | |
| file | iotn861.h [code] |
| file | iotn861a.h [code] |
| Definitions for ATtiny861A. | |
| file | iotn87.h [code] |
| Definitions for ATtiny87. | |
| file | iotn88.h [code] |
| Definitions for ATtiny88. | |
| file | iotnx4.h [code] |
| file | iotnx5.h [code] |
| Definitions for ATtiny25, ATtiny45 and ATtiny85. | |
| file | iotnx61.h [code] |
| Definitions for ATtiny261, ATtiny461 and ATtiny861. | |
| file | iousb1286.h [code] |
| Definitions for AT90USB1286. | |
| file | iousb1287.h [code] |
| Definitions for AT90USB1287. | |
| file | iousb162.h [code] |
| file | iousb646.h [code] |
| Definitions for AT90USB646. | |
| file | iousb647.h [code] |
| Definitions for AT90USB647. | |
| file | iousb82.h [code] |
| Ddefinitions for AT90USB82. | |
| file | iousbxx2.h [code] |
| Definitions for AT90USB82 and AT90USB162. | |
| file | iousbxx6_7.h [code] |
| Definitions for AT90USB646, AT90USB647, AT90USB1286, AT90USB1287. | |
| file | iox128a1.h [code] |
| file | iox128a3.h [code] |
| Definitions for ATxmega128A3. | |
| file | iox128d3.h [code] |
| file | iox16a4.h [code] |
| Definitions for ATxmega16A4. | |
| file | iox16d4.h [code] |
| Definitions for ATxmega16D4. | |
| file | iox192a3.h [code] |
| Definitions for ATxmega192A3. | |
| file | iox192d3.h [code] |
| Definitions for ATxmega192D3. | |
| file | iox256a3.h [code] |
| file | iox256a3b.h [code] |
| Definitions for ATxmega256A3B. | |
| file | iox256d3.h [code] |
| Definitions for ATxmega256D3. | |
| file | iox32a4.h [code] |
| Definitions for ATxmega32A4. | |
| file | iox32d4.h [code] |
| Definitions for ATxmega32D4. | |
| file | iox64a1.h [code] |
| Definitions for ATxmega64A1. | |
| file | iox64a3.h [code] |
| Definitions for ATxmega64A3. | |
| file | iox64d3.h [code] |
| Definitions for ATxmega64D3. | |
| file | lock.h [code] |
| Lock Bits API. | |
| file | parity.h [code] |
| Koved to <util/parity.h> | |
| file | pgmspace.h [code] |
| file | portpins.h [code] |
| Define Generic PORTn, DDn, and PINn Values. | |
| file | power.h [code] |
| Power Reduction Management. | |
| file | sfr_defs.h [code] |
| Macros for Accessing AVR Special Function Registers. | |
| file | score/cpu/avr/avr/signal.h [code] |
| Use <avr/interrupt.h> | |
| file | signature.h [code] |
| Signature Support. | |
| file | sleep.h [code] |
| Power Management and Sleep Modes. | |
| file | score/cpu/avr/avr/version.h [code] |
| Current Version of avr-libc. | |
| file | wdt.h [code] |
| Watchdog Timer Handling. | |
