RTEMS 6.1
cpu.h File Reference
V850 CPU Department Source. More...
#include <rtems/score/v850.h>
struct  Context_Control
 Thread register context. More...
struct  CPU_Interrupt_frame
 Interrupt stack frame (ISF). More...
#define CPU_SIMPLE_VECTORED_INTERRUPTS   FALSE
#define CPU_HARDWARE_FP   FALSE
#define CPU_SOFTWARE_FP   FALSE
#define CPU_ALL_TASKS_ARE_FP   FALSE
#define CPU_IDLE_TASK_IS_FP   FALSE
#define CPU_USE_DEFERRED_FP_SWITCH   FALSE
#define CPU_ENABLE_ROBUST_THREAD_DISPATCH   FALSE
#define CPU_STACK_GROWS_UP   FALSE
#define CPU_CACHE_LINE_BYTES   32
#define CPU_STRUCTURE_ALIGNMENT
#define CPU_MODES_INTERRUPT_MASK   0x00000001
#define CPU_MAXIMUM_PROCESSORS   32
#define _CPU_Context_Get_SP(_context)    (_context)->r3_stack_pointer
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   0
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE
#define CPU_STACK_MINIMUM_SIZE   (1024*4)
#define CPU_SIZEOF_POINTER   4
#define CPU_ALIGNMENT   8
#define CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT
#define CPU_STACK_ALIGNMENT   8
#define CPU_INTERRUPT_STACK_ALIGNMENT   CPU_CACHE_LINE_BYTES
#define _CPU_ISR_Disable(_isr_cookie)
#define _CPU_ISR_Enable(_isr_cookie)
#define _CPU_ISR_Flash(_isr_cookie)
#define _CPU_ISR_Set_level(new_level)
#define _CPU_Context_Restart_self(_the_context)    _CPU_Context_restore( (_the_context) );
#define CPU_USE_GENERIC_BITFIELD_CODE   TRUE
#define CPU_USE_LIBC_INIT_FINI_ARRAY   FALSE
typedef CPU_Interrupt_frame CPU_Exception_frame
typedef uint32_t CPU_Counter_ticks
typedef uintptr_t CPU_Uint32ptr
uint32_t _CPU_ISR_Get_level (void)
 Returns the interrupt level of the executing thread.
void _CPU_Context_Initialize (Context_Control *the_context, uint32_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area)
void _CPU_Initialize (void)
 CPU initialize. This routine performs CPU dependent initialization.
RTEMS_NO_RETURN void * _CPU_Thread_Idle_body (uintptr_t ignored)
void _CPU_Context_switch (Context_Control *run, Context_Control *heir)
 CPU switch context.
RTEMS_NO_RETURN void _CPU_Context_restore (Context_Control *new_context)
 SPARC specific context restore.
void _CPU_Exception_frame_print (const CPU_Exception_frame *frame)
 Prints the exception frame via printk().
uint32_t _CPU_Counter_frequency (void)
 Gets the current CPU counter frequency in Hz.
CPU_Counter_ticks _CPU_Counter_read (void)
 Gets the current CPU counter value.
This include file contains information pertaining to the v850 processor.
◆ _CPU_Context_Restart_self
#define _CPU_Context_Restart_self (   _the_context)     _CPU_Context_restore( (_the_context) );
This routine is responsible for somehow restarting the currently executing task. If you are lucky, then all that is necessary is restoring the context. Otherwise, there will need to be a special assembly routine which does something special in this case. For many ports, simply adding a label to the restore path of _CPU_Context_switch will work. On other ports, it may be possibly to load a few arguments and jump to the restore path. It will not work if restarting self conflicts with the stack frame assumptions of restoring a context.
Port Specific Information:
On the v850, we require a special entry point to restart a task.
◆ CPU_ALIGNMENT
CPU's worst alignment requirement for data types on a byte boundary. This alignment does not take into account the requirements for the stack.
There is no apparent reason why this should be larger than 8.
◆ CPU_HEAP_ALIGNMENT
This number corresponds to the byte alignment requirement for the heap handler. This alignment requirement may be stricter than that for the data types alignment specified by CPU_ALIGNMENT. It is common for the heap to follow the same alignment requirement as CPU_ALIGNMENT. If the CPU_ALIGNMENT is strict enough for the heap, then this should be set to CPU_ALIGNMENT.
Note
This does not have to be a power of 2 although it should be a multiple of 2 greater than or equal to 2. The requirement to be a multiple of 2 is because the heap uses the least significant field of the front and back flags to indicate that a block is in use or free. So you do not want any odd length blocks really putting length data in that bit.
On byte oriented architectures, CPU_HEAP_ALIGNMENT normally will have to be greater or equal to than CPU_ALIGNMENT to ensure that elements allocated from the heap meet all restrictions.
There is no apparent reason why this should be larger than CPU_ALIGNMENT.
◆ CPU_SIMPLE_VECTORED_INTERRUPTS
Does the CPU follow the simple vectored interrupt model?
If TRUE, then RTEMS allocates the vector table it internally manages. If FALSE, then the BSP is assumed to allocate and manage the vector table
This port uses the Progammable Interrupt Controller interrupt model.
◆ CPU_STACK_ALIGNMENT
The v850 has enough RAM where alignment to 16 may be desirable depending on the cache properties. But this remains to be demonstrated.
◆ CPU_STACK_GROWS_UP
Does the stack grow up (toward higher addresses) or down (toward lower addresses)?
If TRUE, then the grows upward. If FALSE, then the grows toward smaller addresses.
The v850 stack grows from high addresses to low addresses.
Typedef Documentation
◆ CPU_Uint32ptr
Type that can store a 32-bit integer or a pointer.
◆ _CPU_Context_Initialize()
void _CPU_Context_Initialize ( Context_Control the_context,
uint32_t *  stack_base,
uint32_t  size,
uint32_t  new_level,
void *  entry_point,
bool  is_fp,
void *  tls_area
Initialize the context to a state suitable for starting a task after a context restore operation. Generally, this involves:
  • setting a starting address
  • preparing the stack
  • preparing the stack and frame pointers
  • setting the proper interrupt level in the context
  • initializing the floating point context
Parameters
[in]the_contextpoints to the context area
[in]stack_baseis the low address of the allocated stack area
[in]sizeis the size of the stack area in bytes
[in]new_levelis the interrupt level for the task
[in]entry_pointis the task's entry point
[in]is_fpis set to TRUE if the task is a floating point task
[in]tls_areais the thread-local storage (TLS) area
NOTE: Implemented as a subroutine for the SPARC port.
