RTEMS 6.1
score Directory Reference
file  cpu.h [code]
 V850 CPU Department Source.
file  cpu_asm.h [code]
 V850 Assembly File Very loose template for an include file for the cpu_asm.? file if it is implemented as a ".S" file (preprocessed by cpp) instead of a ".s" file (preprocessed by gm4 or gasp).
file  cpuimpl.h [code]
 CPU Port Implementation API.
file  v850.h [code]
 V850 Set up Basic CPU Dependency Settings Based on Compiler Settings.
