RTEMS 6.1
cpu_asm.h
2
12/*
13 * COPYRIGHT (c) 1989-2012.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_SCORE_CPU_ASM_H
39#define _RTEMS_SCORE_CPU_ASM_H
40
41/* pull in the generated offsets */
42
43#include <rtems/score/offsets.h>
44
45/*
46 * Hardware General Registers
47 */
48
49/* put something here */
50
51/*
52 * Hardware Floating Point Registers
53 */
54
55/* put something here */
56
57/*
58 * Hardware Control Registers
59 */
60
61/* put something here */
62
63/*
64 * Calling Convention
65 */
66
67/* put something here */
68
69/*
70 * Temporary registers
71 */
72
73/* put something here */
74
75/*
76 * Floating Point Registers - SW Conventions
77 */
78
79/* put something here */
80
81/*
82 * Temporary floating point registers
83 */
84
85/* put something here */
86
87#endif
88
89/* end of file */
