RTEMS 6.1
rtems_rtl_rap Struct Reference
rtems_rtl_obj_cachefile
rtems_rtl_obj_compdecomp
uint32_t length
uint32_t version
uint32_t compression
uint32_t checksum
uint32_t machinetype
uint32_t datatype
uint32_t class
uint32_t init
uint32_t fini
rtems_rtl_rap_section secs [RTEMS_RTL_RAP_SECS]
uint32_t symtab_size
char * strtab
uint32_t strtab_size
uint32_t relocs_size
uint32_t symbols
uint32_t strtable_size
uint32_t rpathlen
char * strtable
The RAP loader.
Field Documentation
◆ checksum
uint32_t rtems_rtl_rap::checksum
The checksum.
◆ class
uint32_t rtems_rtl_rap::class
The ELF class.
◆ compression
uint32_t rtems_rtl_rap::compression
The type of compression.
◆ datatype
uint32_t rtems_rtl_rap::datatype
The ELF data type.
◆ decomp
rtems_rtl_obj_comp* rtems_rtl_rap::decomp
The decompression streamer.
◆ file
rtems_rtl_obj_cache* rtems_rtl_rap::file
The file cache for the RAP file.
◆ fini
uint32_t rtems_rtl_rap::fini
The finish strtab offset.
◆ init
uint32_t rtems_rtl_rap::init
The initialisation strtab offset.
◆ length
uint32_t rtems_rtl_rap::length
The file length.
◆ machinetype
uint32_t rtems_rtl_rap::machinetype
The ELF machine type.
◆ relocs_size
uint32_t rtems_rtl_rap::relocs_size
The relocation table size.
◆ rpathlen
uint32_t rtems_rtl_rap::rpathlen
The length of rpath.
◆ secs
rtems_rtl_rap_section rtems_rtl_rap::secs[RTEMS_RTL_RAP_SECS]
The sections.
◆ strtab
char* rtems_rtl_rap::strtab
The string table.
◆ strtab_size
uint32_t rtems_rtl_rap::strtab_size
The string table size.
◆ strtable
char* rtems_rtl_rap::strtable
The detail string which resides in obj detail.
◆ strtable_size
uint32_t rtems_rtl_rap::strtable_size
The size of section names and obj names.
◆ symbols
uint32_t rtems_rtl_rap::symbols
The number of symbols.
◆ symtab_size
uint32_t rtems_rtl_rap::symtab_size
The symbol table size.
◆ version
uint32_t rtems_rtl_rap::version
The RAP file version.
