RTEMS 6.1
#include <rtl-obj-cache.h>
Data Fields | |
| int | fd |
| size_t | file_size |
| off_t | offset |
| size_t | size |
| size_t | level |
| uint8_t * | buffer |
The buffer cache.
| uint8_t* rtems_rtl_obj_cache::buffer |
The buffer
| int rtems_rtl_obj_cache::fd |
The file descriptor of the data in the cache.
| size_t rtems_rtl_obj_cache::file_size |
The size of the file.
| size_t rtems_rtl_obj_cache::level |
The amount of data in the cache. A file can be smaller than the cache file.
| off_t rtems_rtl_obj_cache::offset |
The base offset of the buffer.
| size_t rtems_rtl_obj_cache::size |
The size of the cache.
