RTEMS 6.1
rtl-rap.c File Reference
RTEMS Run-Time Link Editor. More...
#include <fcntl.h>
#include <inttypes.h>
#include <unistd.h>
#include <rtems/rtl/rtl.h>
#include "rtl-elf.h"
#include "rtl-error.h"
#include <rtems/rtl/rtl-obj-comp.h>
#include "rtl-rap.h"
#include <rtems/rtl/rtl-trace.h>
#include <rtems/rtl/rtl-unresolved.h>
struct  rtems_rtl_rap_sectdef
struct  rtems_rtl_rap_section
#define REL_R_OFFSET   (0)
#define REL_R_INFO   (1)
#define REL_R_ADDEND   (2)
#define RTEMS_RTL_RAP_TEXT_SEC   (0)
#define RTEMS_RTL_RAP_CONST_SEC   (1)
#define RTEMS_RTL_RAP_CTOR_SEC   (2)
#define RTEMS_RTL_RAP_DTOR_SEC   (3)
#define RTEMS_RTL_RAP_DATA_SEC   (4)
#define RTEMS_RTL_RAP_BSS_SEC   (5)
#define RTEMS_RTL_RAP_SECS   (6)
#define SYMNAME_BUFFER_SIZE   (1024)
typedef struct rtems_rtl_rap_sectdef rtems_rtl_rap_sectdef
typedef struct rtems_rtl_rap_section rtems_rtl_rap_section
typedef struct rtems_rtl_rap rtems_rtl_rap
bool rtems_rtl_rap_file_check (rtems_rtl_obj *obj, int fd)
bool rtems_rtl_rap_file_load (rtems_rtl_obj *obj, int fd)
bool rtems_rtl_rap_file_unload (rtems_rtl_obj *obj)
rtems_rtl_loader_formatrtems_rtl_rap_file_sig (void)
This is the RAP format loader support..
◆ REL_R_OFFSET
The offsets in the unresolved array.
◆ RTEMS_RTL_RAP_TEXT_SEC
The section indexes. These are fixed.
Typedef Documentation
◆ rtems_rtl_rap
The RAP loader.
◆ rtems_rtl_rap_sectdef
The section definitions found in a RAP file.
◆ rtems_rtl_rap_section
◆ rtems_rtl_rap_file_check()
bool rtems_rtl_rap_file_check ( rtems_rtl_obj obj,
int  fd
The RAP format check handler.
Parameters
objThe object being checked.
fdThe file descriptor.
◆ rtems_rtl_rap_file_load()
bool rtems_rtl_rap_file_load ( rtems_rtl_obj obj,
int  fd
The RAP format load handler.
Parameters
objThe object to load.
obj->entry = (void*)(uintptr_t) ehdr.e_entry;
◆ rtems_rtl_rap_file_sig()
rtems_rtl_loader_format * rtems_rtl_rap_file_sig ( void  )
The RAP format signature handler.
Returns
rtems_rtl_loader_format* The format's signature.
◆ rtems_rtl_rap_file_unload()
bool rtems_rtl_rap_file_unload ( rtems_rtl_obj obj)
The RAP format unload handler.
Parameters
objThe object to unload.
