struct pci_bus * | bus |
struct pci_dev * | sibling |
struct pci_dev * | next |
void * | sysdata |
struct proc_dir_entry * | procent |
unsigned int | devfn |
unsigned short | vendor |
unsigned short | device |
unsigned int | class |
unsigned int | hdr_type |
unsigned int | master: 1 |
unsigned int | irq |
unsigned long | base_address [6] |
unsigned long | rom_address |
struct pci_res | resources [DEV_RES_CNT] |
pci_dev_t | busdevfun |
uint8_t | flags |
uint8_t | sysirq |
uint16_t | vendor |
uint16_t | device |
uint16_t | subvendor |
uint16_t | subdevice |
uint32_t | classrev |
uint16_t | command |
The documentation for this struct was generated from the following files:
- bsps/powerpc/motorola_powerpc/bootloader/pci.h
- cpukit/include/pci/cfg.h
