RTEMS 6.1
pci_bus Struct Reference
struct pci_busparent
struct pci_buschildren
struct pci_busnext
struct pci_devself
struct pci_devdevices
void * sysdata
struct proc_dir_entry * procdir
unsigned char number
unsigned char primary
unsigned char secondary
unsigned char subordinate
struct pci_dev dev
struct pci_devdevs
unsigned int flags
int num
int pri
int sord
The documentation for this struct was generated from the following files:
