15#ifndef BOOTLOADER_PCI_H
   16#define BOOTLOADER_PCI_H
   23        int (*read_config_byte)(
unsigned char,
unsigned char,
   24                               unsigned char, uint8_t *);
   25        int (*read_config_word)(
unsigned char,
unsigned char,
   26                               unsigned char, uint16_t *);
   27        int (*read_config_dword)(
unsigned char,
unsigned char,
   28                               unsigned char, uint32_t *);
   29        int (*write_config_byte)(
unsigned char,
unsigned char,
   30                               unsigned char, uint8_t);
   31        int (*write_config_word)(
unsigned char,
unsigned char,
   32                               unsigned char, uint16_t);
   33        int (*write_config_dword)(
unsigned char,
unsigned char,
   34                               unsigned char, uint32_t);
   47    struct proc_dir_entry *procent;
   50    unsigned short  vendor;
   51    unsigned short  device;
   53    unsigned int    hdr_type;
   54    unsigned int    master : 1;
   71    unsigned long   base_address[6];
   72    unsigned long   rom_address;
   84    struct proc_dir_entry *procdir;
   87    unsigned char   primary;
   88    unsigned char   secondary;
   89    unsigned char   subordinate;
   93extern struct pci_dev   *pci_devices;
