RTEMS 6.1
drvmgr_bus Struct Reference
#include <drvmgr.h>
int obj_type
unsigned char bus_type
unsigned char depth
struct drvmgr_busnext
struct drvmgr_devdev
void * priv
struct drvmgr_devchildren
struct drvmgr_bus_opsops
struct drvmgr_funcfuncs
int dev_cnt
struct drvmgr_bus_resreslist
struct drvmgr_map_entrymaps_up
struct drvmgr_map_entrymaps_down
int level
int state
int error
Bus information. Describes a bus.
Field Documentation
◆ bus_type
unsigned char drvmgr_bus::bus_type
Type of bus
◆ children
struct drvmgr_dev* drvmgr_bus::children
Hardware devices on this bus
◆ depth
unsigned char drvmgr_bus::depth
Bus level distance from root bus
◆ dev
struct drvmgr_dev* drvmgr_bus::dev
Bus device, the hardware...
◆ dev_cnt
int drvmgr_bus::dev_cnt
Number of devices this bus has
◆ error
int drvmgr_bus::error
Return code from bus->ops->initN()
◆ funcs
struct drvmgr_func* drvmgr_bus::funcs
Extra operations
◆ level
int drvmgr_bus::level
Initialization Level of Bus
◆ maps_down
struct drvmgr_map_entry* drvmgr_bus::maps_down
Map Translation, array of address spaces downstreams to Hardware
◆ maps_up
struct drvmgr_map_entry* drvmgr_bus::maps_up
Map Translation, array of address spaces upstreams to CPU
◆ next
struct drvmgr_bus* drvmgr_bus::next
Next Bus
◆ obj_type
int drvmgr_bus::obj_type
DRVMGR_OBJ_BUS
◆ ops
struct drvmgr_bus_ops* drvmgr_bus::ops
Bus operations supported by this bus driver
◆ priv
void* drvmgr_bus::priv
Private data structure used by BUS driver
◆ reslist
struct drvmgr_bus_res* drvmgr_bus::reslist
Bus resources, head of a linked list of resources.
◆ state
int drvmgr_bus::state
Init State of Bus, BUS_STATE_*
