RTEMS 6.1
drvmgr.h
2
9/*
10 * COPYRIGHT (c) 2009 Cobham Gaisler AB.
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34#ifndef _DRIVER_MANAGER_H_
35#define _DRIVER_MANAGER_H_
36
37#include <rtems.h>
38#include <drvmgr/drvmgr_list.h>
39#include <stdint.h>
41#include <rtems/score/smpimpl.h>
42
43#ifdef __cplusplus
44extern "C" {
45#endif
46
47/*** Configure Driver manager ***/
48
49/* Define the number of initialization levels of device drivers */
50#define DRVMGR_LEVEL_MAX 4
51
52/* Default to use semahpores for protection. Initialization works without
53 * locks and after initialization too if devices are not removed.
54 */
55#ifndef DRVMGR_USE_LOCKS
56#define DRVMGR_USE_LOCKS 1
57#endif
58
59struct drvmgr_dev; /* Device */
60struct drvmgr_bus; /* Bus */
61struct drvmgr_drv; /* Driver */
62
63/*** List Interface shortcuts ***/
64#define BUS_LIST_HEAD(list) LIST_HEAD(list, struct drvmgr_bus)
65#define BUS_LIST_TAIL(list) LIST_TAIL(list, struct drvmgr_bus)
66#define DEV_LIST_HEAD(list) LIST_HEAD(list, struct drvmgr_dev)
67#define DEV_LIST_TAIL(list) LIST_TAIL(list, struct drvmgr_dev)
68#define DRV_LIST_HEAD(list) LIST_HEAD(list, struct drvmgr_drv)
69#define DRV_LIST_TAIL(list) LIST_TAIL(list, struct drvmgr_drv)
70
71/*** Bus indentification ***/
72#define DRVMGR_BUS_TYPE_NONE 0 /* Not a valid bus */
73#define DRVMGR_BUS_TYPE_ROOT 1 /* Hard coded bus */
74#define DRVMGR_BUS_TYPE_PCI 2 /* PCI bus */
75#define DRVMGR_BUS_TYPE_AMBAPP 3 /* AMBA Plug & Play bus */
76#define DRVMGR_BUS_TYPE_LEON2_AMBA 4 /* LEON2 hardcoded bus */
77#define DRVMGR_BUS_TYPE_AMBAPP_DIST 5 /* Distibuted AMBA Plug & Play bus accessed using a communication interface */
78#define DRVMGR_BUS_TYPE_SPW_RMAP 6 /* SpaceWire Network bus */
79#define DRVMGR_BUS_TYPE_AMBAPP_RMAP 7 /* SpaceWire RMAP accessed AMBA Plug & Play bus */
80
81enum {
82 DRVMGR_OBJ_NONE = 0,
83 DRVMGR_OBJ_DRV = 1,
84 DRVMGR_OBJ_BUS = 2,
85 DRVMGR_OBJ_DEV = 3,
86};
87
88/*** Driver indentification ***
89 *
90 * 64-bit identification integer definition
91 * * Bus ID 8-bit [7..0]
92 * * Reserved 8-bit field [63..56]
93 * * Device ID specific for bus type 48-bit [55..8] (Different buses have
94 * different unique identifications for hardware/driver.)
95 *
96 * ID Rules
97 * * A root bus driver must always have device ID set to 0. There can only by
98 * one root bus driver for a certain bus type.
99 * * A Driver ID must identify a unique hardware core
100 *
101 */
102
103/* Bus ID Mask */
104#define DRIVER_ID_BUS_MASK 0x00000000000000FFULL
105
106/* Reserved Mask for future use */
107#define DRIVER_ID_RSV_MASK 0xFF00000000000000ULL
108
109/* Reserved Mask for future use */
110#define DRIVER_ID_DEV_MASK 0x00FFFFFFFFFFFF00ULL
111
112/* Set Bus ID Mask. */
113#define DRIVER_ID(busid, devid) ((unsigned long long) \
114 ((((unsigned long long)(devid) << 8) & DRIVER_ID_DEV_MASK) | \
115 ((unsigned long long)(busid) & DRIVER_ID_BUS_MASK)))
116
117/* Get IDs */
118#define DRIVER_BUSID_GET(id) ((unsigned long long)(id) & DRIVER_ID_BUS_MASK)
119#define DRIVER_DEVID_GET(id) (((unsigned long long)(id) & DRIVER_ID_DEV_MASK) >> 8)
120
121#define DRIVER_ROOTBUS_ID(bus_type) DRIVER_ID(bus_type, 0)
122
123/*** Root Bus drivers ***/
124
125/* Generic Hard coded Root bus: Driver ID */
126#define DRIVER_ROOT_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_ROOT)
127
128/* PCI Plug & Play bus: Driver ID */
129#define DRIVER_PCIBUS_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_PCI)
130
131/* AMBA Plug & Play bus: Driver ID */
132#define DRIVER_GRLIB_AMBAPP_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_AMBAPP)
133
134/* AMBA Hard coded bus: Driver ID */
135#define DRIVER_LEON2_AMBA_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_LEON2_AMBA)
136
137/* Distributed AMBA Plug & Play bus: Driver ID */
138#define DRIVER_AMBAPP_DIST_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_AMBAPP_DIST)
139
147};
148
149/* Interrupt Service Routine (ISR) */
150typedef void (*drvmgr_isr)(void *arg);
151
154 /* Functions used internally within driver manager */
155 int (*init[DRVMGR_LEVEL_MAX])(struct drvmgr_bus *);
156 int (*remove)(struct drvmgr_bus *);
157 int (*unite)(struct drvmgr_drv *, struct drvmgr_dev *);
159 /* Functions called indirectly from drivers */
160 int (*int_register)(struct drvmgr_dev *, int index, const char *info, drvmgr_isr isr, void *arg);
161 int (*int_unregister)(struct drvmgr_dev *, int index, drvmgr_isr isr, void *arg);
162 int (*int_clear)(struct drvmgr_dev *, int index);
163 int (*int_mask)(struct drvmgr_dev *, int index);
164 int (*int_unmask)(struct drvmgr_dev *, int index);
165#ifdef RTEMS_SMP
166 int (*int_set_affinity)(struct drvmgr_dev *, int index,
167 const Processor_mask *cpus);
168#endif
169
170 /* Get Parameters */
171 int (*get_params)(struct drvmgr_dev *, struct drvmgr_bus_params *);
172 /* Get Frequency of Bus */
173 int (*get_freq)(struct drvmgr_dev*, int, unsigned int*);
177 void (*get_info_dev)(struct drvmgr_dev *,
178 void (*print)(void *p, char *str), void *p);
179};
180#define BUS_OPS_NUM (sizeof(struct drvmgr_bus_ops)/sizeof(void (*)(void)))
181
183 int funcid;
184 void *func;
185};
186#define DRVMGR_FUNC(_ID_, _FUNC_) {(int)(_ID_), (void *)(_FUNC_)}
187#define DRVMGR_FUNC_END {0, NULL}
188
189/*** Resource definitions ***
190 *
191 * Overview of structures:
192 * All bus resources entries (_bus_res) are linked together per bus
193 * (bus_info->reslist). One bus resource entry has a pointer to an array of
194 * driver resources (_drv_res). One driver resouces is made out of an array
195 * of keys (drvmgr_key). All keys belongs to the same driver and harwdare
196 * device. Each key has a Name, Type ID and Data interpreted differently
197 * depending on the Type ID (union drvmgr_key_value).
198 *
199 */
200
201/* Key Data Types */
202enum drvmgr_kt {
203 DRVMGR_KT_ANY = -1,
204 DRVMGR_KT_NONE = 0,
205 DRVMGR_KT_INT = 1,
206 DRVMGR_KT_STRING = 2,
207 DRVMGR_KT_POINTER = 3,
208};
209
210#define DRVMGR_KEY_EMPTY {NULL, DRVMGR_KT_NONE, {0}}
211#define DRVMGR_RES_EMPTY {0, 0, NULL}
212#define MMAP_EMPTY {0, 0, 0}
213
216 unsigned int i;
217 char *str;
218 void *ptr;
219};
220
221/* One key. One Value. Holding information relevant to the driver. */
223 char *key_name; /* Name of key */
224 enum drvmgr_kt key_type; /* How to interpret key_value */
225 union drvmgr_key_value key_value; /* The value or pointer to value */
226};
227
232 uint64_t drv_id;
234 struct drvmgr_key *keys;
235};
236
241};
242
250 char *name;
251 unsigned int size;
252 char *from_adr;
254 char *to_adr;
256};
257#define DRVMGR_TRANSLATE_ONE2ONE NULL
258#define DRVMGR_TRANSLATE_NO_BRIDGE ((void *)1) /* No bridge, error */
259
263 unsigned char bus_type;
264 unsigned char depth;
265 struct drvmgr_bus *next;
266 struct drvmgr_dev *dev;
267 void *priv;
276 /* Bus status */
277 int level;
278 int state;
279 int error;
280};
281
282/* States of a bus */
283#define BUS_STATE_INIT_FAILED 0x00000001 /* Initialization Failed */
284#define BUS_STATE_LIST_INACTIVE 0x00001000 /* In inactive bus list */
285#define BUS_STATE_DEPEND_FAILED 0x00000004 /* Device init failed */
286
287/* States of a device */
288#define DEV_STATE_INIT_FAILED 0x00000001 /* Initialization Failed */
289#define DEV_STATE_INIT_DONE 0x00000002 /* All init levels completed */
290#define DEV_STATE_DEPEND_FAILED 0x00000004 /* Parent Bus init failed */
291#define DEV_STATE_UNITED 0x00000100 /* Device United with Device Driver */
292#define DEV_STATE_REMOVED 0x00000200 /* Device has been removed (unregistered) */
293#define DEV_STATE_IGNORED 0x00000400 /* Device was ignored according to user's request, the device
294 * was never reported to it's driver (as expected).
295 */
296#define DEV_STATE_LIST_INACTIVE 0x00001000 /* In inactive device list */
301 struct drvmgr_dev *next;
302 struct drvmgr_dev *next_in_bus;
305 struct drvmgr_drv *drv;
307 short minor_drv;
308 short minor_bus;
309 char *name;
310 void *priv;
311 void *businfo;
312 struct drvmgr_bus *bus;
314 /* Device Status */
315 unsigned int state;
316 int level;
317 int error;
318};
322 int (*init[DRVMGR_LEVEL_MAX])(struct drvmgr_dev *);
323 int (*remove)(struct drvmgr_dev *);
324 int (*info)(struct drvmgr_dev *, void (*print)(void *p, char *str), void *p, int, char *argv[]);
325};
326#define DRVMGR_OPS_NUM(x) (sizeof(x)/sizeof(void (*)(void)))
331 struct drvmgr_drv *next;
332 struct drvmgr_dev *dev;
334 uint64_t drv_id;
335 char *name;
339 unsigned int dev_cnt;
340 unsigned int dev_priv_size;
341};
342
347typedef void (*drvmgr_drv_reg_func)(void);
348
349/*** DRIVER | DEVICE | BUS FUNCTIONS ***/
350
351/* Return Codes */
352enum {
353 DRVMGR_OK = 0, /* Sucess */
354 DRVMGR_NOMEM = 1, /* Memory allocation error */
355 DRVMGR_EIO = 2, /* I/O error */
356 DRVMGR_EINVAL = 3, /* Invalid parameter */
357 DRVMGR_ENOSYS = 4,
358 DRVMGR_TIMEDOUT = 5, /* Operation timeout error */
359 DRVMGR_EBUSY = 6,
360 DRVMGR_ENORES = 7, /* Not enough resources */
361 DRVMGR_FAIL = -1 /* Unspecified failure */
362};
363
368extern void _DRV_Manager_initialization(void);
369
375extern void _DRV_Manager_init_level(int level);
376
382extern int drvmgr_init(void);
383
384/* Take registered buses and devices into the correct init level,
385 * this function is called from _init_level() so normally
386 * we don't need to call it directly.
387 */
388extern void drvmgr_init_update(void);
389
391extern int drvmgr_root_drv_register(struct drvmgr_drv *drv);
392
394extern int drvmgr_drv_register(struct drvmgr_drv *drv);
395
397extern int drvmgr_dev_register(struct drvmgr_dev *dev);
398
409extern int drvmgr_dev_unregister(struct drvmgr_dev *dev);
410
412extern int drvmgr_bus_register(struct drvmgr_bus *bus);
413
415extern int drvmgr_bus_unregister(struct drvmgr_bus *bus);
416
422extern int drvmgr_children_unregister(struct drvmgr_bus *bus);
423
424/* Separate a device from the driver it has been united with */
425extern int drvmgr_dev_drv_separate(struct drvmgr_dev *dev);
426
433extern int drvmgr_alloc_dev(struct drvmgr_dev **pdev, int extra);
434
441extern int drvmgr_alloc_bus(struct drvmgr_bus **pbus, int extra);
442
443/*** DRIVER RESOURCE FUNCTIONS ***/
444
451extern void drvmgr_bus_res_add(struct drvmgr_bus *bus,
452 struct drvmgr_bus_res *bres);
453
460extern int drvmgr_keys_get(struct drvmgr_dev *dev, struct drvmgr_key **keys);
461
468extern struct drvmgr_key *drvmgr_key_get(struct drvmgr_key *keys, char *key_name);
469
483 struct drvmgr_key *keys,
484 char *key_name,
485 enum drvmgr_kt key_type);
486
500 struct drvmgr_dev *dev,
501 char *key_name,
502 enum drvmgr_kt key_type);
503
504/*** DRIVER INTERACE USED TO REQUEST INFORMATION/SERVICES FROM BUS DRIVER ***/
505
507static inline struct drvmgr_bus *drvmgr_get_parent(
508 struct drvmgr_dev *dev)
509{
510 if (dev)
511 return dev->parent;
512 else
513 return NULL;
514}
515
517static inline struct drvmgr_drv *drvmgr_get_drv(struct drvmgr_dev *dev)
518{
519 if (dev)
520 return dev->drv;
521 else
522 return NULL;
523}
524
537#define DRVMGR_FED_BF 1 /* Breadth-first search */
538#define DRVMGR_FED_DF 0 /* Depth first search */
539extern intptr_t drvmgr_for_each_dev(
540 intptr_t (*func)(struct drvmgr_dev *dev, void *arg),
541 void *arg,
542 int options);
543
552extern int drvmgr_get_dev(
553 struct drvmgr_drv *drv,
554 int minor,
555 struct drvmgr_dev **pdev);
556
563extern int drvmgr_freq_get(
564 struct drvmgr_dev *dev,
565 int options,
566 unsigned int *freq_hz);
567
569extern int drvmgr_on_rootbus(struct drvmgr_dev *dev);
570
577extern int drvmgr_get_dev_prefix(struct drvmgr_dev *dev, char *dev_prefix);
578
593 struct drvmgr_dev *dev,
594 int index,
595 const char *info,
596 drvmgr_isr isr,
597 void *arg);
598
610 struct drvmgr_dev *dev,
611 int index,
612 drvmgr_isr isr,
613 void *arg);
614
624extern int drvmgr_interrupt_clear(
625 struct drvmgr_dev *dev,
626 int index);
627
638extern int drvmgr_interrupt_unmask(
639 struct drvmgr_dev *dev,
640 int index);
641
650extern int drvmgr_interrupt_mask(
651 struct drvmgr_dev *dev,
652 int index);
653
662#ifdef RTEMS_SMP
663extern int drvmgr_interrupt_set_affinity(
664 struct drvmgr_dev *dev,
665 int index,
666 const Processor_mask *cpus);
667#endif
670enum drvmgr_tr_opts {
671 /* Translate CPU RAM Address (input) to DMA unit accessible address
672 * (output), this is an upstreams translation in reverse order.
673 *
674 * Typical Usage:
675 * It is common to translate a CPU accessible RAM address to an
676 * address that DMA units can access over bridges.
677 */
678 CPUMEM_TO_DMA = 0x0,
679
680 /* Translate DMA Unit Accessible address mapped to CPU RAM (input) to
681 * CPU accessible address (output). This is an upstreams translation.
682 *
683 * Typical Usage (not often used):
684 * The DMA unit descriptors contain pointers to DMA buffers located at
685 * CPU RAM addresses that the DMA unit can access, the CPU processes
686 * the descriptors and want to access the data but a translation back
687 * to CPU address is required.
688 */
689 CPUMEM_FROM_DMA = 0x1,
690
691 /* Translate DMA Memory Address (input) to CPU accessible address
692 * (output), this is a downstreams translation in reverse order.
693 *
694 * Typical Usage:
695 * A PCI network card puts packets into its memory not doing DMA over
696 * PCI, in order for the CPU to access them the PCI address must be
697 * translated.
698 */
699 DMAMEM_TO_CPU = 0x2,
700
701 /* Translate CPU accessible address (input) mapped to DMA Memory Address
702 * to DMA Unit accessible address (output). This is a downstreams
703 * translation.
704 */
705 DMAMEM_FROM_CPU = 0x3,
706};
707#define DRVMGR_TR_REVERSE 0x1 /* do reverse translation direction order */
708#define DRVMGR_TR_PATH 0x2 /* 0x0=down-stream 0x2=up-stream address path */
709
746extern unsigned int drvmgr_translate(
747 struct drvmgr_dev *dev,
748 unsigned int options,
749 void *src_address,
750 void **dst_address);
751
752/* Translate addresses between buses, used internally to implement
753 * drvmgr_translate. Function is not limited to translate from/to root bus
754 * where CPU is resident, however buses must be on a straight path relative
755 * to each other (parent of parent of parent and so on).
756 *
757 * \param from src_address is given for this bus
758 * \param to src_address is translated to this bus
759 * \param reverse Selects translation method, if map entries are used in
760 * the reverse order (map_up->to is used as map_up->from)
761 * \param src_address Address to be translated
762 * \param dst_address Translated address is stored here on success (return=0)
763 *
764 * Returns 0 if unable to translate. The remaining length from the given
765 * address of the map is returned on success and the result is stored into
766 * *dst_address. For example if a map starts at 0x40000000 of size 0x100000
767 * the result will be 0x40000 if the address was translated into 0x400C0000.
768 * If dev is on root-bus no translation is performed 0xffffffff is returned.
769 * and src_address is stored in *dst_address.
770 */
771extern unsigned int drvmgr_translate_bus(
772 struct drvmgr_bus *from,
773 struct drvmgr_bus *to,
774 int reverse,
775 void *src_address,
776 void **dst_address);
777
778/* Calls drvmgr_translate() to translate an address range and checks the result,
779 * a printout is generated if the check fails. All parameters are passed on to
780 * drvmgr_translate() except for size, see paramters of drvmgr_translate().
781 *
782 * If size=0 only the starting address is not checked.
783 *
784 * If mapping failes a non-zero result is returned.
785 */
786extern int drvmgr_translate_check(
787 struct drvmgr_dev *dev,
788 unsigned int options,
789 void *src_address,
790 void **dst_address,
791 unsigned int size);
792
797extern int drvmgr_func_get(void *obj, int funcid, void **func);
798
800extern int drvmgr_func_call(void *obj, int funcid, void *a, void *b, void *c, void *d);
801
802/* Builds a Function ID.
803 *
804 * Used to request optional functions by a bus or device driver
805 */
806#define DRVMGR_FUNCID(major, minor) ((((major) & 0xfff) << 20) | ((minor) & 0xfffff))
807#define DRVMGR_FUNCID_NONE 0
808#define DRVMGR_FUNCID_END DRVMGR_FUNCID(DRVMGR_FUNCID_NONE, 0)
809
810/* Major Function ID. Most significant 12-bits. */
811enum {
812 FUNCID_NONE = 0x000,
813 FUNCID_RW = 0x001, /* Read/Write functions */
814};
815
816/* Select Sub-Function Read/Write function by ID */
817#define RW_SIZE_1 0x00001 /* Access Size */
818#define RW_SIZE_2 0x00002
819#define RW_SIZE_4 0x00004
820#define RW_SIZE_8 0x00008
821#define RW_SIZE_ANY 0x00000
822#define RW_SIZE(id) ((unsigned int)(id) & 0xf)
823
824#define RW_DIR_ANY 0x00000 /* Access Direction */
825#define RW_READ 0x00000 /* Read */
826#define RW_WRITE 0x00010 /* Write */
827#define RW_SET 0x00020 /* Write with same value (memset) */
828#define RW_DIR(id) (((unsigned int)(id) >> 4) & 0x3)
829
830#define RW_RAW 0x00000 /* Raw access - no swapping (machine default) */
831#define RW_LITTLE 0x00040 /* Little Endian */
832#define RW_BIG 0x00080 /* Big Endian */
833#define RW_ENDIAN(id) (((unsigned int)(id) >> 6) & 0x3)
834
835#define RW_TYPE_ANY 0x00000 /* Access type */
836#define RW_REG 0x00100
837#define RW_MEM 0x00200
838#define RW_MEMREG 0x00300
839#define RW_CFG 0x00400
840#define RW_TYPE(id) (((unsigned int)(id) >> 8) & 0xf)
841
842#define RW_ARG 0x01000 /* Optional Argument */
843#define RW_ERR 0x02000 /* Optional Error Handler */
844
845/* Build a Read/Write function ID */
846#define DRVMGR_RWFUNC(minor) DRVMGR_FUNCID(FUNCID_RW, minor)
847
848/* Argument to Read/Write functions, the "void *arg" pointer is returned by
849 * RW_ARG. If NULL is returned no argument is needed.
850 */
851struct drvmgr_rw_arg {
852 void *arg;
853 struct drvmgr_dev *dev;
854};
855
856/* Standard Read/Write function types */
857typedef uint8_t (*drvmgr_r8)(uint8_t *srcadr);
858typedef uint16_t (*drvmgr_r16)(uint16_t *srcadr);
859typedef uint32_t (*drvmgr_r32)(uint32_t *srcadr);
860typedef uint64_t (*drvmgr_r64)(uint64_t *srcadr);
861typedef void (*drvmgr_w8)(uint8_t *dstadr, uint8_t data);
862typedef void (*drvmgr_w16)(uint16_t *dstadr, uint16_t data);
863typedef void (*drvmgr_w32)(uint32_t *dstadr, uint32_t data);
864typedef void (*drvmgr_w64)(uint64_t *dstadr, uint64_t data);
865/* READ/COPY a memory area located on bus into CPU memory.
866 * From 'src' (remote) to the destination 'dest' (local), n=number of bytes
867 */
868typedef int (*drvmgr_rmem)(void *dest, const void *src, int n);
869/* WRITE/COPY a user buffer located in CPU memory to a location on the bus.
870 * From 'src' (local) to the destination 'dest' (remote), n=number of bytes
871 */
872typedef int (*drvmgr_wmem)(void *dest, const void *src, int n);
873/* Set a memory area to the byte value given in c, see LIBC memset(). Memset is
874 * implemented by calling wmem() multiple times with a "large" buffer.
875 */
876typedef int (*drvmgr_memset)(void *dstadr, int c, size_t n);
877
878/* Read/Write function types with additional argument */
879typedef uint8_t (*drvmgr_r8_arg)(uint8_t *srcadr, void *a);
880typedef uint16_t (*drvmgr_r16_arg)(uint16_t *srcadr, void *a);
881typedef uint32_t (*drvmgr_r32_arg)(uint32_t *srcadr, void *a);
882typedef uint64_t (*drvmgr_r64_arg)(uint64_t *srcadr, void *a);
883typedef void (*drvmgr_w8_arg)(uint8_t *dstadr, uint8_t data, void *a);
884typedef void (*drvmgr_w16_arg)(uint16_t *dstadr, uint16_t data, void *a);
885typedef void (*drvmgr_w32_arg)(uint32_t *dstadr, uint32_t data, void *a);
886typedef void (*drvmgr_w64_arg)(uint64_t *dstadr, uint64_t data, void *a);
887typedef int (*drvmgr_rmem_arg)(void *dest, const void *src, int n, void *a);
888typedef int (*drvmgr_wmem_arg)(void *dest, const void *src, int n, void *a);
889typedef int (*drvmgr_memset_arg)(void *dstadr, int c, size_t n, void *a);
890
891/* Report an error to the parent bus of the device */
892typedef void (*drvmgr_rw_err)(struct drvmgr_rw_arg *a, struct drvmgr_bus *bus,
893 int funcid, void *adr);
894
895/* Helper function for buses that implement the memset() over wmem() */
896extern void drvmgr_rw_memset(
897 void *dstadr,
898 int c,
899 size_t n,
900 void *a,
901 drvmgr_wmem_arg wmem
902 );
903
904/*** PRINT INFORMATION ABOUT DRIVER MANAGER ***/
905
930extern int drvmgr_for_each_listdev(
931 struct drvmgr_list *devlist,
932 unsigned int state_set_mask,
933 unsigned int state_clr_mask,
934 int (*func)(struct drvmgr_dev *dev, void *arg),
935 void *arg);
936
937/* Print all devices */
938#define PRINT_DEVS_FAILED 0x01 /* Failed during initialization */
939#define PRINT_DEVS_ASSIGNED 0x02 /* Driver assigned */
940#define PRINT_DEVS_UNASSIGNED 0x04 /* Driver not assigned */
941#define PRINT_DEVS_IGNORED 0x08 /* Device ignored on user's request */
942#define PRINT_DEVS_ALL (PRINT_DEVS_FAILED | \
943 PRINT_DEVS_ASSIGNED | \
944 PRINT_DEVS_UNASSIGNED |\
945 PRINT_DEVS_IGNORED)
946
948extern void drvmgr_summary(void);
949
951extern void drvmgr_print_devs(unsigned int options);
952
954extern void drvmgr_print_topo(void);
955
959extern void drvmgr_print_mem(void);
960
961#define OPTION_DEV_GENINFO 0x00000001
962#define OPTION_DEV_BUSINFO 0x00000002
963#define OPTION_DEV_DRVINFO 0x00000004
964#define OPTION_DRV_DEVS 0x00000100
965#define OPTION_BUS_DEVS 0x00010000
966#define OPTION_RECURSIVE 0x01000000
967#define OPTION_INFO_ALL 0xffffffff
968
970extern void drvmgr_info(void *id, unsigned int options);
971
973extern void drvmgr_info_dev(struct drvmgr_dev *dev, unsigned int options);
974
976extern void drvmgr_info_bus(struct drvmgr_bus *bus, unsigned int options);
977
979extern void drvmgr_info_drv(struct drvmgr_drv *drv, unsigned int options);
980
982extern void drvmgr_info_devs_on_bus(struct drvmgr_bus *bus, unsigned int options);
983
985extern void drvmgr_info_devs(unsigned int options);
986
988extern void drvmgr_info_drvs(unsigned int options);
989
991extern void drvmgr_info_buses(unsigned int options);
992
994extern struct drvmgr_drv *drvmgr_drv_by_id(uint64_t id);
995
997extern struct drvmgr_drv *drvmgr_drv_by_name(const char *name);
998
1000extern struct drvmgr_dev *drvmgr_dev_by_name(const char *name);
1001
1002#ifdef __cplusplus
1003}
1004#endif
1005
1006#endif
This header file provides basic definitions used by the API and the implementation.
struct drvmgr_drv * drvmgr_drv_by_id(uint64_t id)
Definition: drvmgr_by_id.c:33
Definition: drvmgr_print.c:116
Definition: drvmgr.c:631
Definition: drvmgr.c:585
int drvmgr_for_each_listdev(struct drvmgr_list *devlist, unsigned int state_set_mask, unsigned int state_clr_mask, int(*func)(struct drvmgr_dev *dev, void *arg), void *arg)
Definition: drvmgr_for_each_list_dev.c:33
Definition: drvmgr_res.c:33
Definition: drvmgr_print.c:394
Definition: drvmgr_func_call.c:32
int drvmgr_interrupt_register(struct drvmgr_dev *dev, int index, const char *info, drvmgr_isr isr, void *arg)
Definition: drvmgr_drvinf.c:98
union drvmgr_key_value * drvmgr_dev_key_get(struct drvmgr_dev *dev, char *key_name, enum drvmgr_kt key_type)
Definition: drvmgr_res.c:108
Definition: drvmgr.c:363
Definition: drvmgr_init.c:34
Definition: drvmgr_drvinf.c:83
Definition: drvmgr.c:334
Definition: drvmgr_print.c:444
Definition: drvmgr_unregister.c:169
int drvmgr_get_dev(struct drvmgr_drv *drv, int minor, struct drvmgr_dev **pdev)
Definition: drvmgr_drvinf.c:46
int drvmgr_interrupt_unmask(struct drvmgr_dev *dev, int index)
Definition: drvmgr_drvinf.c:140
Definition: drvmgr_print.c:125
drvmgr_tr_opts
Definition: drvmgr.h:668
unsigned int drvmgr_translate(struct drvmgr_dev *dev, unsigned int options, void *src_address, void **dst_address)
Definition: drvmgr_translate.c:148
int drvmgr_interrupt_clear(struct drvmgr_dev *dev, int index)
Definition: drvmgr_drvinf.c:130
int drvmgr_freq_get(struct drvmgr_dev *dev, int options, unsigned int *freq_hz)
Definition: drvmgr_drvinf.c:71
Definition: drvmgr_print.c:257
Definition: drvmgr.c:88
Definition: drvmgr_drvinf.c:173
struct drvmgr_key * drvmgr_key_get(struct drvmgr_key *keys, char *key_name)
Definition: drvmgr_res.c:73
Definition: drvmgr.c:612
Definition: drvmgr_unregister.c:62
Definition: drvmgr.c:490
void drvmgr_bus_res_add(struct drvmgr_bus *bus, struct drvmgr_bus_res *bres)
Definition: drvmgr.c:650
Definition: drvmgr_unregister.c:40
Definition: drvmgr_print.c:433
Definition: drvmgr.c:105
struct drvmgr_drv * drvmgr_drv_by_name(const char *name)
Definition: drvmgr_by_name.c:34
Definition: drvmgr_print.c:320
int drvmgr_interrupt_unregister(struct drvmgr_dev *dev, int index, drvmgr_isr isr, void *arg)
Definition: drvmgr_drvinf.c:115
struct drvmgr_dev * drvmgr_dev_by_name(const char *name)
Definition: drvmgr_dev_by_name.c:45
Definition: drvmgr_print.c:201
Definition: drvmgr_func.c:32
void(* drvmgr_drv_reg_func)(void)
Definition: drvmgr.h:345
Definition: drvmgr_print.c:457
Definition: drvmgr_print.c:60
int drvmgr_interrupt_mask(struct drvmgr_dev *dev, int index)
Definition: drvmgr_drvinf.c:150
Definition: drvmgr_print.c:357
Definition: drvmgr_print.c:408
union drvmgr_key_value * drvmgr_key_val_get(struct drvmgr_key *keys, char *key_name, enum drvmgr_kt key_type)
Definition: drvmgr_res.c:91
Linked list help functions used by driver manager.
This header file provides interfaces of the SMP Support which are only used by the implementation.
Definition: drvmgr.h:153
void(* get_info_dev)(struct drvmgr_dev *, void(*print)(void *p, char *str), void *p)
Definition: drvmgr.h:177
int(* unite)(struct drvmgr_drv *, struct drvmgr_dev *)
Definition: drvmgr.h:157
Definition: drvmgr.h:145
char * dev_prefix
Definition: drvmgr.h:146
Definition: drvmgr.h:238
struct drvmgr_drv_res resource[]
Definition: drvmgr.h:240
struct drvmgr_bus_res * next
Definition: drvmgr.h:239
Definition: drvmgr.h:261
struct drvmgr_func * funcs
Definition: drvmgr.h:270
int error
Definition: drvmgr.h:279
int state
Definition: drvmgr.h:278
int obj_type
Definition: drvmgr.h:262
void * priv
Definition: drvmgr.h:267
struct drvmgr_map_entry * maps_down
Definition: drvmgr.h:274
struct drvmgr_dev * dev
Definition: drvmgr.h:266
struct drvmgr_bus_res * reslist
Definition: drvmgr.h:272
unsigned char depth
Definition: drvmgr.h:264
struct drvmgr_bus * next
Definition: drvmgr.h:265
int dev_cnt
Definition: drvmgr.h:271
struct drvmgr_bus_ops * ops
Definition: drvmgr.h:269
struct drvmgr_map_entry * maps_up
Definition: drvmgr.h:273
int level
Definition: drvmgr.h:277
Definition: drvmgr.h:263
struct drvmgr_dev * children
Definition: drvmgr.h:268
Definition: drvmgr.h:297
struct drvmgr_bus * bus
Definition: drvmgr.h:310
int level
Definition: drvmgr.h:314
struct drvmgr_dev * next
Definition: drvmgr.h:299
char * name
Definition: drvmgr.h:307
unsigned int state
Definition: drvmgr.h:313
struct drvmgr_dev * next_in_bus
Definition: drvmgr.h:300
Definition: drvmgr.h:303
void * priv
Definition: drvmgr.h:308
struct drvmgr_dev * next_in_drv
Definition: drvmgr.h:301
struct drvmgr_bus * parent
Definition: drvmgr.h:304
int obj_type
Definition: drvmgr.h:298
int error
Definition: drvmgr.h:315
short minor_drv
Definition: drvmgr.h:305
void * businfo
Definition: drvmgr.h:309
short minor_bus
Definition: drvmgr.h:306
Definition: drvmgr.h:319
int(* info)(struct drvmgr_dev *, void(*print)(void *p, char *str), void *p, int, char *argv[])
Definition: drvmgr.h:322
int(* remove)(struct drvmgr_dev *)
Definition: drvmgr.h:321
Definition: drvmgr.h:231
int minor_bus
Definition: drvmgr.h:233
struct drvmgr_key * keys
Definition: drvmgr.h:234
uint64_t drv_id
Definition: drvmgr.h:232
Definition: drvmgr.h:327
char * name
Definition: drvmgr.h:333
struct drvmgr_drv * next
Definition: drvmgr.h:329
Definition: drvmgr.h:337
struct drvmgr_drv_ops * ops
Definition: drvmgr.h:335
Definition: drvmgr.h:336
Definition: drvmgr.h:338
Definition: drvmgr.h:330
int obj_type
Definition: drvmgr.h:328
uint64_t drv_id
Definition: drvmgr.h:332
int bus_type
Definition: drvmgr.h:334
Definition: drvmgr.h:182
Definition: drvmgr.h:222
Definition: drvmgr_list.h:48
Definition: drvmgr.h:249
unsigned int size
Definition: drvmgr.h:251
char * name
Definition: drvmgr.h:250
char * to_adr
Definition: drvmgr.h:254
char * from_adr
Definition: drvmgr.h:252
Definition: drvmgr.h:849
unsigned p
Definition: tte.h:17
Definition: drvmgr.h:215
unsigned int i
Definition: drvmgr.h:216
char * str
Definition: drvmgr.h:217
void * ptr
Definition: drvmgr.h:218
