RTEMS 6.1
drvmgr_map_entry Struct Reference
#include <drvmgr.h>
char * name
unsigned int size
char * from_adr
char * to_adr
MAP entry. Describes an linear address space translation. Untranslated Start, Translated Start and length.
Used by bus drivers to describe the address translation needed for the translation driver interface.
Field Documentation
◆ from_adr
char* drvmgr_map_entry::from_adr
Start address of access window used to reach into remote bus
◆ name
char* drvmgr_map_entry::name
Map Name
◆ size
unsigned int drvmgr_map_entry::size
Size of map window
◆ to_adr
char* drvmgr_map_entry::to_adr
Start address of remote system address range
