RTEMS 6.1
__USART_HandleTypeDef Struct Reference
USART handle Structure definition. More...
#include <stm32h7xx_hal_usart.h>
USART_TypeDefInstance
USART_InitTypeDef Init
const uint8_t * pTxBuffPtr
uint16_t TxXferSize
__IO uint16_t TxXferCount
uint8_t * pRxBuffPtr
uint16_t RxXferSize
__IO uint16_t RxXferCount
uint16_t Mask
uint16_t NbRxDataToProcess
uint16_t NbTxDataToProcess
uint32_t SlaveMode
uint32_t FifoMode
void(* RxISR )(struct __USART_HandleTypeDef *husart)
void(* TxISR )(struct __USART_HandleTypeDef *husart)
DMA_HandleTypeDefhdmatx
DMA_HandleTypeDefhdmarx
HAL_LockTypeDef Lock
__IO HAL_USART_StateTypeDef State
__IO uint32_t ErrorCode
Field Documentation
◆ ErrorCode
__IO uint32_t __USART_HandleTypeDef::ErrorCode
USART Error code
◆ FifoMode
uint32_t __USART_HandleTypeDef::FifoMode
Specifies if the FIFO mode will be used. This parameter can be a value of USARTEx FIFO mode.
◆ hdmarx
DMA_HandleTypeDef* __USART_HandleTypeDef::hdmarx
USART Rx DMA Handle parameters
◆ hdmatx
DMA_HandleTypeDef* __USART_HandleTypeDef::hdmatx
USART Tx DMA Handle parameters
◆ Init
USART_InitTypeDef __USART_HandleTypeDef::Init
USART communication parameters
◆ Instance
USART_TypeDef* __USART_HandleTypeDef::Instance
USART registers base address
◆ Lock
HAL_LockTypeDef __USART_HandleTypeDef::Lock
Locking object
◆ Mask
uint16_t __USART_HandleTypeDef::Mask
USART Rx RDR register mask
◆ NbRxDataToProcess
uint16_t __USART_HandleTypeDef::NbRxDataToProcess
Number of data to process during RX ISR execution
◆ NbTxDataToProcess
uint16_t __USART_HandleTypeDef::NbTxDataToProcess
Number of data to process during TX ISR execution
◆ pRxBuffPtr
uint8_t* __USART_HandleTypeDef::pRxBuffPtr
Pointer to USART Rx transfer Buffer
◆ pTxBuffPtr
const uint8_t* __USART_HandleTypeDef::pTxBuffPtr
Pointer to USART Tx transfer Buffer
◆ RxISR
void(* __USART_HandleTypeDef::RxISR) (struct __USART_HandleTypeDef *husart)
Function pointer on Rx IRQ handler
◆ RxXferCount
__IO uint16_t __USART_HandleTypeDef::RxXferCount
USART Rx Transfer Counter
◆ RxXferSize
uint16_t __USART_HandleTypeDef::RxXferSize
USART Rx Transfer size
◆ SlaveMode
uint32_t __USART_HandleTypeDef::SlaveMode
Enable/Disable USART SPI Slave Mode. This parameter can be a value of USARTEx Synchronous Slave mode enable
◆ State
__IO HAL_USART_StateTypeDef __USART_HandleTypeDef::State
USART communication state
◆ TxISR
void(* __USART_HandleTypeDef::TxISR) (struct __USART_HandleTypeDef *husart)
Function pointer on Tx IRQ handler
◆ TxXferCount
__IO uint16_t __USART_HandleTypeDef::TxXferCount
USART Tx Transfer Counter
◆ TxXferSize
uint16_t __USART_HandleTypeDef::TxXferSize
USART Tx Transfer size
