RTEMS 6.1
USART_InitTypeDef Struct Reference
USART Init Structure definition. More...
#include <stm32h7xx_hal_usart.h>
uint32_t BaudRate
uint32_t WordLength
uint32_t StopBits
uint32_t Parity
uint32_t Mode
uint32_t CLKPolarity
uint32_t CLKPhase
uint32_t CLKLastBit
uint32_t ClockPrescaler
Field Documentation
◆ BaudRate
uint32_t USART_InitTypeDef::BaudRate
This member configures the Usart communication baud rate. The baud rate is computed using the following formula: Baud Rate Register[15:4] = ((2 * fclk_pres) / ((huart->Init.BaudRate)))[15:4] Baud Rate Register[3] = 0 Baud Rate Register[2:0] = (((2 * fclk_pres) / ((huart->Init.BaudRate)))[3:0]) >> 1 where fclk_pres is the USART input clock frequency (fclk) divided by a prescaler.
Note
Oversampling by 8 is systematically applied to achieve high baud rates.
◆ CLKLastBit
uint32_t USART_InitTypeDef::CLKLastBit
Specifies whether the clock pulse corresponding to the last transmitted data bit (MSB) has to be output on the SCLK pin in synchronous mode. This parameter can be a value of USART Last Bit.
◆ CLKPhase
uint32_t USART_InitTypeDef::CLKPhase
Specifies the clock transition on which the bit capture is made. This parameter can be a value of USART Clock Phase.
◆ CLKPolarity
uint32_t USART_InitTypeDef::CLKPolarity
Specifies the steady state of the serial clock. This parameter can be a value of USART Clock Polarity.
◆ ClockPrescaler
uint32_t USART_InitTypeDef::ClockPrescaler
Specifies the prescaler value used to divide the USART clock source. This parameter can be a value of USART Clock Prescaler.
◆ Mode
uint32_t USART_InitTypeDef::Mode
Specifies whether the Receive or Transmit mode is enabled or disabled. This parameter can be a value of USART Mode.
◆ Parity
uint32_t USART_InitTypeDef::Parity
Specifies the parity mode. This parameter can be a value of USART Parity
Note
When parity is enabled, the computed parity is inserted at the MSB position of the transmitted data (9th bit when the word length is set to 9 data bits; 8th bit when the word length is set to 8 data bits).
◆ StopBits
uint32_t USART_InitTypeDef::StopBits
Specifies the number of stop bits transmitted. This parameter can be a value of USART Number of Stop Bits.
◆ WordLength
uint32_t USART_InitTypeDef::WordLength
Specifies the number of data bits transmitted or received in a frame. This parameter can be a value of USARTEx Word Length.
