RTEMS 6.1
__SMARTCARD_HandleTypeDef Struct Reference
SMARTCARD handle Structure definition. More...
#include <stm32h7xx_hal_smartcard.h>
USART_TypeDefInstance
SMARTCARD_InitTypeDef Init
SMARTCARD_AdvFeatureInitTypeDef AdvancedInit
const uint8_t * pTxBuffPtr
uint16_t TxXferSize
__IO uint16_t TxXferCount
uint8_t * pRxBuffPtr
uint16_t RxXferSize
__IO uint16_t RxXferCount
uint16_t NbRxDataToProcess
uint16_t NbTxDataToProcess
uint32_t FifoMode
void(* RxISR )(struct __SMARTCARD_HandleTypeDef *huart)
void(* TxISR )(struct __SMARTCARD_HandleTypeDef *huart)
DMA_HandleTypeDefhdmatx
DMA_HandleTypeDefhdmarx
HAL_LockTypeDef Lock
__IO HAL_SMARTCARD_StateTypeDef gState
__IO HAL_SMARTCARD_StateTypeDef RxState
__IO uint32_t ErrorCode
Field Documentation
◆ AdvancedInit
SMARTCARD_AdvFeatureInitTypeDef __SMARTCARD_HandleTypeDef::AdvancedInit
SmartCard advanced features initialization parameters
◆ ErrorCode
__IO uint32_t __SMARTCARD_HandleTypeDef::ErrorCode
SmartCard Error code
◆ FifoMode
uint32_t __SMARTCARD_HandleTypeDef::FifoMode
Specifies if the FIFO mode will be used. This parameter can be a value of SMARTCARD FIFO mode.
◆ gState
__IO HAL_SMARTCARD_StateTypeDef __SMARTCARD_HandleTypeDef::gState
SmartCard state information related to global Handle management and also related to Tx operations. This parameter can be a value of HAL_SMARTCARD_StateTypeDef
◆ hdmarx
DMA_HandleTypeDef* __SMARTCARD_HandleTypeDef::hdmarx
SmartCard Rx DMA Handle parameters
◆ hdmatx
DMA_HandleTypeDef* __SMARTCARD_HandleTypeDef::hdmatx
SmartCard Tx DMA Handle parameters
◆ Init
SMARTCARD_InitTypeDef __SMARTCARD_HandleTypeDef::Init
SmartCard communication parameters
◆ Instance
USART_TypeDef* __SMARTCARD_HandleTypeDef::Instance
USART registers base address
◆ Lock
HAL_LockTypeDef __SMARTCARD_HandleTypeDef::Lock
Locking object
◆ NbRxDataToProcess
uint16_t __SMARTCARD_HandleTypeDef::NbRxDataToProcess
Number of data to process during RX ISR execution
◆ NbTxDataToProcess
uint16_t __SMARTCARD_HandleTypeDef::NbTxDataToProcess
Number of data to process during TX ISR execution
◆ pRxBuffPtr
uint8_t* __SMARTCARD_HandleTypeDef::pRxBuffPtr
Pointer to SmartCard Rx transfer Buffer
◆ pTxBuffPtr
const uint8_t* __SMARTCARD_HandleTypeDef::pTxBuffPtr
Pointer to SmartCard Tx transfer Buffer
◆ RxISR
void(* __SMARTCARD_HandleTypeDef::RxISR) (struct __SMARTCARD_HandleTypeDef *huart)
Function pointer on Rx IRQ handler
◆ RxState
__IO HAL_SMARTCARD_StateTypeDef __SMARTCARD_HandleTypeDef::RxState
SmartCard state information related to Rx operations. This parameter can be a value of HAL_SMARTCARD_StateTypeDef
◆ RxXferCount
__IO uint16_t __SMARTCARD_HandleTypeDef::RxXferCount
SmartCard Rx Transfer Counter
◆ RxXferSize
uint16_t __SMARTCARD_HandleTypeDef::RxXferSize
SmartCard Rx Transfer size
◆ TxISR
void(* __SMARTCARD_HandleTypeDef::TxISR) (struct __SMARTCARD_HandleTypeDef *huart)
Function pointer on Tx IRQ handler
◆ TxXferCount
__IO uint16_t __SMARTCARD_HandleTypeDef::TxXferCount
SmartCard Tx Transfer Counter
◆ TxXferSize
uint16_t __SMARTCARD_HandleTypeDef::TxXferSize
SmartCard Tx Transfer size
