RTEMS 6.1
SMARTCARD_InitTypeDef Struct Reference
SMARTCARD Init Structure definition. More...
#include <stm32h7xx_hal_smartcard.h>
uint32_t BaudRate
uint32_t WordLength
uint32_t StopBits
uint16_t Parity
uint16_t Mode
uint16_t CLKPolarity
uint16_t CLKPhase
uint16_t CLKLastBit
uint16_t OneBitSampling
uint8_t Prescaler
uint8_t GuardTime
uint16_t NACKEnable
uint32_t TimeOutEnable
uint32_t TimeOutValue
uint8_t BlockLength
uint8_t AutoRetryCount
uint32_t ClockPrescaler
Field Documentation
◆ AutoRetryCount
uint8_t SMARTCARD_InitTypeDef::AutoRetryCount
Specifies the SmartCard auto-retry count (number of retries in receive and transmit mode). When set to 0, retransmission is disabled. Otherwise, its maximum value is 7 (before signalling an error)
◆ BaudRate
uint32_t SMARTCARD_InitTypeDef::BaudRate
Configures the SmartCard communication baud rate. The baud rate register is computed using the following formula: Baud Rate Register = ((usart_ker_ckpres) / ((hsmartcard->Init.BaudRate))) where usart_ker_ckpres is the USART input clock divided by a prescaler
◆ BlockLength
uint8_t SMARTCARD_InitTypeDef::BlockLength
Specifies the SmartCard Block Length in T=1 Reception mode. This parameter can be any value from 0x0 to 0xFF
◆ CLKLastBit
uint16_t SMARTCARD_InitTypeDef::CLKLastBit
Specifies whether the clock pulse corresponding to the last transmitted data bit (MSB) has to be output on the SCLK pin in synchronous mode. This parameter can be a value of SMARTCARD Last Bit
◆ CLKPhase
uint16_t SMARTCARD_InitTypeDef::CLKPhase
Specifies the clock transition on which the bit capture is made. This parameter can be a value of SMARTCARD Clock Phase
◆ CLKPolarity
uint16_t SMARTCARD_InitTypeDef::CLKPolarity
Specifies the steady state of the serial clock. This parameter can be a value of SMARTCARD Clock Polarity
◆ ClockPrescaler
uint32_t SMARTCARD_InitTypeDef::ClockPrescaler
Specifies the prescaler value used to divide the USART clock source. This parameter can be a value of SMARTCARD Clock Prescaler.
◆ GuardTime
uint8_t SMARTCARD_InitTypeDef::GuardTime
Specifies the SmartCard Guard Time applied after stop bits.
◆ Mode
uint16_t SMARTCARD_InitTypeDef::Mode
Specifies whether the Receive or Transmit mode is enabled or disabled. This parameter can be a value of SMARTCARD Transfer Mode
◆ NACKEnable
uint16_t SMARTCARD_InitTypeDef::NACKEnable
Specifies whether the SmartCard NACK transmission is enabled in case of parity error. This parameter can be a value of SMARTCARD NACK Enable
◆ OneBitSampling
uint16_t SMARTCARD_InitTypeDef::OneBitSampling
Specifies whether a single sample or three samples' majority vote is selected. Selecting the single sample method increases the receiver tolerance to clock deviations. This parameter can be a value of SMARTCARD One Bit Sampling Method.
◆ Parity
uint16_t SMARTCARD_InitTypeDef::Parity
Specifies the parity mode. This parameter can be a value of SMARTCARD Parity
Note
The parity is enabled by default (PCE is forced to 1). Since the WordLength is forced to 8 bits + parity, M is forced to 1 and the parity bit is the 9th bit.
◆ Prescaler
uint8_t SMARTCARD_InitTypeDef::Prescaler
Specifies the SmartCard Prescaler. This parameter can be any value from 0x01 to 0x1F. Prescaler value is multiplied by 2 to give the division factor of the source clock frequency
◆ StopBits
uint32_t SMARTCARD_InitTypeDef::StopBits
Specifies the number of stop bits. This parameter can be a value of SMARTCARD Number of Stop Bits.
◆ TimeOutEnable
uint32_t SMARTCARD_InitTypeDef::TimeOutEnable
Specifies whether the receiver timeout is enabled. This parameter can be a value of SMARTCARD Timeout Enable
◆ TimeOutValue
uint32_t SMARTCARD_InitTypeDef::TimeOutValue
Specifies the receiver time out value in number of baud blocks: it is used to implement the Character Wait Time (CWT) and Block Wait Time (BWT). It is coded over 24 bits.
◆ WordLength
uint32_t SMARTCARD_InitTypeDef::WordLength
Specifies the number of data bits transmitted or received in a frame. This parameter SMARTCARD Word Length can only be set to 9 (8 data + 1 parity bits).
