RTEMS 6.1
Test context for spec:/score/thread/val/fatal-idle-thread-create-failed test case. More...
Data Fields | |
| rtems_fatal_source | source |
| This member contains a copy of the corresponding ScoreThreadValFatalIdleThreadCreateFailed_Run() parameter. | |
| rtems_fatal_code | code |
