This validation test suite contains a test case which is triggered by a fatal error during system initialization.
More...
#define | FATAL_SYSINIT_RUN ScoreThreadValFatalIdleThreadCreateFailed_Run |
#define | CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER |
#define | CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION |
#define | FATAL_SYSINIT_INITIAL_EXTENSION { .thread_create = CreateTask } |
const char | rtems_test_name [] = "TestsuitesFatalIdleThreadCreateFailed" |
| | Each test must define a test name string.
