Tests a fatal error caused by a failing task create extension.
More...
This test case performs the following actions:
- The test action is carried out by configuring a task create extension which always fails.
- Check that the expected fatal source is present.
- Check that the expected fatal code is present.
◆ ScoreThreadValFatalIdleThreadCreateFailed_Run()
Runs the parameterized test case.
- Parameters
| source | is the fatal source. |
| code | is the fatal code. |
