RTEMS 6.1
RCC extended clocks structure definition. More...
#include <stm32h7xx_hal_rcc_ex.h>
Data Fields | |
| uint64_t | PeriphClockSelection |
| RCC_PLL2InitTypeDef | PLL2 |
| RCC_PLL3InitTypeDef | PLL3 |
| uint32_t | FmcClockSelection |
| uint32_t | SdmmcClockSelection |
| uint32_t | CkperClockSelection |
| uint32_t | Sai1ClockSelection |
| uint32_t | Spi123ClockSelection |
| uint32_t | Spi45ClockSelection |
| uint32_t | SpdifrxClockSelection |
| uint32_t | Dfsdm1ClockSelection |
| uint32_t | Swpmi1ClockSelection |
| uint32_t | Usart234578ClockSelection |
| uint32_t | Usart16ClockSelection |
| uint32_t | RngClockSelection |
| uint32_t | I2c123ClockSelection |
| uint32_t | UsbClockSelection |
| uint32_t | CecClockSelection |
| uint32_t | Lptim1ClockSelection |
| uint32_t | Lpuart1ClockSelection |
| uint32_t | I2c4ClockSelection |
| uint32_t | Lptim2ClockSelection |
| uint32_t | Lptim345ClockSelection |
| uint32_t | AdcClockSelection |
| uint32_t | Spi6ClockSelection |
| uint32_t | RTCClockSelection |
| uint32_t | TIMPresSelection |
| uint32_t RCC_PeriphCLKInitTypeDef::AdcClockSelection |
Specifies ADC interface clock source This parameter can be a value of RCCEx ADC Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::CecClockSelection |
Specifies CEC clock source This parameter can be a value of RCCEx CEC Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::CkperClockSelection |
Specifies CKPER clock source This parameter can be a value of RCCEx CLKP Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::Dfsdm1ClockSelection |
Specifies DFSDM1 Clock clock source This parameter can be a value of RCCEx DFSDM1 Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::FmcClockSelection |
Specifies FMC clock source This parameter can be a value of RCCEx FMC Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::I2c123ClockSelection |
Specifies I2C1/2/3 clock source This parameter can be a value of RCCEx I2C1/2/3/5 Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::I2c4ClockSelection |
Specifies I2C4 clock source This parameter can be a value of RCCEx I2C4 Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::Lptim1ClockSelection |
Specifies LPTIM1 clock source This parameter can be a value of RCCEx LPTIM1 Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::Lptim2ClockSelection |
Specifies LPTIM2 clock source This parameter can be a value of RCCEx LPTIM2 Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::Lptim345ClockSelection |
Specifies LPTIM3/4/5 clock source This parameter can be a value of RCCEx LPTIM3/4/5 Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::Lpuart1ClockSelection |
Specifies LPUART1 clock source This parameter can be a value of RCCEx LPUART1 Clock Source
| uint64_t RCC_PeriphCLKInitTypeDef::PeriphClockSelection |
The Extended Clock to be configured. This parameter can be a value of RCCEx Periph Clock Selection
| RCC_PLL2InitTypeDef RCC_PeriphCLKInitTypeDef::PLL2 |
PLL2structure parameters. This parameter will be used only when PLL2 is selected as kernel clock Source for some peripherals
| RCC_PLL3InitTypeDef RCC_PeriphCLKInitTypeDef::PLL3 |
PLL3 structure parameters. This parameter will be used only when PLL2 is selected as kernel clock Source for some peripherals
| uint32_t RCC_PeriphCLKInitTypeDef::RngClockSelection |
Specifies RNG clock source This parameter can be a value of RCCEx RNG Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::RTCClockSelection |
Specifies RTC Clock clock source This parameter can be a value of RCC RTC Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::Sai1ClockSelection |
Specifies SAI1 clock source This parameter can be a value of SAI1 Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::SdmmcClockSelection |
Specifies SDMMC clock source This parameter can be a value of RCCEx SDMMC Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::SpdifrxClockSelection |
Specifies SPDIFRX Clock clock source This parameter can be a value of RCCEx SPDIFRX Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::Spi123ClockSelection |
Specifies SPI1/2/3 clock source This parameter can be a value of SPI1/2/3 Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::Spi45ClockSelection |
Specifies SPI4/5 clock source This parameter can be a value of SPI4/5 Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::Spi6ClockSelection |
Specifies SPI6 clock source This parameter can be a value of SPI6 Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::Swpmi1ClockSelection |
Specifies SWPMI1 Clock clock source This parameter can be a value of RCCEx SWPMI1 Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::TIMPresSelection |
Specifies TIM Clock Prescalers Selection. This parameter can be a value of RCCEx TIM Prescaler Selection
| uint32_t RCC_PeriphCLKInitTypeDef::Usart16ClockSelection |
Specifies USART1/6 clock source This parameter can be a value of RCCEx USART1/6 Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::Usart234578ClockSelection |
Specifies USART2/3/4/5/7/8 clock source This parameter can be a value of RCCEx USART2/3/4/5/7/8 Clock Source
| uint32_t RCC_PeriphCLKInitTypeDef::UsbClockSelection |
Specifies USB clock source This parameter can be a value of RCCEx USB Clock Source
