RTEMS 6.1
PLL3 Clock structure definition. More...
#include <stm32h7xx_hal_rcc_ex.h>
Data Fields | |
| uint32_t | PLL3M |
| uint32_t | PLL3N |
| uint32_t | PLL3P |
| uint32_t | PLL3Q |
| uint32_t | PLL3R |
| uint32_t | PLL3RGE |
| uint32_t | PLL3VCOSEL |
| uint32_t | PLL3FRACN |
| uint32_t RCC_PLL3InitTypeDef::PLL3FRACN |
PLL3FRACN: Specifies Fractional Part Of The Multiplication Factor for PLL3 VCO It should be a value between 0 and 8191
| uint32_t RCC_PLL3InitTypeDef::PLL3M |
PLL3M: Division factor for PLL3 VCO input clock. This parameter must be a number between Min_Data = 1 and Max_Data = 63
| uint32_t RCC_PLL3InitTypeDef::PLL3N |
PLL3N: Multiplication factor for PLL3 VCO output clock. This parameter must be a number between Min_Data = 4 and Max_Data = 512 or between Min_Data = 8 and Max_Data = 420(*) (*) : For stm32h7a3xx and stm32h7b3xx family lines.
| uint32_t RCC_PLL3InitTypeDef::PLL3P |
PLL3P: Division factor for system clock. This parameter must be a number between Min_Data = 2 and Max_Data = 128 odd division factors are not allowed
| uint32_t RCC_PLL3InitTypeDef::PLL3Q |
PLL3Q: Division factor for peripheral clocks. This parameter must be a number between Min_Data = 1 and Max_Data = 128
| uint32_t RCC_PLL3InitTypeDef::PLL3R |
PLL3R: Division factor for peripheral clocks. This parameter must be a number between Min_Data = 1 and Max_Data = 128
| uint32_t RCC_PLL3InitTypeDef::PLL3RGE |
PLL3RGE: PLL3 clock Input range This parameter must be a value of RCC PLL3 VCI Range
| uint32_t RCC_PLL3InitTypeDef::PLL3VCOSEL |
PLL3VCOSEL: PLL3 clock Output range This parameter must be a value of RCC PLL3 VCO Range
