RTEMS 6.1
RCC_PLL2InitTypeDef Struct Reference
PLL2 Clock structure definition. More...
#include <stm32h7xx_hal_rcc_ex.h>
uint32_t PLL2M
uint32_t PLL2N
uint32_t PLL2P
uint32_t PLL2Q
uint32_t PLL2R
uint32_t PLL2RGE
uint32_t PLL2VCOSEL
uint32_t PLL2FRACN
Field Documentation
◆ PLL2FRACN
uint32_t RCC_PLL2InitTypeDef::PLL2FRACN
PLL2FRACN: Specifies Fractional Part Of The Multiplication Factor for PLL2 VCO It should be a value between 0 and 8191
◆ PLL2M
uint32_t RCC_PLL2InitTypeDef::PLL2M
PLL2M: Division factor for PLL2 VCO input clock. This parameter must be a number between Min_Data = 1 and Max_Data = 63
◆ PLL2N
uint32_t RCC_PLL2InitTypeDef::PLL2N
PLL2N: Multiplication factor for PLL2 VCO output clock. This parameter must be a number between Min_Data = 4 and Max_Data = 512 or between Min_Data = 8 and Max_Data = 420(*) (*) : For stm32h7a3xx and stm32h7b3xx family lines.
◆ PLL2P
uint32_t RCC_PLL2InitTypeDef::PLL2P
PLL2P: Division factor for system clock. This parameter must be a number between Min_Data = 2 and Max_Data = 128 odd division factors are not allowed
◆ PLL2Q
uint32_t RCC_PLL2InitTypeDef::PLL2Q
PLL2Q: Division factor for peripheral clocks. This parameter must be a number between Min_Data = 1 and Max_Data = 128
◆ PLL2R
uint32_t RCC_PLL2InitTypeDef::PLL2R
PLL2R: Division factor for peripheral clocks. This parameter must be a number between Min_Data = 1 and Max_Data = 128
◆ PLL2RGE
uint32_t RCC_PLL2InitTypeDef::PLL2RGE
PLL2RGE: PLL2 clock Input range This parameter must be a value of RCC PLL2 VCI Range
◆ PLL2VCOSEL
uint32_t RCC_PLL2InitTypeDef::PLL2VCOSEL
PLL2VCOSEL: PLL2 clock Output range This parameter must be a value of RCC PLL2 VCO Range
